Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Mar 3, 2016 at 11:08 PM
    maarkymaark
    maarkymaark Well-Known Member
    Mark
    Oahu, Hawaii
    2013 4x4 DCLB
    debadged, LEDs all around, 5% tint all around, TRD Air Filter, all around Bilsteins 5100s, 885s coils, 2" AAL, LR UCA
    I'm one step ahead of you. Gonna order some power stop rotors and pads from Amazon! Gonna install everything one time. I just hope it will be the last time taking it apart
  2. Mar 4, 2016 at 3:21 AM
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    If it gets louder during long windy turns left or right then it's probably the wheel bearing...I've been through a few of them. Don't ask me how much...my passenger side one is currently bad.
    maarkymaark[QUOTED] likes this.
  3. Mar 4, 2016 at 7:57 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    so made up my mind on the glock 19, and 26. the other half wants a sig 226 lol she gonna have to wait for that one tho $$$$ lol
    xmods and D.Mathys like this.
  4. Mar 4, 2016 at 8:18 PM
    hirod
    hirod Well-Known Member
    hawaii
    16 double cab short bed OR
    Glock 26 is a little snappy. Baby finger tends to hang off the frame. Not an unpleasant shooting gun but outside of concealed carry, no significant benefits over a 17.
    226 is opposite end of the spectrum. A little large because the decocker adds some thickness to the grip. Won't be much of an issue if your guys hands are on the larger size. Stainless finish isn't so corrosion resistant.
    I'm a glock guy. Glocks only need one tool (glock tool with front sight driver and punch) to disassemble completely. Every part can be replaced without having to send to the factory (unlike 226). Lots of options with the 17. Look up "lone wolf". I think a 17 and 19 would be a good initial investment. Also, gun show coming up end of this month i think. Maybe good deals there.
  5. Mar 4, 2016 at 8:21 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I got me a glock 22 nice shooting gun just bought it for home defense
  6. Mar 4, 2016 at 8:32 PM
    hirod
    hawaii
    :thumbsup:
  7. Mar 4, 2016 at 8:34 PM
    artesho
    artesho Well-Known Member
    Randy
    Never owned a glock myself, but I've shot a few. Definitely can't go wrong with them. Personally I have a couple sigs and HKs. They have never failed me. ever
  8. Mar 4, 2016 at 8:37 PM
    jimbo808
    Kapolei, Hawaii
    05 TRD Sport 4x4
    I'm more of a 1911, ak guy. Though i got a cz which i like a lot too lol. Anyone down for Kaena pt tonight? going to test out the new tires
  9. Mar 4, 2016 at 8:56 PM
    hirod
    hawaii
    I got small hands so the older sigs and hks never got me. I did like the p30L and the hk45 though. But i had already invested a bunch in glocks so couldn't get myself to switch. Btw, glock mags are some of the cheapest factory mags. One reason i did not pick up an m&p 9.
    2ahawaii is a good local shooting resource.
  10. Mar 4, 2016 at 9:14 PM
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    i was up in the air with the 26, mp shield, and the glock 43. im set on the 26 cause may as well when i can swap mags, none are instock atm so i still have some time to get a 17 instead lol
  11. Mar 4, 2016 at 9:24 PM
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    Hmm, it could be the wheel bearing, or the diff bushing like Bullaculla said. But it's hard to say. If it was the wheel bearing you should notice it at almost all speeds.
    If the tires are to blame, that would explain it. You can rotate the tires side to side and see if that changes when you hear the noise, or how it sounds?
    I know that isn't really helpful, but it would suck to replace the bearing (takes $$$ or hard work to replace) and then have it not fix the problem.
    One thing that is hard to tell without dropping it, is either driveshaft. How many miles do you have? If the u-joints are worn out that will give you vibrations at different speeds.
    The brakes are a mystery. Once a rotor warps, that's pretty much it. You can resurface it, but that won't last because you are cutting it back straight. So the internal structure is still warped and it will warp again even worse.
    At Orielly's they wouldn't resurface if you had more than 0.005" runout because it will just warp again.
  12. Mar 5, 2016 at 12:12 AM
    maarkymaark
    Mark
    Oahu, Hawaii
    2013 4x4 DCLB
    I'm at 42k miles on my truck. I tired on and off with the 4wd drive still sounds the same, so I can kinda check off the needle bearing for shaft. But I'm really leaning on the wheel bearing. Today I noticed when I was making like a oval turn, it made different noises from left and right. I could feel like it's the bearings.... But gonna try some stock tires tomorrow and see if the noises are still there.
    My brakes on the other had. It's been cut already from my first warped rotors. So I'll have to buy some new rotors anyways
    xmods[QUOTED] likes this.
  13. Mar 5, 2016 at 12:23 AM
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Truck and Jeep Fest at Blaisdell Center this weekend. Anybody been to it before? Curious what kind of vendors/parts they might have
  14. Mar 5, 2016 at 1:52 AM
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    Twisted sisters :crazy::cheers::crazy:
    We showed up before the staff or setup crew lol
    Been all 6 years... lol
    A lot of vendors, BFG, ProComp, Fox, WeatehrTech, Bedrug, Smittybilt, Mickey Thompson, Method, ARB, Dick Cepek, Bak flip, Rigid, KC, Lund, Warn, Maxxis, and a bunch of others I can't remember right now. Its a cool place to take pictures of trucks, and check out if there are any deals. But ask at the register for a price, sometimes the reps try and make retail if they can. The Bak rep told me retail $850 two years ago, the guy at the register hooked me up with a cover for $680, waved the shipping charge too. Cheaper than Amazon even after Taxes...
    Inside word is SMittyBilt winches will be cheaper than ever.. Even cheaper than Amazon. They gave us a price but can't say until tomorrow.. I'll say if I was looking for a winch the SmittyBilt with the syn rope would be sweet at the price they are asking..
    And despite what @bullaculla may tell you, I'm not a rep for 4wp in any way shape or form :rofl:
  15. Mar 5, 2016 at 1:58 AM
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    Too long to list :D
    I wouldn't write off the ujoints completely.. I know the Tacoma has the front diff disconnect but I'm pretty sure the front driveshaft still spins in 2wd, just not under power. so when the front wheels roll, they in turn spin the shaft even though it isn't engaged in the transfercase. So any vibrations from the ujoints would be the same in 2 or 4.
  16. Mar 5, 2016 at 5:48 AM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Whats the blue , shiney thing on your truck Miles :eek:o_O:boink::thumbsup:
  17. Mar 5, 2016 at 8:13 AM
    polekasta
    polekasta Well-Known Member
    Wahiawa, Oahu, Hawaii
    06 4x4 long bed
    add a leaf, Bilstein 5100's
    Those aren't Kings, are they? :notsure:
  18. Mar 5, 2016 at 8:53 AM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    cubiclesurfer likes this.
  19. Mar 5, 2016 at 8:59 AM
    polekasta
    06 4x4 long bed
    :bowdown:
  20. Mar 5, 2016 at 9:52 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Hi Mr. 4WP! :p
    I thought the King resi would mount horizonatally?! That's how I have always seen them. Yours is setup like Ricks ICON. Kind of a pain when its time to grease UCA bushings.
    squint0241 and xmods[QUOTED] like this.
