Oahu deals and Craigslist finds
Discussion in 'Hawaii' started by FMF, Feb 27, 2013.
  1. Mar 18, 2023 at 7:49 PM
    #6901
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Looking for a OEM Roof Rack! Anyone have 1 in the garage after adding an overland style rack or if someone wanted to remove but didn't want to pay big $ for the trim pieces. I can offer my drip rail trim pieces as well as cash $$.
  2. Nov 15, 2023 at 4:20 PM
    #6902
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
    Selling some stuff on CL. Haven't been on here for ages. Oahu members first, lemme know
  3. Dec 11, 2023 at 9:30 PM
    #6903
    Kev2ndGen
    Kev2ndGen Member
    Kevin
    2012 Tacoma Sport
    Sold.
    Exhaust for 2nd gen DCSB for sale.
    Originally was a TRD exhaust, swapped in a Borla Pro xs 14” muffler. Exhaust dumps right after axle. Will not fit with spare tire, pic attached to show.
    Muffler is less than 6 months old.
    Only selling because I bought another exhaust setup.
    pinktaco808 and JS2ndGen like this.
  4. Jan 22, 2024 at 8:27 PM
    #6904
    hwntaco20
    Sold
  5. Jan 23, 2024 at 11:10 PM
    #6905
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    Stock 2023 TRD Sport wheels and tires. Fresh off the dealer lot with 450 miles, excellent condition. No TPMS. Located in Ewa Beach. $650.
  6. Feb 22, 2024 at 3:19 PM
    #6906
    hwntaco20
    Sold
    daveeasa likes this.
  7. Mar 8, 2024 at 2:01 PM
    #6907
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    WTT, Toyota steelie (off T4R) w new 265/70R17 tire for your 265/65R17 stock size spare, date code was 2022 IIRC.
    Was planning to size up on my dad's truck but recently got some clean Firestones in 265/65R17 so I'm committed to stock size for the next decade. I'd like to get him a properly matching spare now that I've changed course. Straight trade, no cash either way. I'd prefer a 17" steelie if possible but no bbk (yet) so a 16 would work if date code 2020 or newer. I'm no longer in town but could coordinate, ideal would be you come to my dad's in Manoa and help him with the swap. Good for anyone running 265/75R16 or 265/70R17 to have a proper sized spare. No TPMS as far as I'm aware.
    Hit me up via DM if interested.
  8. Mar 15, 2024 at 11:33 AM
    #6908
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    GONE
    Front wheel bearing assy .Still good 100500miles . Replaced because assumed bearing noise was front but was rear :boink:. Free if anyone wants it. Also got 2 front rotors thats not bad
    Island Cruiser likes this.
  9. Jun 20, 2024 at 12:18 PM
    #6909
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    Selling my factory installed TRD supercharger off of my 2015 Toyota Tacoma Xrunner. Will fit all 2005-2015 Toyota Tacoma or any 1grfe v6 4.0 with single vvti engines that were found in the 4Runner and Fj.
    Unit has been well maintained, a catch can was installed to keep the internals clean and oil was changed using JB Performance Supercharger oil is a synthetic oil with 3 stage technology. URD 2.7 pulley is installed, with pulley wrap mod. Unit has about 80k miles on it. Makes about 7.5 - 9 pounds of boost. Depends on your intake and exhaust system.
    It will come with
    URD maf cal, tuned for my set up and runs strong! But will need a new tune after installation, as every set up is different.
    TRD injectors
    spark plugs
    Throttle body adapter for a 76mm
    Belt drive system belt, tensioner, bracket, and pulleys
    You would need to purchase the fit kit to complete the install.
    I do have extra parts for it
    New- URD Interchange pulley set up with 2.55 pulley
    New- Jon Bond Carbon Fiber Drive Snout Coupler
    -URD snout cutter
    It’s still on my truck so you can sample it if you are serious in buying it than will just need a day to remove all the parts off the truck
    $5k
    OnyXrunner and daveeasa like this.
  10. Aug 10, 2024 at 10:54 PM
    #6910
    Blue17
    Blue17 Well-Known Member
    Aaron
    Blazing Blue 2017, TRD Off Road
    Selling the tacoma soon, after i hit the post limit. but seeing if theres interest in the RCI Bedrack, CVT RTT with annex, used and abused maxtrax, and Hilift Jack. Will post better pictures next week but message if interested
    https://imgur.com/a/QwI9Pc1
    polekasta likes this.
  11. Dec 22, 2024 at 9:33 AM
    #6911
    Oahu96819
    Oahu96819 Well-Known Member
    Robert
    Honolulu, HI
    2019OR 4WD
    2019 TRD Off Road for sale $35,000 - Orig. Owner. Dealer serviced. 34,000 miles. clean. new at 25k includes Toyo 275 70r17 Method Wheels Bil5100 Eibach Springs. Registered to 9/25. Honolulu
  12. Jan 10, 2025 at 3:35 PM
    #6912
    Braunschwaga
    Braunschwaga AyeeeeVita
    A-A-Ron
    Kauai, HI
    TE37X OG
    16x8 -20
    6x139.7/6x5.5
    Gloss Black
    Brand New w/Box
    All Original
    $4,000 Shipped
  13. Apr 30, 2025 at 11:39 PM
    #6913
    hwntaco20
    Up for sale
    3rd Gen Tacoma, came off a 2020 TRD OR.
    Meso Stage 1 tail light kit solf
    Meso map and dome lights, early version, sold
    Meso key fob, 1st version, sold
    Teton shifter, army green accent. Automatic
    $80 price $75 shipped
    Left side cubby -sold
    Located in Kaneohe but work all over town during day.
    Can ship but need to check rates.
  14. Aug 3, 2025 at 11:09 AM
    #6914
    TacoLolo
    TacoLolo Well-Known Member
    JC
    808
    2004 PreRunner SR5 Xtra-cab 2.7L L4 A/T TRD Off Road
    Mostly cosmetic but she ain’t stock(looking) anymore.
    FOR SALE!
    Located on KAUAI, 2016 LEER truck topper for 6’2” bed in good condition. Came off of my 2004 Xtra cab Tacoma. Rear window locks and comes with new unused rubber bed seal. Has some clear coat peel on top above side windows, paint code 3P1.
    MAKE ME A REASONABLE OFFER!
