Oahu Lift: Home install or pay a garage?
Discussion in 'Hawaii' started by SmackGoneWild, Jun 14, 2014.
  1. Jun 15, 2014 at 5:00 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    I have 5100/stock coils on the top notch(2.5") upfront.
    Trd sports 3 leaf pack with a 1.5" aal an a 1" block in the rear. Rcd bilstein 5100 shocks.
    Ride isnt bad at all. If u wanah take a ride lmk.
  2. Jun 15, 2014 at 5:16 PM
    SmackGoneWild
    SmackGoneWild [OP] Member
    Aaron
    Kapolei, HI
    14 LB TRD
    workin' on it.
    That's a good point. Aside from elevating it, ride quality does matter to me. Keeping the same feel or improving works, just not making it worse.
    Thanks for all the quick responses guys, finally getting somewhere here.
  3. Jun 16, 2014 at 1:34 AM
    SmackGoneWild
    Aaron
    Kapolei, HI
    14 LB TRD
    workin' on it.
    http://bilsteinlifts.com/shop/05-and-up-tacoma/bilstein-adjustable-lift-kit-with-5100-shocks/
    If it turns out the shipping on this doesn't kill me, then this is the way to go I believe.
    Estimate Shipping for Hawaii is coming back as
    Free Shipping
    FedEx Ground: $207.41
    FedEx 2Day: $281.95
    so Im thinking the free shipping doesn't apply to the islands
    Sounds like everyone agrees to skip the diff drop,
    And also in the Q&A section there's one answer that makes me nervous..... the few questions about needing new UCAs seems to get passed over in the answers.
    Also going with the ToyTec 2inch AAL do I need to grab a top plate spacer to level it out, or do I take a bigger chance needing UCAs and possible having a lower rear overtime?
    Liking the idea of doing this at home more and more. So close to buying now!
  4. Jun 16, 2014 at 1:51 AM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
  5. Jun 16, 2014 at 1:56 AM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Pm likeaboss4x4. Tell them what u are looking for an they will hook u up with a pretty good deal. Wen i have the funds i will be going through them to get my maxtrac spindles an allpro leaf pack. I bought my bilsteins from them an am currently waiting for a u bolt flip kit with rear brakelines. Some of the best customer service ive recieved yet. An ive communicated with all the top recommended dealers.
  6. Jun 16, 2014 at 2:13 AM
    Koootch
    Koootch Well-Known Member
    Oahu
    2011 Prerunner
    Maxtrac Spindles, Bilstien 5100s @.85, OME Dakar, Fuel trophies w/ BFG AT KO 285/70/17
    Definitely check out headstrongoffroad too. I just ordered the maxtrac bundle without the leaf packs and shipping was $125 for two heavy boxes. Packages arrived in 3 days. The kit you're looking at should weigh a lot less so shipping might not be that bad.
  7. Jun 16, 2014 at 2:37 AM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    X2...they to give pretty good deals.
  8. Jun 16, 2014 at 12:51 PM
    MikeyTG
    MikeyTG Oh Herro
    Oahu
    IMO, stock suspension is the best ride quality you will achieve on the road. If you are adding springs (stiffer to achieve lift) or preloading shocks, you will feel the road more harshly than you would with stock suspension. Just something to consider b/c I don't want you to think you are going to get an improved on-road driving experience when you lift and it sounds like on-road driving experience is a priority for you.
  9. Jun 16, 2014 at 9:09 PM
    SmackGoneWild
    Aaron
    Kapolei, HI
    14 LB TRD
    workin' on it.
    does the bilsteinlift.com or the headstrong links a few posts up have any noticeable differences?
    sorry, bilsteinlift replied saying to get the top plate spacer to fully level the truck at 3 inches in the front, and that "Most people are able to get their vehicle back into alignment without the UCA’s, but we do recommend them 2.5” or higher simply because they do add 2 degrees of adjustability for your alignment."
    .. I really hate that "most" part, too much beating around the bush.
