O2 Sensor Tool ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Feb 12, 2011.
  1. Feb 12, 2011 at 6:07 PM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    i replaced the O2 senor towards the front, but can't get too the rear one. can someone tell me what size and type i need too remove it. i used a ratcheting box end wrench too remove the front one. a pic would be nice if you can post it! i did the front one in 20 mins, the back one gave me a neck ache. what a cluster f--- that is!
  2. Feb 12, 2011 at 6:22 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
  3. Feb 12, 2011 at 8:45 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Pipewrench.
  4. Feb 12, 2011 at 9:04 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    I would definitely get something to get down in those threads to loosen it up before you remove it.. I removed mine when i put in my headers and ripped the threading out of it it was so locked in there.. fortunately they went back in
  5. Feb 13, 2011 at 7:10 PM
    beatle
    beatle Well-Known Member
    Springfield, VA
    98 3.4l SR5 TRD
    Use the tool HondaGM linked to, and use Kroil as a lubricant to get the sensor out. If you're able, spray some penetrating lubricant on the threads a few times before you take on the job. I'm doing the same thing on my suspension bolts before my shocks arrive.
    When it comes time to put the wrench to the sensor, if it doesn't turn at first, try going backwards a bit before getting a breaker bar.
  6. Feb 14, 2011 at 1:08 AM
    tlh178
    terry
    lake huron/sag bay
    i've been spraying it with pb blaster for 2 weeks now. i did find some offset box end ratcheting wrenchs on ebay and brought them. if i can't get on them that, i'll buy a crowsfoot! thanks for all the replys!
  7. Feb 14, 2011 at 5:09 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    i just used some tinsnips to cut the shield outta the way then it was no problem to get to.
  8. Feb 14, 2011 at 5:18 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Fuck that. If your exhaust is rusty do yourself a favor and buy a cat back and just chop that thing out. I spent three whole days trying to save my o2 sensor only to realize that nothing would work.
  9. Feb 14, 2011 at 6:49 PM
    tlh178
    terry
    lake huron/sag bay
    the exhaust is still in great shape. not sure if the cat is plugged or not. it looks good for having 265k on it. i'm replacing the sensor past the cat. shitroc, did you replace the shield or just go without it?
  10. Feb 14, 2011 at 6:56 PM
    malander
    max
    01 limited trd 4x4
    Ah well Missouri salt ruined mine for sure haha
  11. Feb 15, 2011 at 3:04 PM
    tacod
    tacod Well-Known Member
    Dan
    Kemblesville, PA
    '04 Xtra V6 TRD 4x4
    this is the correct tool, though i've also had success in the past with a stubby and a hammer.
  12. Feb 15, 2011 at 4:20 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    no i didnt bother replacing the heat shield, i left a little bit of slack in the wires enough so any movement in the exhaust wouldnt tug on them but i made sure that the wires would also never touch on the exhaust and melt.
  13. Feb 23, 2011 at 6:31 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    What size nuts and thread pitch are used on the rear O2 sensor studs?
    The nuts will be destroyed when I take them off, cut them off, otherwise remove them today.
    They are so rusted away that they appear to have been 12mm (outside diameter) at one time. Is the 1.25mm pitch the norm?
    I want to get the replacements on the way home and not make multiple trips to the store.
    Thanks for any input.
  14. Feb 23, 2011 at 5:31 PM
    tlh178
    terry
    lake huron/sag bay
    bowyer, yes the pitch is 1.25 M8 and i think the nuts were 13mm. i thought mine were rounded off or rusted out badly. but they must have vibrated off. i used the 1.25 too rethread mine. the studs looked new after that. sure is nice not too see the check engine light on. i brought some grade 8 nuts and lock washer on mine. g/l
  15. Feb 24, 2011 at 6:21 AM
    bowyer2002
    NE Missouri
    tlh178 -
    thanks, you confirmed my suspicions.
    however, the nuts were 'rust welded' on and I am still trying to get them removed!
    next tool up will be the angle grinder or the dremel!
  16. Feb 24, 2011 at 4:38 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    have you been spraying them repeatedly with some penetrating fluid, i sprayed mine over and over again for 2 days prior to actually removing them and even then had to lock on to them with vice grips.
