Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Mar 6, 2019 at 12:37 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Yeah, that document is from 1986. Don't think that applies anymore.
    inksin[QUOTED] and El Duderino like this.
  2. Mar 6, 2019 at 12:48 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    i asked the inspector for @Tuna tacos and they said if you change the stock height of your front or rear bumpers from stock, safety shouldn’t be passing you. But some do they said it’s a crap shoot if you just do a small front spacer.
  3. Mar 6, 2019 at 1:00 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    Yeah, they should be measuring your bumper heights when inspecting and put it on your paperwork.
    El Duderino[QUOTED] likes this.
  4. Mar 6, 2019 at 1:03 PM
    El Duderino
    Jeremy
    HI->PNW
    They did
    kakwvu[QUOTED] likes this.
  5. Mar 6, 2019 at 1:04 PM
    kakwvu
    Kyle
    WV
    ‘24 JLURX
    They tell you that you had the second nicest third gen with ADS?
  6. Mar 6, 2019 at 1:29 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Understood and it's not a point I can really argue with anyone because I've had more than my share of recon vehicles and special interest vehicles (and was part of the process to amend recon for special interest vehicles) to understand that there is nothing that is clear and cut with the rules that are layed out for us. The judge and jury will be the safety check station.
    My only point is that as of today, on the official government website it says that it is passable if everything else is stock. The '86 document are the same rules they use to this day that everyone needs to abide by and yes, there have been updates although what you posted was a FAQ about recon and not official laws (which is all good with me cause I've never found the official amendments to the original documents either). Nothing says specifically that leveling kits aren't allowed in the updates, only that anything that lifts the vehicle frame would be the most common thing that you'd need recon for.
    Section G (suspension) paragraph 1, subsection B, also reinforces that anything that is added to the suspension to alter the height makes the vehicle subject to recon (which is corroborated by the updated info you posted) but paragraph 2 and 3 which I posted list those specific things (with those specific conditions being met) as being exempt from needing recon. My only point is that it's in writing on their own website.
    With all that being said, I wouldn't bet any money on getting a stock 4wd with just a leveling kit through safety without a recon but you do have ground to stand on if someone felt like arguing the issue to the inspector. You may still get denied too cause we all know that inspectors have the freedom to interpret the rules to what suits them best. A big tittie girl will get a pass on all kinds of stuff but an old white guy like me will get failed cause my TPMS light is on (true story). I'd still try safety without recon though to try it. If you don't pass then getting recon for only a front spacer lift would be easy peasy anyway
  7. Mar 6, 2019 at 1:32 PM
    inksin
    Hawaii
    Thing with that is that if you put bigger (or smaller) tires then your bumper height is changed already without touching the suspension
  8. Mar 6, 2019 at 2:32 PM
    Tuna tacos
    Tuna tacos Well-Known Member
    2018 Barcelona SR Double cab 4x4
    Thanks man! Good looking out!
  9. Mar 6, 2019 at 7:35 PM
    El Duderino
    Jeremy
    HI->PNW
    Yup I will never fully understand the logic of recon and safety check check list.
    inksin[QUOTED] likes this.
  10. Mar 7, 2019 at 2:44 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    also the exact process everyone uses for the bumper height may be different.
    inksin and El Duderino like this.
  11. Mar 8, 2019 at 7:33 PM
    El Duderino
    Jeremy
    HI->PNW
    This dudes rear shocks were just hanging. Must just be bouncing all day every day
    Grumpy and fett_taco like this.
  12. Mar 9, 2019 at 4:00 PM
    Jultepod
    Jultepod Well-Known Member
    Oahu, Hawaii
    2013 Gray Tacoma TRD
    K&N cold air, Exhaust, rims and tires, 3" king extended travel coilovers and total chaos UCAs, rear diff breather mod, CBI off-road ditch brackets with Cali raised LED pod lights and painless wiring harness, 4xinnovations rock sliders, cab mount chop.
    Anyone else think the 4wheelparts show this year was kinda a wash? I wasnt impressed. Also didnt see any good deals for really any tacoma studd. Seen EJ there but hes to good to talk to us now that he got that sweet business card on his truck jk
  13. Mar 9, 2019 at 4:06 PM
    El Duderino
    Jeremy
    HI->PNW
    Was going to go for a hi lift but changed my mind
  14. Mar 9, 2019 at 5:15 PM
    Hwntunda
    Hwntunda Member
    2013 White Tacoma Prerunner
    Does anyone know if the blow out section has more stuff added to it Sunday or is it the same exact as today?
  15. Mar 9, 2019 at 5:20 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    No pictures of trucks in the show :rofl:
  16. Mar 9, 2019 at 5:21 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    What ever they have today will be there tomorrow but before they finish by the end of the day they will lower the prices on Sunday. If it doesn’t sale they have a sale next week Saturday at the store.
    05Taco4x4 and seoulja99 like this.
  17. Mar 9, 2019 at 5:23 PM
    Hwntunda
    Hwntunda Member
    Thanks
  18. Mar 9, 2019 at 5:52 PM
    Chex808
    Chex808 Well-Known Member
    Hawaii
    2017 Super White DCSB
    favorite truck at the show
  19. Mar 9, 2019 at 5:53 PM
    El Duderino
    Jeremy
    HI->PNW
    That’s nice
  20. Mar 9, 2019 at 6:02 PM
    Chex808
    Hawaii
    Overall I have to agree the trucks at the show were kind of meh, lots of 6 inch painted parts zZzZz. The jeeps looked good. I did enjoy talking to a few people about the my king setup.
    El Duderino likes this.
