Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Apr 25, 2017 at 2:17 PM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    anyone?? I asked Sarah to give my contact info to the person(s) receiving stuff on that pallet. I wanna order that TJM Awning, and shipping on the pallet is $30 vs $130 if I have it shipped straight to me via UPS. $190 is a pretty good deal, I hope :cookiemonster:
  2. Apr 25, 2017 at 3:26 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    No, but you can try on my 285/75/16 MTRs on 16" konig countersteers. 4.5" BS 0 offset.
    Pretty close.
    They are still off the truck :rofl:
  3. Apr 25, 2017 at 3:43 PM
    artesho
    artesho Well-Known Member
    Randy
    Thanks for the offer! You clever mister, gif insert. Is that all linked up? Super awesome articulation of that straight axle
  4. Apr 25, 2017 at 3:52 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Sure you don't want to stack a spacer lift on top of your coilovers? Totally safe and will give you mad lift:militarypress:.
  5. Apr 25, 2017 at 4:02 PM
    artesho
    Randy
    Asking for a friend: can you do a 6" bracket lift and long travel?! Hahahha
  6. Apr 25, 2017 at 4:04 PM
    bullaculla
    Da big big island!
    Shieeet... it's already gonna be way too high :(
    artesho likes this.
  7. Apr 25, 2017 at 4:10 PM
    bullaculla
    Da big big island!
    No problem, but actually, I just wanted to get you over here so I can check out the LT :spy:
  8. Apr 25, 2017 at 5:07 PM
    cubiclesurfer
    Kailua-Kona, HI
    can, as long as you put the 3" body lift for "clearance". lol
    hacklerjason likes this.
  9. Apr 25, 2017 at 5:31 PM
    89hatcher
    89hatcher Well-Known Member
    lol I actually seen a picture on TW with bracket lift and Long travel kit installed and it had Hawaii plates
  10. Apr 25, 2017 at 5:54 PM
    Bob1sh
    Bob1sh Well-Known Member
    Zac
    2017 DCSB 4x4
    Hey guys looking at picking up a set of SCS 17x9 3.5 BS for my 3rd gen. I want to put 255/80/17s on them, why issues will I run into do you think?
  11. Apr 25, 2017 at 6:01 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Inner fender rub. You'll have to cut some fender flare back and just heat gun the liner back. Should clear.
    Bob1sh likes this.
  12. Apr 25, 2017 at 6:02 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    Have mercy.
  13. Apr 25, 2017 at 6:07 PM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    This would be so sick if the pics were you laying on the floor bench pressing the axle to full stuff, to flex, to full droop :rofl:
    artesho and squint0241 like this.
  14. Apr 25, 2017 at 6:09 PM
    cubiclesurfer
    Kailua-Kona, HI
    can you run that size tires on a 9" wide rim? sounds borderline.
    Bob1sh[QUOTED] likes this.
  15. Apr 25, 2017 at 6:29 PM
    Bob1sh
    Zac
    2017 DCSB 4x4
    That was my real concern, the function of tire
  16. Apr 25, 2017 at 7:16 PM
    deeezy
    Dana
    Hawaii
    Well, you're going beyond the max rim width. That's worse than going the other way and fitting a wide tire on a narrow wheel. I think it'll be more prone to losing a bead when wheeling. Going the other way, with a wide tire on a narrow wheel, I think it actually will hold a bead better than normal.
  17. Apr 25, 2017 at 7:21 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    It's a -38mm offset SCS F5 as well. Anyone here running anything that aggressive?
  18. Apr 25, 2017 at 7:28 PM
    deeezy
    Dana
    Hawaii
    Your tire will probably hit your firewall/pinchweld and cab mount with that backspacing/width. You might as well run 285's if you clearance all of that.
  19. Apr 25, 2017 at 7:30 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    285 would just pull that fender flare right off haha. Do it!
  20. Apr 25, 2017 at 7:33 PM
    deeezy
    Dana
    Hawaii
    The 255's are a larger diameter than a 285 and he's moving that large diameter out to where a 285 on normal bs (4.5) would be. So prob same rubbage as 285's on 4.5 bs, maybe worse.
