O3 4WDYOTA college build/488s/mall crawl + BS
Discussion in '1st Gen. Builds (1995-2004)' started by snowboard704, Sep 12, 2016.
  1. Dec 14, 2016 at 5:46 PM
    #141
    snowboard704
    snowboard704 [OP] Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Pm'd
  2. Dec 14, 2016 at 6:58 PM
    #142
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    Replied back to you. Look forward to hearing from you.
  3. Dec 14, 2016 at 8:58 PM
    #143
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Amazing build man.
    snowboard704[OP] likes this.
  4. Dec 14, 2016 at 9:53 PM
    #144
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Thanks :hattip:
    It's been a fun project
    DustStorm4x4[QUOTED] likes this.
  5. Dec 14, 2016 at 10:10 PM
    #145
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    Pmd also, mine just went out.
  6. Dec 15, 2016 at 10:51 AM
    #146
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Awesome build, man. I had jumper's kit in my 2nd gen. Enjoyed them a lot, and he was good to do business with as well. Guess I'll add that to the to-do list.
  7. Dec 15, 2016 at 12:44 PM
    #147
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Good to hear.. I'll be ordering them in about 2 weeks :thumbsup:
    rngr[QUOTED] likes this.
  8. Dec 15, 2016 at 12:52 PM
    #148
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    I just ordered them, how hard were the LED ones you put in to do? Pretty simple?
  9. Dec 15, 2016 at 12:59 PM
    #149
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Super simple.. just need a small flathead and everything just pops out
    Delta00[QUOTED] likes this.
  10. Dec 16, 2016 at 10:46 AM
    #150
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Troy, what did you order from @csjumper2003 ? Is it map lights and dome light?
  11. Dec 16, 2016 at 10:53 AM
    #151
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Yep, map and dome. Kinda expensive but I really miss my dome light and always wanted to go led.
  12. Dec 16, 2016 at 10:58 AM
    #152
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks.
    I'll be curious to hear what you think of them. Like how bright they are and the color temp.
  13. Dec 21, 2016 at 6:40 PM
    #153
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Filled up At a crappy gas station in Nevada the other day
    Noticed the truck running like garbage.. kind of lurching at low rpm cruising and also while accelerating hard. Changed the plugs and wires today (Toyota oem) and helped a lot but still doing in a little.
    Hopefully it's just the bad gas in it
  14. Dec 27, 2016 at 2:30 PM
    #154
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Well this will be my first trip report/write up so well see how things go...
    Couple weeks of planning prior had led to a group of five to make the trek across the mojave desert (laughlin --> Barstow) via Mojave road. @eon_blue (will be stealing some of your pics for this:hattip:) @Andybear @Mike likes Tacos @Kens04Taco
    We all met up at a gas station on the cajon pass at 7:30 sharp... ish:D
    Me and Andy drove to the meet up spot while ryan, ken, and mike drove together to the meet spot. Cold winds and overcast skies promised a chilly weekend ahead. After we had all filled up, the trek to laughlin began, only about 3 1/2 hours ash but a head wind made everything fun:bananadead: With the rigs all loaded up they didn’t seem to like the wind and constantly fighting the wind pushing you off the road got quick rather quick.
    Once we arrived to the AVI casino gas station (laughlin) we got gas, picked up some beef jerky, flipped on the radios and headed to the trail head. The adventure had begun.
    We drove about half a mile into a wash and parked along the hill side to get a quick lineup pick while also airing down.
    [​IMG]IMG_4839 by Austin Burton, on Flickr
    From there we got to eat Mikes roost all the way until the next stopping point. The desert scenery was amazing, cruising through the hills, washes, and trees was unlike I had ever done before really.
    [​IMG]IMG_5375 by Austin Burton, on Flickr
    [​IMG]IMG_5377 by Austin Burton, on Flickr
    [​IMG]IMG_5378 by Austin Burton, on Flickr
    The different shades of the dirt in the hills popped out and grabbed your attention while driving.. getting some interference over the radio we decided to stop and change channels. This is when I noticed my rear shock leaking, the shock had moved and hit a fitting on my rear shock bracket causing the nut to loosen up just barely causing a little oil leaking out. A quick trail fix with zip ties fixed it for the rest of the trip (fixed officially now).
    [​IMG]IMG_4841 by Austin Burton, on Flickr
    Continuing on and many jokes over the comms later we reached the turnoff for ford piute, cruising along the very rocky road we finally reached the old fort. It was used to house mail riders and made for a good spot out of the wind to catch our breathe and relax for a few minutes.
    [​IMG]IMG_4842 by Austin Burton, on Flickr
    Hopping back into the rigs we backtracked to the main Mojave road trail and continued on, starting to look for a place too call home for the night. After traversing the little washed out road we found our camp for the night, it was on the top of a hill in a plateau kind of area with a wind break. We rushed to set up camp before nightfall and before the temperatures plummeted. The forecast predicted mid 20s and some wind. The wind is what made it much worse, my zero degree bag, thermal clothing, and buddy heater made short work of the cold but some others weren’t as comfy:rofl: That night on the menu was bacon wrapped steaks and carne asada tacos.
    [​IMG]IMG_4845 by Austin Burton, on Flickr
    [​IMG]IMG_4844 by Austin Burton, on Flickr
    [​IMG]IMG_5397 by Austin Burton, on Flickr
    The next morning we brushed the ice off everything and thawed out for our next big day ahead. For breakfast we cooked our half frozen eggs, ham, and bacon. Searching for water that wasn’t all frozen. We left for that days drive about 9am. Everyone was eager to turn their heaters on and get on with the day.
    The next stop was the bus.
