Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Feb 6, 2016 at 1:19 PM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    Mine next?
  2. Feb 6, 2016 at 1:27 PM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    So my icon 700 lb springs came in, how much thread do you 700 lb spring guys run? right now with my i got 1.75 drivers side, 1.5 passenger side with the 650 lb springs and I still got toyota lean. How much you think I should put them at? I got steel bumper, steel ifs and steel midskid. Adding winch later on.
  3. Feb 6, 2016 at 1:53 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Make sure your "taco lean" isn't your fender support bushing being bad on the driver's side. If the bushing is bad it compresses way more than the passenger side and makes it look like your truck is leaning when it's just your cab that's leaning. I changed mine and it brought my truck back to normal.
  4. Feb 6, 2016 at 1:59 PM
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    what's it look like? are they the body mounts by the radiator?
  5. Feb 6, 2016 at 2:17 PM
    deeezy
    Dana
    Hawaii
    These are Energy Suspension bushings:
    The new bushings brought my driver's side fender up close to 3/8". I bet a lot of people that think they have taco lean actually just have to replace their bushings. Because the stock bushing is smashed down, it throws your hub to fender measurement off. The driver's side bushing compresses because of the extra weight on that side.
    EODTRD, Vigo and Upsblaine like this.
  6. Feb 6, 2016 at 2:22 PM
    youngbuckcody
    youngbuckcody Well-Known Member
    Cody
    Mililani, HI
    12 Pryite Mica TRD Sport DC 4x4
    Wats up guys get one questions about tpms. My friend he swapped his stocks with sr5 4Runner rims and da light stay on. Is the runner rims not interchangeable with our tacos ?
  7. Feb 6, 2016 at 2:26 PM
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    sensors are in the valves i think. you gotta takem out
  8. Feb 6, 2016 at 2:30 PM
    hacklerjason
    hacklerjason hACKman's Customs
    Ewa Beach, HI
    2016 Chevy Colorado Duramax Turbo Diesel
    BajaKits UCA King 2.5 Extended Travel Remote Reservoir, Compression Adjustable (Front) King 2.5 Piggyback Reservoir, Compression Adjustable (Rear) American Racing AR910, Gloss Black PC
    You have to replace the sensors... The sr5 sensors were calibrated to the tpms ecu... If you swap wheels you have to either pull the old sensors from the wheels and swap them into the new wheels.. If the old wheels were stamped steel and the new wheels are alloy, then you'll need either new sensors or a sensor bomb to defeat the light... If they are both alloy then sensor swap should work great... If the new wheels have sensors in them already, then you'll need to have them calibrated into the tpms ecu.. The way you can tell is by looking at the valve stem... If its metal with a nut holding it to the wheel, its a tpms sensor... If its the rubber type we've all seen in the past, then its non tpms
  9. Feb 6, 2016 at 2:47 PM
    deeezy
    Dana
    Hawaii
    @jimbo808 You can measure from your frame to fender support and compare the drivers and passenger's side. You'll still have to compensate by cranking the driver's side coilover some, but maybe not as much. I haven't been using hub to fender measurements to level my truck, I've been measuring from each side frame to ground.
  10. Feb 6, 2016 at 2:51 PM
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    yup just measured, drivers side 1/16ths shorter
  11. Feb 6, 2016 at 2:56 PM
    deeezy
    Dana
    Hawaii
    That really isn't bad. And your 650's cranked down that much isn't that bad either, it's just that those 650's are 13" springs, an inch shorter than other coilover brands so they look like they are preloaded more than other coilovers that come with 14" springs.
  12. Feb 6, 2016 at 3:20 PM
    youngbuckcody
    Cody
    Mililani, HI
    You heading back work killa? Think I just saw u @hacklerjason
    hacklerjason likes this.
  13. Feb 6, 2016 at 3:46 PM
    hacklerjason
    Ewa Beach, HI
    Where at? I just got home from kapolei
  14. Feb 6, 2016 at 3:50 PM
    youngbuckcody
    Cody
    Mililani, HI
    Passed u right before the high school u was coming from like chilis side
  15. Feb 6, 2016 at 3:52 PM
    hacklerjason
    Ewa Beach, HI
    Yup that was me... I was coming from GameStop to grab a giftcard for a nephews birthday
  16. Feb 6, 2016 at 4:07 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    I ended up getting Duratracs
  17. Feb 6, 2016 at 4:19 PM
    deeezy
    Dana
    Hawaii
    How long are you guys going to be there working on you truck?
  18. Feb 6, 2016 at 4:28 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    I might come up to
  19. Feb 6, 2016 at 5:30 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    yup! had fog so bad tonight, everything was shut down. it would have been perfect for my truck :cool:
  20. Feb 6, 2016 at 6:33 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2025 TRD Pro
    Come on up!
