O2 sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rckstr, Jul 16, 2013.
  1. Jul 16, 2013 at 5:27 PM
    rckstr
    rckstr [OP] Member
    Tennessee
    04 Tacoma 4x4
    Check engine light is on. Cleaned the MAF and reset the code by disconnecting the battery for 10 min. The light stayed off for a day then came back on. The truck is running poorly if you get into the throttle. Code thrown is too lean in bank one. Think its the O2? Would that cause it to run poorly?
  2. Jul 16, 2013 at 5:28 PM
    TPain
    TPain Boss
    Tanner
    Asheville, NC
    01 Supercharged
    Don't know what would be causing it to run poorly but it could be a bad cat
  3. Jul 16, 2013 at 5:29 PM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    Up stream o2 sensor. I've had mine go bad. My 04 had no power at all and would drink fuel like a fish
  4. Jul 17, 2013 at 7:04 AM
    rckstr
    rckstr [OP] Member
    Tennessee
    04 Tacoma 4x4
    Does the bank 1 code mean its upstream? Where is the best place to buy a new Denso sensor? The truck runs fine at low rpm, but when you mash on the gas, the truck spits and sputters (backfired once). Im thinking it may be the sensor.
  5. Jul 17, 2013 at 11:22 AM
    BamaToy1997
    Bill
    Navarre, FL
    If your engine is sputtering and backfiring, and the code is a lean code, I would look more towards a vacuum leak off-idle (ported vacuum) or something along those lines. Maybe even a fuel supply issue (Which would cause a lean code as well) The bank 1 A/F sensor IS upstream, so it is the closest one to the engine.
