Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Sep 28, 2021 at 3:07 PM
    89hatcher
    89hatcher Well-Known Member
    What you guys think of the JBA high caster arms?
  2. Sep 28, 2021 at 10:42 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I have them and was perfect for my set up. The owner is super helpful, answered all my questions and even sends reminders to grease the zerks. For me the SPC had too many variables to adjust and set correctly, the JBA was bolt on with the castor built in, just align and good to go. More of a no brainer. If you are running 33's or bigger and you really need all the adjustment ranges the SPC provides, than that's for you. Hope that helps.
  3. Sep 30, 2021 at 8:44 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Well if you don't mind cutting your cab mounts than they are fine.
    If you add Caster you are essentially moving the tire rewards towards the cab mounts.
  4. Sep 30, 2021 at 8:47 PM
    toku58
    Mall Crawler!
    Set you SPC's to "F" or "G" setting and you should be good to go for 285's If you want 35" tires than more than likely you'll need to do the CMC and pinch weld.
    89hatcher likes this.
  5. Oct 1, 2021 at 12:56 AM
    HiFire
    HiFire Well-Known Member
    Eric
    Hawaii
    SR5,4x4,DCSB,Auto
    Weathertech mats, BAMF sliders, US Offroad front winch bumper, RCI Alum. Skid plates, ICON suspension, Pelfreybilt rear bumper, JBA uca's, Allpro u-bolt flip,
    I’ve been running JBA arms for 30k miles with 255/85-16 tires and they clear the cab mounts. Mine have the stock Toyota bushings and Chevy ball joints. No complaints.
    flash5twelve and hirod like this.
  6. Oct 1, 2021 at 8:32 AM
    toku58
    Mall Crawler!
    What do you have the SPC's set at?
  7. Oct 1, 2021 at 12:38 PM
    ShadowBoxDragon
    ShadowBoxDragon Well-Known Member
    @toku58 Mahalo for the info. I picked up a 1st gen so no cmc just pinch weld. Gonna run 255s max maybe 265/75 for less work, only lifting about 2" all around. Wanted SPCs for the adjustability if I like go bigger in the future.
    toku58 likes this.
  8. Oct 1, 2021 at 12:54 PM
    Trail_limo_pro
    Trail_limo_pro Well-Known Member
    Brian
    Oahu Hawaii
    E
  9. Oct 1, 2021 at 1:01 PM
    toku58
    Mall Crawler!
    That's what I'm currently set at and I get very minor rubbing when reversing and turning. My Caster is only set at 1.8. LCA cams are at neutral. (So plenty room to adjust more)
    I'm moving the SPC's to the "F" setting and having the guy set my Caster to 2.0 tomorrow, that should clear everything.
  10. Oct 4, 2021 at 11:52 AM
    TacoMesa
    TacoMesa Active Member
    2017 Metallic Grey Tacoma TRD Off Road
    Does anyone have a good mechanic in town they can recommend? I know this is a Toyota forum, but my 03 ranger needs some work done, and figured I'd see if anyone can refer me to someone legit. Mahalo
  11. Oct 4, 2021 at 12:35 PM
    808veedub
    808veedub Well-Known Member
    Brent
    Hawaii
    2016 4x4 tundra crewmax 2016 trd sport tacoma
    Kapahulu auto. Took my wife’s car there when we lived in town. Real good work and fair prices
    jaymay82 and TacoMesa[QUOTED] like this.
  12. Oct 12, 2021 at 10:19 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Check out James from Combs Performance.
    Edit: oh, dang. It’s been a while since I’ve been on here and didn’t even check the date of your post! My bad for the late reply. Hope you found something.
  13. Oct 12, 2021 at 10:30 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
  14. Oct 12, 2021 at 11:46 PM
    Bubble Wrap
    Bubble Wrap Well-Known Member
    Honolulu, HI
    2016 SR5 DCSB MGM
    https://www.yelp.com/biz/mobotech-auto-honolulu-2
  15. Oct 15, 2021 at 12:05 AM
    ryyryy808
    ryyryy808 Member
    2020 sr5 black tacoma
    Anybody recommend a good affordable shop or someone that could install rock lights? mahalos!
  16. Oct 21, 2021 at 11:09 PM
    RHED808
    RHED808 -Zeke
    Hawaii
    2018 TRD Pro MT
    RIGID DSS PRO KO2 265/75r16
    Does anyone know if Ka'ena point (Mokuleia) permits are able to be applied for. It said that there is applications for 2022 in fall, please correct me if I am wrong. It is fall right now?
    Very Respectfully
    -Zeke
    flash5twelve likes this.
  17. Oct 28, 2021 at 1:52 AM
    Kazimcsurf
    Kazimcsurf Active Member
    Honolulu
    2010 TRD OR 4wd manual
    Ya, I ordered couple of days ago. Don't know what will show up., but gate code still works. Went there Friday night-nobody there.
  18. Oct 30, 2021 at 6:08 PM
    c808nner
    c808nner Well-Known Member
    Oahu
    1995 Tacoma 3.4 MT Extracab
    anyone have 1st gen (01-04) stock/amber corner lights i can borrow for safety check? if they're an extra set i wouldn't mind purchasing it either. let me know i get back to the island in about a week and my safety expires tomorrow so it's gonna be one of the first things i do when i get back. 6 pack or plate lunch on me let me know
  19. Dec 7, 2021 at 2:08 PM
    _braddah_koa_
    _braddah_koa_ New Member
    2008 black Tacoma trd
    Anybody selling A hood with scoop for a 2008 Tacoma lmk
  20. Dec 8, 2021 at 10:08 PM
    tx novice
    tx novice Foward momentum
    Ron
    OAHU
    11 DC 4X4 TX PRO silver
    Trd, Cal Tech, Weather tech, Viper, Al's tinting . L.E.D's , Hide a Hitch or Chrome Stinger , Walker Evans Resi's w/AllPro 3" lift ,FLM, ProComp Xtreme MT2 , Diff Breather Mod, 4x4 Switch Light mod, Plastic Derped. Trailer Socket Relocate mod via Miles , 4:56 G2 gears. Blue Intake Spacer, S.S. Brake Lines F&R, Sway Bar Deleted, Roll-X, Pop-N-Lock Electric. Red metal TRD badges. Paid Off Mod- Chee Hu, Superbumbs(f),Timbrens(r).Pelfrey Bilt, Bamf, Urd. Cobra Heat Shield.CMC .Mishimoto (custom bracket by Nate), Powerstop, Rampage 50".Depo Taillights,SPPC Black Headlights, Rigid Industries. Factor 55.American AirFlow.
    I have 1. Needs a paint job
    toku58 likes this.
