Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Sep 2, 2015 at 11:58 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Yeah...WTF!!!
  2. Sep 3, 2015 at 12:00 AM
    BotoSlap808
    BotoSlap808 JAHblessed
    Kaneohe,HI
    2015 sport DCSB
    Lol that's how real moke action locals give direction? But someone here should be able to break it down for you
  3. Sep 3, 2015 at 12:00 AM
    tx novice
    Ron
    OAHU
    Don't worry. Unko Kimo is old and no can see good. His spear goin miss. Garans bah :rofl:
  4. Sep 3, 2015 at 12:08 AM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    Das why he get tita rita for help him aim
  5. Sep 3, 2015 at 12:28 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Da mango tree wen get cut by the hanapa'a cru. Get one small rock where it was
  6. Sep 3, 2015 at 1:10 AM
    polekasta
    polekasta Well-Known Member
    Wahiawa, Oahu, Hawaii
    06 4x4 long bed
    add a leaf, Bilstein 5100's
    What happen if da manapua man no stay? :rofl:
  7. Sep 3, 2015 at 1:15 AM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    den look fo da green mailbox with the little bit left lean. easy to spot. just look fo da shopping cart das missing the 2 right tiyahz buleh. you get um.
  8. Sep 3, 2015 at 1:17 AM
    polekasta
    06 4x4 long bed
    :rofl::rofl::rofl:
  9. Sep 3, 2015 at 1:18 AM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2024 Tacoma OR, 2024 4Runner OR
    I can tell I have a lot to learn.
  10. Sep 3, 2015 at 2:19 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    For the shackle flip,
    Get ready for some swear words....
    I may not have had the best tools, but idk any good way to get those f'n rivets out. Blood pressure is climbing just thinking of them. Tried drilling them, then using a punch and hammer, tried grinding an X into the head and chiseling off the head and then pound through, also tried grinding the while head off... I found no easy way to do it.
    Also there isn't much space to work with down there.
    -Drop the spare, you'll need to do it for the rear lines anyway.
    -Watch the back swing on the hammer, or you may contact the fender.
    -I used an angle grinder and cut the stock shackle mount off to get more room to access the rivets
    -IDK what springs you plan on using, but try to measure the spacing before bolting it all up. shackle should be at 45 degrees at ride height
    *for the stock or stock length shackle, make sure to use the two rearward mounting locations. you cannot use the front, it will swing back into the bracket, you will swear, and have to take it all apart and move the frame mount points so you can use the rear mounts for the shackle. Ask me how I know all this...
    Must have tools are a strong drill, bits, punch, 3lb deadblow, dremel to enlarge holes that don't line up, spray paint/ sandpaper/grinder (frame will be rusty under mount)
    Good luck.
  11. Sep 3, 2015 at 2:23 AM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
  12. Sep 3, 2015 at 2:47 AM
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
    Thanks for the insight! I think I'm going try and take the bed off. Hopefully that'll help.
  13. Sep 3, 2015 at 3:05 AM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    That's a good idea. I was by myself, so it wasn't even an option.
  14. Sep 3, 2015 at 3:50 AM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    damn i think i found one of my old toys....
    only way i can really tell is i plasti dipped the grill black, and the 5star wheels
  15. Sep 3, 2015 at 3:20 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    More flooding. lol
  16. Sep 3, 2015 at 3:34 PM
    polekasta
    06 4x4 long bed
  17. Sep 3, 2015 at 3:35 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    awesome!
  18. Sep 3, 2015 at 3:45 PM
    RedLantern
    RedLantern Well-Known Member
    Honolulu, Hi
    2019 TRD Pro Tacoma - Voodoo Blue / 06 double cab PreRunner Turbocharged (sold)
    Holy crap lol
  19. Sep 3, 2015 at 3:46 PM
    cubiclesurfer
    Kailua-Kona, HI
    i wanna take my sup over there so i can be on the news. hahahaha
    i'll probably need a gasoline shower shortly after though.
  20. Sep 3, 2015 at 4:13 PM
    Miyagi
    Miyagi Well-Known Member
    Seattle, WA
    2024 Windchill Pearl Land Cruiser 250 Prem.
    Greenlane Sliders + Leveling Kit, Rotiform STL, Falken Wildpeak AT4W
    @rka You passed me on Kalanianaole headed westbound. Nice truck brother! I also seen your truck at Sports Authority a while back, sorry if I was pointing and gawking :thumbsup:.