  10. Jun 17, 2014 at 12:42 AM
    lemon177
    lemon177 Well-Known Member
    Matthew
    kauai/oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    I got the 885 plus top spacer on the sport shocks with no aftermarket UCA. Sure it may limit the down travel, but I've taken my truck to peacock flats and kaena with no problems.
    My only negative thing to say about bilsteins with setting preload is that the higher you go, you get less quality in ride...but theres some out there that have no complaints with it. Personally, I'd suggest the OME setup from toytec, it's good quality plus great price, plus you can always swap to different shocks later down the road for improvement.
  11. Jun 17, 2014 at 1:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    wait.....they told you what?
    That makes absolutely no sense
  12. Jun 17, 2014 at 3:30 AM
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    looks like they come with the same stuff. the headstrong you can add the eibach coils or ome coils. price is the deciding factor
  13. Jun 18, 2014 at 11:54 PM
    SmackGoneWild
    Aaron
    Kapolei, HI
    14 LB TRD
    workin' on it.
    Thanks for all the input guys. I went ahead and contacted Boss4x4 (likeaboss4x4 here) and got the best deal + shipping. Hopefully in a couple weeks they will be delivered and I will take a day to install them. Went with
    Bilstein 5100 Series Front Adjustable 0-2.5" Lift Shock
    RCD Bilstein 5100 Rear Shock for '05+ Tacoma
    OME 5mm Trim Packer
    Wheeler's 3-Leaf Progressive AAL
    ..also installed Wet Okole front and rear seat covers in Realtree
    tomorrow is Dynamat on all 4 doors, back wall behind enclosure is already done.
  14. Jun 19, 2014 at 12:08 AM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Awrite!!! Boss does hook it up even for us guys in Hawaii!
    I should have my flip kit an rear extended brakelines from them by next week.
  15. Jun 19, 2014 at 2:25 AM
    #35
    808state
    808state Well-Known Member
    Randy
    Hawaii
    Prerunner Sport DCLB
    Debadged, painted emblem, TRD badge, BFD, Duratrac (replaced), Gorilla, Maxtrac, Dakar, 5100s, extended brake lines, Toytec 1/4" top plate spacer, Spidertrax, Rally Armor universal, Auto Ventshade Stepshield, N-Fab, Antenna-X, TRD skid, Weathertech DigitalFit and deflectors, Wet Okole, Redline Tuning QuickLIFT, OEM exhaust tip, FormulaOne Pinnacle, OEM bed mat, Roll-N-Lock, 2014 head unit, Ultragauge, Smittybilt shackles and hitch mount, Smittybilt shovel (broken), Curt, Bushwacker, BPFabricating tow hook, OME 883s (replaced), D29XL, Light Racing, SuperBumps, painted valance, Salex, ARB, Staun, Viair, Yakima, BHLM, OME 885s, Toytec 1" block (removed), Daystar d-ring isolators, 2" block, 1/2" top plate, Toyo 33" R/T, Optima red top To put on: Bora, XTP ims, URD Maf cal, AFE intake Wish list: EBC stage 5, full sized spare, Gerber folding shovel
    I thought you need OME shocks to run the OME trim packer? :notsure:
  16. Jun 19, 2014 at 9:39 AM
    #36
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    it might fit with the 5100s...and it might work out ok...
    I put a 10mm and 7mm in my OME shocks and it's held up for the last 6 months or so, although my ride is extra stiff.
  17. Jun 19, 2014 at 1:39 PM
    #37
    SmackGoneWild
    Aaron
    Kapolei, HI
    14 LB TRD
    workin' on it.
    I just copy/pasted the first quote we were working with, dumped the trim packers. For the sake of convenience, I am also going to buy my own jack + stands, simply because I hate going on post to do anything, so theres a new hunt for tools.
  18. Jun 19, 2014 at 5:21 PM
    #38
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    what was the price? can pm me if need to..im still looking for my lift
  19. Jun 19, 2014 at 5:41 PM
    #39
    TRDeeznutz
    Kaleo
    Kapolei, HI
    I got my 5100s for $377.
  20. Jun 19, 2014 at 7:42 PM
    #40
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    front and rear? im debating to go another route for the rear besides the billies, not sure what brand yet tho, or if anything compares price/performance wise
