Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Nov 26, 2018 at 9:06 AM
    jimbro
    jimbro Well-Known Member
    Jim
    Manoa, Hawaii
    2018 Magnetic Grey DCSB TRD OR
    Damn if you had the double bed rack setup i would be all over this!
    El Duderino likes this.
  2. Nov 26, 2018 at 10:11 AM
    El Duderino
    El Duderino Yeah,well, that's just, like, your opinion, man.
    Jeremy
    Kahalu'u Oahu
    16 MGM Sport 4x4 DCSB & 19 nautical blue SR5 premium 4x4
    Pelfrybilt sliders and skids. Pro grille insert,T4R Pro Wheels
    @kakwvu just informed the Hulu is .99¢ a month for a year if you sign up today
    rogerman and seoulja99 like this.
  3. Nov 27, 2018 at 9:39 PM
    gotblika
    gotblika Well-Known Member
    jimbro likes this.
  4. Nov 28, 2018 at 9:50 PM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    Price lower on my Thule racks here for 350
    seoulja99 likes this.
  5. Nov 29, 2018 at 10:48 AM
    kalaukoa
    kalaukoa Well-Known Member
    Kailua
    2011 TRD OR 4x4 Access Cab
    Anyone got some reccomendations for tint shops? Looking to get the windows tinted on my 2011 AC. Tanks eh!
  6. Nov 29, 2018 at 10:59 AM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    Prestige tinting in Kaneohe did my 4Runner excellent job. Pay cash he knocks the price down a bit.
    Vanguard, 05Taco4x4 and kalaukoa like this.
  7. Nov 29, 2018 at 6:57 PM
    rogerman
    rogerman Well-Known Member
    Roger
    Honolulu
    2000 Tacoma SR5 V6 4wd 5speed
  8. Nov 29, 2018 at 9:05 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    if you like skinny 31's
  9. Dec 3, 2018 at 4:25 PM
    kalaukoa
    Kailua
    Got new wheels and tires. Stoked on the tires and look. I am getting some minor rubbing full lock. They are rubbing on the mud flaps and the shroud on the inside of the wheel well. I have 1.25” spacers and tires are 265/70r17. Any thoughts? Are the spacers causing the rubbing? Was thinking about using a heat gun to manipulate the plastic.New Shoes.jpg Rim and Tire.jpg
  10. Dec 3, 2018 at 4:31 PM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    Racks and kayak are sold just to update
  11. Dec 3, 2018 at 4:34 PM
    luka
    Kailua, HI
    could be your alignment, wheel offset, and/or lift.
    the front flaps do stick into the wheel well a noticable amount
  12. Dec 3, 2018 at 4:34 PM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    Could be alignment being off.
  13. Dec 3, 2018 at 4:37 PM
    luka
    Kailua, HI
    too slow :wave:
    :anonymous:
  14. Dec 3, 2018 at 4:38 PM
    kalaukoa
    Kailua
    I just had an alignment done a couple of months back after I put the lift on and it was all in spec. I havnt done anything with the suspension since the alignment. It drives straight (no pulling). Could my alignment gone out of whack in a couple of months time?
  15. Dec 3, 2018 at 4:38 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    Morgantown, WV
    2016 OR 4X4 6MT BBP
    He's right, @kalaukoa .. front flaps need to come off (not a recon or safety item, so no worries). You should be fine after an alignment, or its the offset with the spacers and you can try using some heat and love to push in the part of your liner that is getting rubbed.
  16. Dec 3, 2018 at 4:40 PM
    kakwvu
    Kyle
    Morgantown, WV
    2016 OR 4X4 6MT BBP
    You were in spec with different tires and weren't rubbing, so they likely just stopped because it was all cherry. If you kept the same tire size, it may just be that you're diameter is a hair larger and enough to rub now.
  17. Dec 3, 2018 at 4:44 PM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    You got me lol
  18. Dec 3, 2018 at 4:47 PM
    luka
    Kailua, HI
    if you changed tire sizes and rim offset, sometimes you have to change your alignment to an "out-of-stock" setting to maintain the stock drive-ability.
  19. Dec 3, 2018 at 4:47 PM
    kalaukoa
    Kailua
    Could it be the spacers? The new rims are 17" vs the 16" that was on there previously. Also went up one size tire.
    tx novice likes this.
  20. Dec 3, 2018 at 4:49 PM
    El Duderino
    Jeremy
    Kahalu'u Oahu
    Yea you’re going to need an alignment. You’re in spec for what was on there before. At least that’s what I have been told.
