Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. May 22, 2016 at 9:47 AM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Its all preference. I havent done it yet but i like the gas cap area.
    seoulja99[QUOTED] likes this.
  2. May 22, 2016 at 10:34 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    It's been floating around in the back of the truck, I just never really got around to it. It's a little pointless, unless the whole axle is submerged. People made like the stock one is a one way valve, but it's not. Water can and still will enter through axle seals in some peoples cases. I guess it just helps if the location is higher so the vacuum created by cooling can pull in air easier than water through the axle seals. I ended up mounting mine in the bed cubby since I have bed cover.
    And pre runners dint have a front differential, but the 4wd diff breather is mounted higher up, so most people leave it.
    seoulja99 likes this.
  3. May 22, 2016 at 12:16 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Mine was a spring loaded one way valve. Always blocked off if the diff is sucking and able to blow out if there;s enough pressure to push the spring.
  4. May 22, 2016 at 12:24 PM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    I was too lazy to drill a hole, so I went behind the driver side tail light.
  5. May 22, 2016 at 12:49 PM
    Vigo
    Vigo WFO
    '12 4 door
    stuff...
    Mine just had a hole with a silver cap that flopped around, and the new part with the barb didn't have a check valve, I could blow air either way through it. Drained and filed the rear diff with the lucas oil at the same time. No noticeable difference in sound for me, but there are so many other noises going on with the truck and its contents, it's hard to tell anyway.
    yours would also explain why some people get water sucked into their axles through the seals...
    I wonder if mine was defective?
  6. May 22, 2016 at 2:49 PM
    cubiclesurfer
    Kailua-Kona, HI
    well, I'm joining the tall/skinny tire club, with @luka and @xmods. just ordered (5) 255/85/16 Cooper ST Maxx :bananadance:
    I was kinda torn between the KM2's and ST Maxx for that size. I almost pulled the trigger on KM2's but I talked to Lex Brodies again, and I was able to convince the salesperson that the size does exist (previously, they claimed that the size doesn't exist - probably cause everyone wants 285/75/16 or they're stretching MT's on Fuel Hostages, lol). the reason I went with the ST Maxx over the KM2 is cause the ST Maxx isn't a full MT (which would've been kinda impractical for my daily driver, imo), and it's a little wider/slightly shorter than the KM2. in case anyone is interested, here's the numbers for the 255/85/16 ST Maxx and KM2 that I found online, based on 7" wide rims:
    ST Maxx -
    height = 32.8"
    width = 10.2"
    tread width = 8.15"
    weight = 58lbs (load range E)
    BFG KM2 -
    height = 33.3"
    width = 10"
    tread width = 7.4"
    weight = 55lbs (load range E)
    xmods, kumz, GrisMunkyNinja and 2 others like this.
  7. May 22, 2016 at 5:07 PM
    deeezy
    Dana
    Hawaii
    Maybe yours was defective. If mine was like that, I would have reused it and just relocated it higher.
    Vigo[QUOTED] likes this.
  8. May 22, 2016 at 9:49 PM
    senojeelnodnarb
    senojeelnodnarb Well-Known Member
    Brandon
    Oahu, HI /Canton, NC
    2013 Tacoma DCSB 4x4 TRD OR, 6-Spd Manual
    Fully De-Badged, Mossy Oak seat covers, Fog Light anytime mod, Custom Bed Light Bar, flowmaster 40 series, Plasti-Dipped Grille, Painted Stock TRD Rims, Custom Plate Bumper, High-Lift Bed Mount, Ballacula Trailer Plug Relocate, Rear Seat Dog Platform, sunglasses holder Switch panel, 2" lift, 285/75/R16 Mickey Thompson Baja MTZ, custom sliders, + a shit load more,
    I miss you guys we should hang out more. I only see Mike and Ron. (One of those is forced) :)
    Vigo likes this.
  9. May 22, 2016 at 9:58 PM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    How u been brandon? Heard u got into a bad motorcycle accident?
  10. May 22, 2016 at 10:00 PM
    senojeelnodnarb
    Brandon
    Yeah I'm walking now. Shoulder blade and deltoid doesn't work. Think it might be the nerves. Thanks for asking
  11. May 22, 2016 at 10:04 PM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Glad youre ok...sort of. Yeah phil told me.
  12. May 23, 2016 at 12:26 AM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    Can...your dodge is 4x4 :thumbsup::mudding:just dont get stuck..:ballchain::rofl:
    Vigo likes this.
  13. May 23, 2016 at 1:00 AM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    I've been debating going this tire size and selling my 265s
    cubiclesurfer[QUOTED] likes this.
  14. May 23, 2016 at 8:18 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    :cookiemonster:
  15. May 23, 2016 at 3:31 PM
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    Hey guys I just found out I'm gunna be moving to big island for a month anyone know anyone that might have a place to stay that's affordable?
  16. May 23, 2016 at 3:38 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
  17. May 23, 2016 at 3:43 PM
    EODTRD
    EODTRD Brick horder
    Dave
    Spartanburg, SC
    2024 Tacoma OR, 2024 4Runner OR
    @cubiclesurfer he might have an idea.
    cubiclesurfer likes this.
  18. May 23, 2016 at 3:46 PM
    cubiclesurfer
    Kailua-Kona, HI
    what side? that should be an easy way to narrow down what's "affordable". I don't know anyone off the top of my head, but I can ask around. only 1 month though?
  19. May 23, 2016 at 5:17 PM
    WailuaTaco808
    Phil
    Hawaiian Islands
    Oh boy...
    I'll be in Kona. Working at the airport. Mokulele is sending me there on Tuesday so I might check out a hostle. What ever happen to konaborn he ever move back B.I.
  20. May 24, 2016 at 1:39 AM
    cubiclesurfer
    Kailua-Kona, HI
    not yet. I think he just graduated after what sounded like a pretty brutal final year. Iʻll ask around this side. you bringing your truck, or no?
