Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Dec 8, 2015 at 10:53 PM
    Chanc'um
    Chanc'um Well-Known Member
    Primo
    Primo.... Chanc'um
    None. Broke
    Das why you stay making your own parts bulleh... lol... nice..
  2. Dec 8, 2015 at 10:54 PM
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    But if it isn't covered you'll have to do the repairs yourself and pay them for diagnostics, or pay for the whole repair... Its not major but you'll get raped no matter which way if it isn't covered... Can always call and ask
  3. Dec 8, 2015 at 10:55 PM
    hacklerjason
    Ewa Beach, HI
    Oh I don't make my own parts, yet... I do a little fab as needed for my own use.. You know, only to solve problems hahaha but not on a commercial scale
  4. Dec 8, 2015 at 10:56 PM
    hacklerjason
    Ewa Beach, HI
    I do all my own wiring and have made entire harnesses for motor swaps...
  5. Dec 8, 2015 at 10:59 PM
    Chanc'um
    Primo
    Primo.... Chanc'um
    None. Broke
    I need one of those plate thingies for da fuse block and the other stuffs.. who knows how?
    hacklerjason likes this.
  6. Dec 8, 2015 at 11:00 PM
    hacklerjason
    Ewa Beach, HI
    What you mean?
    One of these?
  7. Dec 8, 2015 at 11:08 PM
    kumz
    kumz Well-Known Member
    brah jus go da kine bu and grab um at da place dat stay on top nimitz. da one dat get da boat stuffs, get planny fuse blok marine grade animo for trow on da truck. i wen wire mines one 2 shakes. can. if need help let me know cuz
    k3v11n, Marcs2012 and BotoSlap808 like this.
  8. Dec 8, 2015 at 11:28 PM
    Chanc'um
    Primo
    Primo.... Chanc'um
    None. Broke
    O.k. Kumz... I'll make my way to West Marine and see what they have.. if I have any questions, I will make sure and ask you.. lol
    .. what about da plate it mounts to?? Who makes that??
    kumz likes this.
  9. Dec 8, 2015 at 11:45 PM
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    I hear Mike used to make. @luka
  10. Dec 8, 2015 at 11:57 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
  11. Dec 9, 2015 at 1:00 AM
    artesho
    artesho Well-Known Member
    Randy
    Chalan Pago. Oh yeah that closed a while ago but I remember checking it out. Oahu is my second home now and I'm stoked to be back in a toyota. Had a 99 4runner back in college then had 2 acura's. Missed the truck scene so now I'm back, just waiting for the delivery of my TRDOR :bananadance:
  12. Dec 9, 2015 at 9:17 AM
    kumz
    pelfreybilt makes a nice one. thats the one i got...big sale in a few days:bananadance:
  13. Dec 9, 2015 at 10:35 AM
    youngbuckcody
    youngbuckcody Well-Known Member
    Cody
    Mililani, HI
    12 Pryite Mica TRD Sport DC 4x4
    Goin try call em today hopefully under warranty . Power train I still under.
  14. Dec 9, 2015 at 1:53 PM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I haven't done this since Maui OR took care of me, but you need to mark the nut before you remove the pinion, and tighten just past your mark when you install the new seal. There is a crush sleeve on the pinion and will adjust the pinion depth/ gear mesh if tightened too far.
    xmods likes this.
  15. Dec 9, 2015 at 1:56 PM
    hacklerjason
    Ewa Beach, HI
    No the shim stack changes the pinion backlash... I gave him a FSM with Toyota Procedures, Tools, and Specifications... He should be ok its an easy job with the tools
  16. Dec 9, 2015 at 2:33 PM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Ok. Is it for the bearing pre load?
  17. Dec 9, 2015 at 3:18 PM
    hacklerjason
    Ewa Beach, HI
    Sort of... The torque you put in the nut changes the preload, the stack of shims on the pinion side of the bearings changes the gear mesh... You rub bluing compound to the meshing faces of the ring gear, then set the preload, then inspect the ring and pinion blued areas to check the mesh... You want the mesh to leave a witness mark dead center of the teeth... If its too far in or out, tear the pinion side down again and readjust the shim stack and repeat... It's mind of tedious to get it perfect, but your rear will thank you for it in the long run
  18. Dec 9, 2015 at 4:00 PM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    sounds like black magic to me. I was just told to mark pinion nut it to replace seal if the crush sleeve wasn't being replaced as well.
  19. Dec 9, 2015 at 4:09 PM
    hacklerjason
    Ewa Beach, HI
    That's shade tree... That's good enough if you're on the side of the road... If you in your garage and only want to do it that one time, do it per the manual which is the shit when you need to do a project... I can link you
  20. Dec 9, 2015 at 4:20 PM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Oh, no need for that. I just didn't see it in your post to replace the crush sleeve, just the pinion seal.