    [​IMG]IMG_5400 by Austin Burton, on Flickr
    [​IMG]IMG_5398 by Austin Burton, on Flickr
    [​IMG]IMG_5406 by Austin Burton, on Flickr
    [​IMG]IMG_4846 by Austin Burton, on Flickr
    After the bus, back to driving through joshua trees to our next stop
    [​IMG]IMG_5411 by Austin Burton, on Flickr
    [​IMG]IMG_5413 by Austin Burton, on Flickr
    [​IMG]IMG_5415 by Austin Burton, on Flickr
    The only semi difficult part of the trail. Which gave us an excuse to go back up it.. just for fun:D
    [​IMG]IMG_5422 by Austin Burton, on Flickr
    [​IMG]IMG_5431 by Austin Burton, on Flickr
    First gen best gen!
    [​IMG]IMG_5433 by Austin Burton, on Flickr
    Next stop was the mail box, so cool how the offroad community can come together to keep something like this going.
    [​IMG]IMG_5437 by Austin Burton, on Flickr
    [​IMG]IMG_5443 by Austin Burton, on Flickr
    [​IMG]IMG_4851 by Austin Burton, on Flickr
    [​IMG]IMG_5456 by Austin Burton, on Flickr
    [​IMG]IMG_5457 by Austin Burton, on Flickr
    [​IMG]IMG_5459 by Austin Burton, on Flickr
    [​IMG]IMG_5460 by Austin Burton, on Flickr
    Back to the road
    [​IMG]IMG_5448 by Austin Burton, on Flickr
    LAVA TUBES
    [​IMG]IMG_4852 by Austin Burton, on Flickr
    On the way there we past a lowered mazda who had gotten stuck in the sand which gave mike the perfect opportunity to test out his new winch. They had been there over two hours.. luckily for them we came by.
    Base camp for night two we chose a wiser spot. Closer to the Barstow area now we found a rock wall to huddle up against for the night circling the trucks so we could avoid what happened the previous night. Luckily for us it wasn’t as cold as the previous night. Tight quarters.
    [​IMG]IMG_4853 by Austin Burton, on Flickr
    [​IMG]IMG_5472 by Austin Burton, on Flickr
    [​IMG]IMG_5469 by Austin Burton, on Flickr
    The next morning we headed back into the desert for the final stretch.
    [​IMG]IMG_5517 by Austin Burton, on Flickr
    [​IMG]IMG_5521 by Austin Burton, on Flickr
    [​IMG]IMG_4857 by Austin Burton, on Flickr
    Next was the rock pile monument on Soda Lake.
    [​IMG]IMG_4859 by Austin Burton, on Flickr
    Continuing on we entered a giant, soft wash which left ken a bit stuck. A quick tug from Ryan got him free in no time with no more incidents the rest of the trip. The Gaia gps track I had had been perfect until now, we kind of made out own way where the gpx file told us to go until be got to the correct road. We think the sand had blown over the road making it hard to see.:notsure:
    [​IMG]IMG_5522 by Austin Burton, on Flickr
    [​IMG]IMG_4862 by Austin Burton, on Flickr
    Once in Afton canyon, reaching our ending point we found some fun little 4x4 trails to follow and play around on before having to end the journey. Wd followed them up to a couple canyons and hiked to the back. Definitely one of the highlights of the trip seeing the huge canyon walls formed over the years and getting to crawl around in the caves they made.
    [​IMG]IMG_4863 by Austin Burton, on Flickr
    [​IMG]IMG_4864 by Austin Burton, on Flickr
    After hiking and lunch at the canyon. We continued onto the river. The water wasn’t too deep compared to before but was deep enough that it made it fun for sure.
    [​IMG]IMG_5535 by Austin Burton, on Flickr
    [​IMG]IMG_4866 by Austin Burton, on Flickr
    After the crossing was a grated flat road winding in and out of hills so we cruised that until the full off on the side of the freeway. When we got to pavement our epic journey had come to an end.
    [​IMG]IMG_5544 by Austin Burton, on Flickr
    Our journey through the desert was now complete. Over 120+ miles were clocked and many laughs around the fire enjoying the good times. Great bunch of guys to spend a few days with and hope to do another trip in the near future. Trips like this is what fuels my addiction to keep building my truck, thanks a lot guys:rofl::bananadead::cheers:
  15. Dec 27, 2016 at 2:53 PM
    #155
    Mike likes Tacos
    Mike likes Tacos Mod in Training
    Northridge,CA
    2014 4x4 DCSB
    Long travel with big tires and lights
    Great trip report! Looking forward to the next one.:cheers:
  16. Dec 27, 2016 at 6:39 PM
    #156
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Austin if you don't mind me asking...what setup from King did you go with (I know you had to custom it) and what was the price...needing to redo my front and trying to see how bad it's gonna hurt my bank account.
    You can PM me so you don't have to post price if you don't want to...thanks in advance bro!
  17. Dec 27, 2016 at 6:53 PM
    #157
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea no problem, I went through DSM and got a little deal.
    Pretty much the extended travel oem shocks with the resi. Think they were 1300 out the door if I remember correctly so not too too bad :notsure:
    LogCabins[QUOTED] likes this.
  18. Dec 27, 2016 at 6:56 PM
    #158
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Yeah that's not bad at all, without resi they are 900 and some change so that's pretty good! Thanks bro!
  19. Dec 27, 2016 at 7:00 PM
    #159
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Yea no problem.. I got the 90 degree fittings added on as well so they tacked a bit on for that as well
  20. Dec 27, 2016 at 7:05 PM
    #160
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    More than helpful huge thanks and BTW that looked like a fun wheeling trip! Happy New Year!!!
