Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Mar 23, 2014 at 5:36 AM
    #7021
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    Ain't nobody like a big box... :laugh:
  2. Mar 23, 2014 at 10:11 AM
    #7022
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Yeah, that's what I was referring to by options. I haven't seen that bumper in person yet. I don't think there is any on the island. I'm not a huge fan of the lower part of the bumper, but I really like the way those upper bars look. That's pretty heavy tho. You might want to think about a heavier coil when installing your lift. I went from a 600lb spring to a 700lb spring once I installed the front bumper and winch. Sagged a lot. The pelfreybilt bumper with full hoops is about 110lbs. My Warn 8000s is supposedly 55lbs, but feels more like 80! :D
    Also, I'm not sure if the pre-runner bumper will pass safety or recon with the bars crossing over the headlights like that. Not real sure how anal they will be about it.
    From Hawaii.gov motor vehicle section regarding headlights and lamps:
    Fail light and reflectoritems if:
    Missing
    Damaged so that light shows through the damaged portion of thelens (placing tape over the damaged portion of the lens is not adequate to passthe inspection but gluing that restores proper function is adequate) ormoisture is present inside the lens
    Not properly installed, or directs light improperly (this could becaused by vehicle body damage that causes a properly installed lamp orreflector to improperly direct light).
    Not of an approved type or color(See Tables I-a and I-b on Pages 12-17 and HawaiiAdministrative Rules 19-132)
    Obscured or blocked in any manner or is covered with material that is non‑transparent and which diminishesthe function of the lamp, lens or reflector so as to put it out of conformancewith FMVSS and local laws, ordinances or rules (If modified, the burden ofproof of conformance is on the vehicle owner). If a lamp or reflector that isnot required is installed, it must not diminish the effectiveness of anyrequired lamp or reflector. A rear window with aftermarket tinting must nothave tint over the portion through which the high mounted stop light shines. Ifthat portion is tinted, it is considered an obstruction, because it puts thelamp out of conformance with FMVSS.
    Inoperable, or operates improperly.
    The reverse light stays on in any gear position other than reverse.
    Headlamps(Line 10) do not have reasonably equal candlepower or cannot produce a lightsufficient to reveal any person or object straight ahead for a distance of 200feet.
    Headlamps are not properlyaimed (Instructions for using the aiming device must be available to inspectorsat the inspection station).
    Turn signal (Line 12) orhazard warning lamp (Line 14) flashing rate is less than 60 per minute or morethan 120.
    Turn signal self-canceling devicedoes not operate.
    Side marker lamps do notilluminate when the headlamps or parking lights are turned on.
    The high beam indicatorlamp, or any other safety oriented indicator lamp is inoperative.
    Headlight height (measuredto the headlamp center from road surface) is lower than 22 inches or higherthan 54 inches (§291-25, HRS).
    Reflector height is lowerthan 15 inches or higher than 60 inches. Note: Sec. 15-19.3 of the Honolulu ordinances requires reflectors to be mounted on the motor vehicleat a height not less than 24 inches or more than 60 inches above the ground.However, Federal standards allow a minimum of 15 inches for the following:tail lamps, stop lamps, parking lamps, reflectors, backup lamp, turn signallamps, side marker lamps, intermediate side marker lamps and intermediate sidemarker reflectors. If any of these items is less than the County requirementbut within the Federal requirement, the vehicle should not be failed unless thevehicle was modified in a manner that reduced the height below a Countyrequirement.
    What do you guys think? Should be okay? Maybe TRDgirl can chime in :)
    Not trying to be a downer bro. Just giving a heads up :eek:
  3. Mar 23, 2014 at 12:02 PM
    #7023
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    yeah it had a camper on it. i think I might got that route on tires next..looks good
  4. Mar 23, 2014 at 1:32 PM
    #7024
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    I'm def getting this mutha!:D All-Pro Apex--- (Aluminium)...the way the Aussies say it:D
    Icons going on first though...and thennnnnnnnn:cool:
  5. Mar 23, 2014 at 2:16 PM
    #7025
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    I looked at that aluminum one.. That's some dollars...
  6. Mar 23, 2014 at 3:08 PM
    #7026
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    Bone Stock
    You're right! It is some dollars, but I'll be dead in less than 20 years (30 Tops):D So why not:cool:
  7. Mar 23, 2014 at 3:37 PM
    #7027
    raycie
    Oahu, HI
    In need of $$$
    In that case.. go for it. .
  8. Mar 23, 2014 at 5:53 PM
    #7028
    CBoy808
    CBoy808 The Original Sticker Dude
    Tacoma Mall Crawler
    DAS MY BANK!
  9. Mar 23, 2014 at 6:01 PM
    #7029
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    spotted this truck out at aloha stadium at the spartan race.
    running andre's horns in the grill
    never seen it around before, nice truck.
