Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. May 28, 2014 at 3:46 AM
    #9941
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    technically you could, but I'd get a better coil instead.
  2. May 28, 2014 at 3:56 AM
    #9942
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    I jus installed 5100s set at 2.5" with a 1/4" top plate spacer the ride is 100x better than the procomp 2.25" strut spacer. Im only using the spacer to fix my taco lean. Im using my stock coils. Only set them all the way up to fit my tires. When i get my maxtrac spindles im dropping them to .85" but still gonah use the spacer incase the lean cones back.
  3. May 28, 2014 at 3:58 AM
    #9943
    Konaborne
    Cody
    Kealakekua, Hawaii
    also...nobody here sells coils, do they?
    when I get this bumper on I wanna up my coils to 650lb'ers on my foxes
  4. May 28, 2014 at 4:37 AM
    #9944
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    I agree with Cody. I chose to go straight for the 885/billie setup from the get go. The ride is excellent and can only imagine how much stiffer it would've been had I stuck with any combo which included the stock coils.
  5. May 28, 2014 at 4:39 AM
    #9945
    Konaborne
    Cody
    Kealakekua, Hawaii
    stocks are soft, preload will only wear them out faster
    5100 heights are approximate to the stock spring rate; eventually they'll sag
  6. May 28, 2014 at 9:22 AM
    #9946
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    nice, you cleaned up around the mill :p
    I have a couple sets at home
    what'd ya make?
  7. May 28, 2014 at 11:46 AM
    #9947
    maarkymaark
    maarkymaark Well-Known Member
    Mark
    Oahu, Hawaii
    2013 4x4 DCLB
    debadged, LEDs all around, 5% tint all around, TRD Air Filter, all around Bilsteins 5100s, 885s coils, 2" AAL, LR UCA
    So if i go with the 885 setup, it would give me the 3in without having to put a top spacer?
  8. May 28, 2014 at 12:19 PM
    #9948
    WailuaTaco808
    WailuaTaco808 A.L.O.H.A. Member
    Phil
    Hawaiian Islands
    2010 Tacoma TRD SPORT Kauai Built
    Oh boy...
    i was trying to upload a video of a 2 wheel drive Xterra tearing it up lol but for some reason the video isn't uploading to photobucket. might have to try youtube.
    i love my mtz's they are way better than expected. worst case i give the whole strap to mike. going to be pretty hard to cut. the other tows trap its a heavier duty strap.
    well that would have been way easier lol
  9. May 28, 2014 at 1:06 PM
    #9949
    Vanguard
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    No you'll get more of 2.5. I also have the 1/4 inch lean spacer too and my billies set at 0" with the 885's. From what I gather anything more than that you'll need to do a diff drop because of the cv angles. Most of the guys here are running 2.5 and they all look really good. And a lot of the guys started with Billies and then graduated later to better set ups but the same height. I like my setup and will stick with it for a bit as mine is a daily driver. And I guarantee I put on more miles than anyone else here. When I have a chance I'll move up to 285's and better suspension setup but probably stay at the same height.
  10. May 28, 2014 at 2:04 PM
    #9950
    maarkymaark
    Mark
    Oahu, Hawaii
    2013 4x4 DCLB
    Is there a big difference in ride quality between 1.75 to 2.5 for the bilsteins 5100, i might want to set it at that for now until i save money for the 885 coils
  11. May 28, 2014 at 3:32 PM
    #9951
    xmods
    xmods Super Member
    Nathaniel
    Kaneohe
    10' PRO-4X CC, modded..
    Too long to list :D
    We notched some aluminum crossbraces for my RC.
  12. May 28, 2014 at 7:15 PM
    #9952
    kumz
    kumz Well-Known Member
    yeah, the ride quality sucks at 2.5. too much preload on the coil..
  13. May 28, 2014 at 7:20 PM
    #9953
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    power windows installed
    new project arrived just in time
  14. May 28, 2014 at 7:53 PM
    #9954
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    Nice! No more reaching over to roll down the windows.
    At first, I thought, how'd he get a tweeter there?!? Manual crank hole, duh.
  15. May 28, 2014 at 8:00 PM
    #9955
    polekasta
    polekasta Well-Known Member
    Wahiawa, Oahu, Hawaii
    06 4x4 long bed
    add a leaf, Bilstein 5100's
    So that's how the F250 got stuck, was trying to pull out the 4runner. I gotta start bringing my camera out to these outings.
  16. May 28, 2014 at 8:19 PM
    #9956
    squint0241
    squint0241 OVRLND
    Rick
    Tropics
    '14 DCSB/Off-Road 4X4
    Bone Stock
    Damn! You guys are all muddy! I just washed my shit:D
  17. May 28, 2014 at 8:20 PM
    #9957
    808TacoMan
    808TacoMan HAWAIIAN
    Lawson
    Honolulu, HI
    2018 TRD OR
    Toytec Ultimate lift Coilovers Toytec AAL No diff Drop 5% Tint all around Morimoto 2Stroke LEDS High and Low Morimoto Fog Lights MESO Key FOBs
    Still need the top plate according to toytec
    Edit: I went from bilstein at 2.5 to the ome 885. Much better and more height, I used a 1/4" top plate spacer and a 3/8 on the driver side.
  18. May 28, 2014 at 8:23 PM
    #9958
    hoenah808
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    lol
  19. May 28, 2014 at 10:26 PM
    #9959
    luka
    Kailua, HI
    want to wash mine too? :p
  20. May 28, 2014 at 10:27 PM
    #9960
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    and mine! I'll let you borrow my pressure washer :D
