O2 sensors
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreenTacoSr5, Sep 30, 2016.
  1. Sep 30, 2016 at 12:47 PM
    GreenTacoSr5
    GreenTacoSr5 [OP] Active Member
    1999 Tacoma prerunner 3.4
    Anybody know where I can get them? Both sensors?
  2. Sep 30, 2016 at 1:07 PM
    lonzorizo
    lonzorizo Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
  3. Sep 30, 2016 at 4:39 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    Are you getting a code? Last time i threw a cel i pulled the sensor and cleaned it off with sea foam and haven't had an issue with it since. That was about a month ago.
  4. Sep 30, 2016 at 5:24 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Mag Grey TRD OR Xtracab
    2" plus lift on Bilstiens, Timbrens, U-Bolt flip
  5. Oct 1, 2016 at 2:26 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Now that Napa sells Denso that is where I get mine.
  6. Oct 1, 2016 at 2:56 PM
    GreenTacoSr5
    No no code at all, crawled under and saw that the first bank o2 sensors wire was cut off prior to the previous owner now I want to change both of them.
  7. Oct 1, 2016 at 4:30 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Gotcha, like they said above denso is good.
    GreenTacoSr5[OP] likes this.
  8. Oct 2, 2016 at 7:57 AM
    jaunty
    jaunty Well-Known Member
    99 V6 TRD Automatic 4x4
  9. Nov 26, 2016 at 2:14 AM
    motoman515
    motoman515 Member
    tim
    Menifee, Calif.
    00 PreRunner XCab
    K&N Filter And Tube