  10. Mar 23, 2014 at 6:06 PM
    #7030
    808state
    808state Well-Known Member
    Randy
    Hawaii
    Prerunner Sport DCLB
    Debadged, painted emblem, TRD badge, BFD, Duratrac (replaced), Gorilla, Maxtrac, Dakar, 5100s, extended brake lines, Toytec 1/4" top plate spacer, Spidertrax, Rally Armor universal, Auto Ventshade Stepshield, N-Fab, Antenna-X, TRD skid, Weathertech DigitalFit and deflectors, Wet Okole, Redline Tuning QuickLIFT, OEM exhaust tip, FormulaOne Pinnacle, OEM bed mat, Roll-N-Lock, 2014 head unit, Ultragauge, Smittybilt shackles and hitch mount, Smittybilt shovel (broken), Curt, Bushwacker, BPFabricating tow hook, OME 883s (replaced), D29XL, Light Racing, SuperBumps, painted valance, Salex, ARB, Staun, Viair, Yakima, BHLM, OME 885s, Toytec 1" block (removed), Daystar d-ring isolators, 2" block, 1/2" top plate, Toyo 33" R/T, Optima red top To put on: Bora, XTP ims, URD Maf cal, AFE intake Wish list: EBC stage 5, full sized spare, Gerber folding shovel
    Saw Miles in Makakilo today. Truck grill is looking mean.
  11. Mar 23, 2014 at 8:18 PM
    #7031
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    Is anyone running 2 sets of rims with workin tpms? I want to be able to switch from stock to beast wenever i want without worrying about sensors.
  12. Mar 23, 2014 at 8:21 PM
    #7032
    AiNoFaKNKeA
    AiNoFaKNKeA Well-Known Member
    Hawaii
    '14 TRD Sport DCSB
    885's w/ 1/2" spacers on OME Sport Nitros OME Dakars w/ Sport Nitros & D29XL AAL 285/65 BFG AT KOs on 18" Dropstars 645B 0 Offset 4.5" BS Spidertrax 1.25" Wheel Spacers LED Interior and Exterior 6K HID Headlamps and Fogs 6K LED DRL Switchbacks Pop and Lock Codeable Smart Lock Tailgate Handle Debadged Wet Okole's Front and Rear Weathertech Digital Fit Floor Liners Husky Liners Custom Molded Mud Guards Tint AMP Research Bed Step AMP Research Bed Extender ImMrYo Rear-View Mirror Lift Bracket Viper Alarm ICE: Alpine PDX-V9 Audio Control LC6i Image Dynamics CTX65CS Image Dynamics CTX65 Image Dynamics IDQ12 KnoKnoise Sound Deadening
    I wanted to know also and if anyone running EZ sensors. I have yet to order mines cuz everyone I called said it's a hit or miss when it comes to programming it.
  13. Mar 23, 2014 at 8:22 PM
    #7033
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Luka can program the TPMS for you for a small price:D
  14. Mar 23, 2014 at 8:24 PM
    #7034
    AiNoFaKNKeA
    Hawaii
    '14 TRD Sport DCSB
    Can Luka program the Schrader EZ sensors?
  15. Mar 23, 2014 at 9:37 PM
    #7035
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Well mike what u think, if i get a set of oem sensors can u reprogram them for me?
  16. Mar 23, 2014 at 9:46 PM
    #7036
    senojeelnodnarb
    senojeelnodnarb Well-Known Member
    Brandon
    Oahu, HI /Canton, NC
    2013 Tacoma DCSB 4x4 TRD OR, 6-Spd Manual
    Fully De-Badged, Mossy Oak seat covers, Fog Light anytime mod, Custom Bed Light Bar, flowmaster 40 series, Plasti-Dipped Grille, Painted Stock TRD Rims, Custom Plate Bumper, High-Lift Bed Mount, Ballacula Trailer Plug Relocate, Rear Seat Dog Platform, sunglasses holder Switch panel, 2" lift, 285/75/R16 Mickey Thompson Baja MTZ, custom sliders, + a shit load more,
    What ever you do, don't but them from Toyota. They charge out the butt
  17. Mar 23, 2014 at 9:48 PM
    #7037
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    as long as it has the 8-9 digit serial number, it should work just fine.
    the number should be on the sensor, so you need to take a picture of it or write it down for me to enter it in. The tool I have plugs into the obd2 port and my laptop.
    Used it on mine and a few others already.
    oem sensors are about 70-90 from toyota, but they use a 3rd party company.
  18. Mar 23, 2014 at 10:14 PM
    #7038
    TRDeeznutz
    Kaleo
    Kapolei, HI
    09B18225E1... Is that the number?
  19. Mar 23, 2014 at 10:15 PM
    #7039
    TRDeeznutz
    Kaleo
    Kapolei, HI
    315mhz 20 degrees for alloy wheels.
  20. Mar 23, 2014 at 10:25 PM
    #7040
    luka
    Kailua, HI
    yeah, that looks right. it should be laser etched on the valve. just take a pic of it to be sure and keep track of which valve goes to which tire location to make it easy
