Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Sep 22, 2015 at 12:13 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Wait isnt your truck new an stock? Did the 1 trip up the mountain hurt that much?
  2. Sep 22, 2015 at 12:14 PM
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    American tire in Kapolei
    cubiclesurfer likes this.
  3. Sep 22, 2015 at 12:20 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    I have OME setup and I have to have a current alinement sheet for recon. Additionally my steering wheel is a little off center so I wanted to correct that too.
    Thanks, I will set up an appointment.
  4. Sep 22, 2015 at 12:21 PM
    hacklerjason
    Ewa Beach, HI
    That's where I set up the other guys at after they did their ucas
  5. Sep 22, 2015 at 12:39 PM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Since your airport side better to try the american tire in mapunapuna.
  6. Sep 22, 2015 at 12:44 PM
    hacklerjason
    Ewa Beach, HI
    I don't have any people there so if he get recon idk how they would handle that... I go to Kapolei because I have a kid that used to go to preschool with one of the big players kids over in campbell... Plus I get favorable pricing over there but alignments aren't included... However they are super cool to me in that they make me paper that pass recon separate from the actual spec sheet
  7. Sep 22, 2015 at 1:42 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    I live just south of the statium if that helps with a place.
  8. Sep 22, 2015 at 1:50 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Your close to Scotty's and Island Brake and Alignment.
  9. Sep 22, 2015 at 1:52 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    Good places to check out?
  10. Sep 22, 2015 at 1:53 PM
    hacklerjason
    Ewa Beach, HI
    Island brake and alignment is really good from what I heat, no personal experience because when I did try the were so booked I didn't want to wait... Fwiw that should be a good thing
  11. Sep 22, 2015 at 2:16 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    Well I got an appointment with island today at 3.
  12. Sep 22, 2015 at 2:23 PM
    deeezy
    Dana
    Hawaii
    I've been to both places and they were good.
  13. Sep 22, 2015 at 2:40 PM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Wat did u guys used to remove the old safety check stickers from your bumpers?
  14. Sep 22, 2015 at 2:44 PM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    Island had no problem aligning me for recon with a new lift and stock UCA's.
  15. Sep 22, 2015 at 2:44 PM
    hacklerjason
    Ewa Beach, HI
    I have a lube for taking the white "void" marks left behind... What you do is use a plastic card to get a corner started then peel it off... Then used something oily/solventy to take it off but no harsh solvent that would attack paint... I used john Deere multi purpose spray lube TY6350 and it'll wipe the leftover shit off with minimal effort... I imagine anything with naphthalene or random spray lubes will suffice... Lmk if you need some... You can come by the shop and I'll give you some
  16. Sep 22, 2015 at 2:56 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Doesn't click. Gotta press and hold, which is weird for a switch to just do that.
  17. Sep 22, 2015 at 2:58 PM
    adio
    HI
    Ones you take off the sticker, you can always use Goo Gone to take off the residue that's left behind. Wash the spot after.
  18. Sep 22, 2015 at 3:26 PM
    cubiclesurfer
    Kailua-Kona, HI
    dumb question: where's a good place to take my front spring/shock assembly to get disassembled so I can put in extended top plate studs? I'm thinking about running OME's 10mm enhancer kit on my 885's cause I think 887's would put me really nose-high, and I don't have any weight to justify running 886's.
  19. Sep 22, 2015 at 3:33 PM
    hacklerjason
    Ewa Beach, HI
    Bring them to me
  20. Sep 22, 2015 at 5:02 PM
    kumz
    kumz Well-Known Member
    Good looking rig. Seen you the other day on Kapolei parkway. I was in the white 4 door
