O4 Tacoma 6 cyl Throttle Hesitation ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HawaiianBrian, Sep 1, 2010.
  1. Sep 1, 2010 at 8:33 PM
    HawaiianBrian
    HawaiianBrian [OP] Member
    Big Island
    04 Xtra Cad TRD 4x4
    I am hoping for some input, here's the scoop:
    My 2004 Tacoma 6cyl has been having some hesitation when I press the gas now and then. No RPM response at all at times, I need to let off and keep pressing the gas until it responds.
    I had it to a local mechanic who hooked it up to a PC and found no errors. He checked and cleaned the throttle body and said it was fine, it ran OK for a few days then started acting up again.
    Took it to another mechanic who told me my throttle body needed to be replaced wanted me to pay 1500.00, I left.
    I do quite a bit of off roading and one long dusty trail in particular. I thought perhaps some dust had gotten into something so I cleaned the sensor connections, throttle body, etc...it ran fine for a week, then started hesitating worse than ever this weekend, actually "jerking" the truck coming up the hill to my house.
    This doesn't happen consistently, it can go for days or a week without any problems, then drive like crap for a few days, then back to normal.
    Anyone experience anything similar?
    I plan to check my fuel filter, fuel sending unit this weekend, Throttle Position Sensor, Mass Airflow, etc.
    Any advice greatly appreciated.
  2. Sep 1, 2010 at 9:00 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    check your fuel filter and clean you maf first
  3. Sep 2, 2010 at 1:02 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Do you get actual hesitation from the engine like sputtering & jerking or does it simply not respond when the pedal is pressed? If it's the latter I would say check out the ETCS-i "throttle by wire" system.
    When I was looking to buy my truck I read about a few people having problems with this on the 03-04s & is why I choose to get a 01-02 which has a throttle cable direct to the throttle body.
    Seems like Toyota has had this issue long before the recent blown out of proportion incidents. Doesn't seem like a whole lot of people have had this problem on 03-04s but there are.
  4. Sep 2, 2010 at 5:50 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The 2003 - 2004 Tacoma ETCS-i system was not pure 'throttle by wire', because there was still a direct mechanical cable linkage from the accelerator to the throttle body. However, sensors at both ends (Accelerator / Pedal Position Sensor; Throttle Position Sensor) fed the ECM, which adjusted the throttle on its own using the motor-controlled throttle.
    *IF* this problem is caused by the ETCS-i system it's probably one or the other sensor going bad, or maybe a wiring fault between either sensor and the ECM.
    It could also be explained by a problem with the throttle control motor mechanism (or its wiring / connections).
  5. Sep 3, 2010 at 1:16 AM
    HawaiianBrian
    Big Island
    04 Xtra Cad TRD 4x4
    Mahalo for the suggestions guys...
    Until this last episode I never actually had hesitation with the engine, the engine simply didn't respond to the gas pedal, when it did respond it was fine. While coming home last weekend it did begin to miss and the truck would jerk around.
    Since then I've just left it alone and drove the old Jeep in hopes that it would "fix itself" because that always works right.
    I've got a long weekend so I'll be trying to get it resolved. Wish me luck and have a great weekend.
    Aloha!
  6. Aug 9, 2011 at 3:24 PM
    bloodywolf
    bloodywolf New Member
    Hi
    Did you ever find a fix for this problem? My Taco is doing the same thing.
    Thanks,
    Joe
  7. Aug 12, 2011 at 10:38 PM
    HawaiianBrian
    Big Island
    04 Xtra Cad TRD 4x4
    I did, I bought a new throttle bottle and had it installed. Problem solved. Cost me 700.00 I think. Good luck.
    Clarification: I bought a rebuilt one, not a new one. 700.00 included overnight shipping to Hawaii.
  8. Aug 13, 2011 at 7:12 PM
    johnny j
    johnny j Member
    john
    carson city, nevada
    99 tacoma x-cab prerunner
    various
    I had a similar problem and I replaced the throttle position sensor..problem solved. The reason for this is the throttle cable only moves the butterfly in the throttle body. The TPS actually sends a signal to the ecu to tell the fuel injectors to spray fuel. You can find a new one on e-bay for a very reasonable price. Hope this helps.
  9. Aug 13, 2011 at 7:41 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    X2
  10. Aug 14, 2011 at 1:30 PM
    bloodywolf
    How hard it is to change the TPS, can you describe the process or point me to a HOWTO? I am going to try this as it is only $50.
    Thank you
  11. Mar 14, 2013 at 4:23 PM
    JoshRug
    JoshRug New Member
    Josh
    Utah
    2001 Taco. Black on black
    Lift puck and rims.
    I am experiencing very similar issues with my '01 Taco. However, it typically happens more on drives that are over 5 to 10 minutes. I am going to look into the fuel filter tonight, but was seeing if this is a waste if time or what. Any help would be great.
  12. Mar 14, 2013 at 9:11 PM
    cruiseroutfit
    cruiseroutfit Well-Known Member
    Kurt
    Sandy, Utah
    08-200 00-100 89-74 87-61 72-40 66-45 & 65-Stout
    This is a known issue with the APPS, which is only available from Toyota as a complete throttle body.
  13. May 13, 2013 at 9:15 PM
    JoshRug
    JoshRug New Member
    Josh
    Utah
    Lift puck and rims.
    Is the apps the same as the GPS, or are we talking about separate parts?
  14. May 13, 2013 at 9:17 PM
    JoshRug
    JoshRug New Member
    Josh
    Utah
    Lift puck and rims.
    Stupid iPad autocorrect. I meant is the APPs the same as the TPS?
  15. Jul 28, 2013 at 9:08 AM
    tubbsj
    tubbsj New Member
    Johnny
    Alabama
    2003 Toyota Tacoma
    HELP!!!
    I was having the same problem on my 2003 Tacoma!!! I replaced the throttle body. I still have the same problem: 1/3 play in the throttle, high idle (1500-2000 rpm). When I disconnect the battery cable and reconnect it runs fine, no play in throttle and idles around 500 rpm. But when I shut the engine off and restart it, it goes back to the high idle and play in throttle.
    Brand new $1200 Throttle Body!!!
    PLEASE HELP!!!
  16. Oct 5, 2014 at 4:47 PM
    squrrrlygurl
    squrrrlygurl Member
    Oakland, CA
    2003 4x4 SR5 DeChromed
    Debadged, Black Trim
