O2 Sensor -to- Misfire on #4 (P0304)
Discussion in '1st Gen. Tacomas (1995-2004)' started by RFMILLS_74, Feb 19, 2022.
  1. Feb 19, 2022 at 10:57 AM
    RFMILLS_74
    RFMILLS_74 [OP] New Member
    Reggie
    2004 Taco TRD
    From what I've gathered these are related but I haven't seen anything that mentioned the O2 sensor as a culprit for causing P0304.
    I have an '04 Taco, had a code for Upstream O2, started running rough, replaced O2 and P0304 shows now.
    I'm probably in need of a tune-up (working from home lends to not driving often) so should I just change plugs and recheck or is there something else looming?
    Many thanks
  2. Feb 19, 2022 at 11:07 AM
    Bishop84
    Bishop84 Well-Known Member
    I haven't seen many o2 sensors cause misfires.
    Misfires are typically ignition based, so wires, coils or spark plugs.
    Injectors are more and more common on the 1st gen tacos lately as well.
    So start with maintenance and go from there.
    If its a v6 there's a date stamped on the ignition leads if its oem. Should give you an idea of where you're at.
    RFMILLS_74[OP] likes this.
  3. Feb 19, 2022 at 12:20 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    B1S1 sensor in an 04 is an air/fuel sensor. I'm not sure what running an O2 sensor upstream would cause but
    I don't think it would cause a misfire.
  4. Feb 19, 2022 at 1:51 PM
    RFMILLS_74
    Reggie
    2004 Taco TRD
    Many thanks. I didn't think there was a relationship so I guess I'm looking at multiple issues. I'll start with plugs and wires.
  5. Feb 19, 2022 at 1:52 PM
    RFMILLS_74
    Reggie
    2004 Taco TRD
    Thanks Bishop. I've been negligent in maintaining her and she let me know there's an issue
