Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Nov 11, 2015 at 7:25 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    That looks NICE!!! As long as you think that would be strong enough to handle any mall parking lot curb....or occasional rock, works for me :thumbsup::rofl:
  2. Nov 11, 2015 at 7:30 PM
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    We could stick them to the truck then run beads around four sides if you want it stuck stuck.... IMO, I would like them on good enough for protection, but weak enough to give if something got a good hold on them... If I run beads around each side of all the legs, and somethings grabs them, only a few things would come from that and none very good.. A) grabs the bar, pulls and tweaks the frame B) breaks off at another point then all the welds gotta be ground off to prepare for another set or to remove them...
  3. Nov 11, 2015 at 7:40 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
  4. Nov 11, 2015 at 7:49 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    wow and to think i was gonna get just the manifold from ozboost as well. i was just going to source the other parts since they use cheap turbos n what not...lmk when/if you make a manifold, id be interested in purchasing one
    hacklerjason likes this.
  5. Nov 11, 2015 at 7:51 PM
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    i can make it on sat
    squint0241[QUOTED] likes this.
  6. Nov 11, 2015 at 9:12 PM
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    I would run the full bead. If you hit something it's not going to mess up the frame, but if you only use rosette welds with the idea that they will fail with a big hit, then hey are not going to protect the body like they are supposed to.
    My sliders are bolt on, but they are on my recon anyway. What the inspector told me is if it is something structural on the frame (cross member, suspension, ect.,.), or something that is intended for safety (bumpers, roll cage) then they will check it out. But if you build a bumper, then bolt it on they don't care. If you buy or build a bumper, and weld it on then they will probably want to look.
  7. Nov 11, 2015 at 9:20 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Thanks for the help/input
  8. Nov 11, 2015 at 9:32 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Good on you... one thing to "explain" nicely why the wait time. Purely another to be an ass... I recently refused to work with a new loan officer (at my local FCU) cause I wasn't getting a call back... been there a long time... had an account longer than I've had a paying job....
  9. Nov 11, 2015 at 9:35 PM
    raycie
    Oahu, HI
    In need of $$$
    Plus, if you actually will use them as sliders, you need them stong enough to hold up the truck.. even in my old (I can say that now) 2x, I've gone over a bolder that would have damaged the cab if it wasn't for strong sliders.
    hacklerjason and LogCabins like this.
  10. Nov 11, 2015 at 9:37 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    Yeah I was kinda already going into it with beads all the way around.....if I hit something hard enough to grab and bend the frame then more than likely would have done it with or without the sliders
  11. Nov 11, 2015 at 9:39 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
    But...I totally understand what Jason was saying, and before he said that I probably wouldn't have even thought of it possibly being a hazard in that way
  12. Nov 11, 2015 at 9:40 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
  13. Nov 11, 2015 at 9:43 PM
    LogCabins
    Robert
    Oahu
    99 SR5 3.4L 4WD
  14. Nov 11, 2015 at 9:54 PM
    raycie
    Oahu, HI
    In need of $$$
  15. Nov 11, 2015 at 9:55 PM
    polekasta
    polekasta Well-Known Member
    Wahiawa, Oahu, Hawaii
    06 4x4 long bed
    add a leaf, Bilstein 5100's
    I agree, to bad it isn't a DCLB :rolleyes:
  16. Nov 11, 2015 at 10:26 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  17. Nov 11, 2015 at 10:45 PM
    zboy
    zboy Well-Known Member
    Oahu808
    12 TRD OR
    Anyone Just got Engine light Codes P0031 & P0051 also that break pump noise
    when you first start the engine is not happing any more the truck has less then
    10,000 miles I was installing fog light switch (new one ) What do you guys think ?
    O2 sensor I did hear the Relay clicking when I was doing the switch also have the Anytime
    Fog light MOD any input on what to do will be great Thanks
  18. Nov 11, 2015 at 10:48 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Have you tried to unplug the fog light switch and start your engine?
  19. Nov 11, 2015 at 10:55 PM
    zboy
    Oahu808
    12 TRD OR
    Ya also took relay from horn changed it to fog relay still get light a have scangage
    The codes are Air mix & O2 sensor also check gas cap no go clear codes then back on
  20. Nov 11, 2015 at 11:22 PM
    bullaculla
    Da big big island!
