O2 Simulator or Replace Cat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaEli, Sep 16, 2020.
  1. Dec 30, 2020 at 10:41 AM
    #41
    4Barrel
    4Barrel Well-Known Member
    Buffalo, NY
    2004 SR5 TRD
    Sounds like we wired it the same way.
    Curious, did you modify the "new" o2 sensor, or the old one?
  2. Dec 30, 2020 at 11:19 AM
    #42
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    I started out trying to eliminate the code by installing two new Denso sensors. No luck.
    I ended up with one new sensor in front and modified. The old one back in the #2 position unmodified.
  3. Dec 30, 2020 at 11:25 AM
    #43
    4Barrel
    Buffalo, NY
    2004 SR5 TRD
    DOH.
    I'm modifying the rear (post cats) O2 sensor, not the front A/F sensor.
    Confused... the you tube vids i saw showed the mod on post cat sensor, and b/c you mentioned you put the modified harness under the passenger seat, which is where the rear o2 sensor connects...
  4. Dec 30, 2020 at 11:27 AM
    #44
    Old n' slow
    Oak Island, N.C.
    CRAP !!!!! Don’t mind me it’s been a year plus. YOU are correct it’s the rear that’s modified. Story for the confusion.
    p.S.....the new is in front unmodified. The old is in rear modified.
    4Barrel likes this.
  5. Dec 30, 2020 at 11:31 AM
    #45
    4Barrel
    Buffalo, NY
    2004 SR5 TRD
    WHEW, that threw me! lol!
    So, I did pretty much the same thing: New front A/F, new rear O2 sensor. Using my extra O2 sensor for the mod, which was the "old" one... maybe i need to modify the newer one to get to a better threshold voltage. I'll give it another go.
    Thanks for the replies... it's helpful!
