O2 sensors......proactive or reactive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patos tacoma, Mar 7, 2021.
  1. Mar 7, 2021 at 12:49 PM
    patos tacoma
    patos tacoma [OP] Well-Known Member
    hello TW Community,
    I have 2010 DCSM, 218K
    working my way down a list of things to replace, flush, repair and next on my list I’m looking at the “upstream” o2 sensors that look like crap, grungy and rusted....obviously OEM original.
    Do I wait for them to fail and give me engine check light and code?
    How hard to take off?......looks from videos , I need special tool....
    all kinds of price ranges for parts....
    As always, thanks in advance
    whatstcp likes this.
  2. Mar 7, 2021 at 2:05 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Some people claim they can drift over time causing slightly worse MPG. Not sure I agree with that logic. Anyhow, if you're going to be removing them to replace them, no special tools are required just cut the harness off and use a regular socket. I would let them run to failure, and I personally consider them to be one of those "life of the engine" type of parts.
  3. Mar 7, 2021 at 2:09 PM
    Bishop84
    Bishop84 Well-Known Member
    Reactive.
    The ECU is always monitoring them for accuracy and compare them to the downstream sensors to see how the voltages match.
    6 gearT444E likes this.
  4. Mar 7, 2021 at 2:21 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    My originals got almost 350k. I had the rasta code, P0420 and that turned out to be a gasket.
    I say wait till they throw a code. They're not cheap.
    avery0829, whatstcp and 6 gearT444E like this.
  5. Mar 7, 2021 at 2:25 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    :rasta:
    Larzzzz[QUOTED] likes this.
  6. Mar 7, 2021 at 4:27 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I personally don’t like messing with emissions components until I have too.
    If there isn’t a problem, I don’t take the chance of creating one.
    Like @whatstcp said, Toyota’s can be “temperamental” with AF and O2 sensors.
    Might as well use the ones that are working fine now and deal with what “might” be a problem later.
  7. Mar 7, 2021 at 4:48 PM
    Spizike231
    Spizike231 Pickin’ & Grinnin’
    Jesse
    Sacramento, CA
    2011 MGM DCSB TRD Sport 4x4
    When I got a check engine light / trac control light for em I went to replace them
    But before I did, I switched the fuse for em with my fog fuse and the next day my lights went away. When I returned them to my stealership they said “no one ever buys these” because they almost never go out.
    I say reactive.
  8. Mar 7, 2021 at 5:07 PM
    Waasheem
    Waasheem
    2007 xrunner
    There is a o2 sensor socket, mine is 7/8”.
    There’s other sized sensor sockets but the 7/8 fit every one I did so far.
    They can be a bear to get out, even if you soaked it with penetrant. On a customer vehicle I spray it cold, run the engine to heat it up. Go get the part, then it’ll come out. On my car I sprayed it, let it sit overnight, drove it, sprayed it cold overnight again. Overkill but I did that for a week, came out easy. Just make sure you’re on it good before twisting. Strip it, your screwed. I had to use a pipe wrench on one someone slipped on.
