Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Jul 11, 2015 at 2:38 AM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    which one did you work at and when?
  2. Jul 12, 2015 at 1:54 AM
    jaymay82
    jaymay82 Well-Known Member
    '13 MGM TRD Sport DCSB
  3. Jul 12, 2015 at 1:33 PM
    D.Mathys
    D.Mathys Well-Known Member
    Sooooo today was the install day for my Icon stuff, didn't make it very far. Ended up rounding off the castle nut holding the spindle to the upper control arm.....
    Any advice other than cut it off? Plus only got a hacksaw....
  4. Jul 12, 2015 at 1:42 PM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    Use a vice grip?
  5. Jul 12, 2015 at 1:46 PM
    D.Mathys
    Tried. No luck.
  6. Jul 12, 2015 at 1:49 PM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Vice should work
  7. Jul 12, 2015 at 1:57 PM
    D.Mathys
    Lol, apparently for everybody but me.
    Think I'm at the point where if I don't stop there is going to be a nice new foot shaped dent in the passenger door. Going to button everything back up.
    Anyone want to buy a Icon stage 4 suspension with Dakars, super bumps and extended brake lines?
  8. Jul 12, 2015 at 2:37 PM
    raycie
    Oahu, HI
    In need of $$$
    You could just cut off as you are gonna be using the icon UCAs correct??
    Would be very tempting to buy some parts off you..
  9. Jul 12, 2015 at 2:49 PM
    D.Mathys
    I'm done for the day, safer. Won't have time again for a couple weeks so I'm going to give 4wheel a call and see what they want to install everything. If it's more than I want to pay, got a feeling it will be, then I will give it another go when I have time. Give me time to pick up a sawzall so I don't have to cut it by hand.
    If it does get to the point where I do say F it and decide to turn my Tacoma into a submarine, I will let you guys know.
  10. Jul 12, 2015 at 2:58 PM
    raycie
    Oahu, HI
    In need of $$$
    I got an angle grinder with metal bit that would take 1 min to cut off...
    More than enough guys to give you a hand, or we also do have a Hawaii Kai, Ewa, Kailua, and Wahiawa TW shops...
  11. Jul 12, 2015 at 2:59 PM
    D.Mathys
    Thanks.
    TW shops?
  12. Jul 12, 2015 at 3:06 PM
    D.Mathys
    Also if the shops are to expensive/I'm too broke, I will re-attempt on the weekend of the 1st. If that falls through, won't have time again until the weekend of the 21st. Either way, I will make sure I have enough beer, bbq and hugs if folks want to come over and assist.
  13. Jul 12, 2015 at 4:34 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    4wheel is notorious for messing stuff up.
    that's a solid couple hours of work.
    how'd you round the castle nut? open-end wrench?
  14. Jul 12, 2015 at 5:20 PM
    D.Mathys
    Thanks. I hear 4wheel is down towards the bottoms of most lists. They are close to me and only shop I've been too before to buy stuff. Honestly not sure where any of the other shops are, so figured I would give them a call. I'm a car guy and have only had the truck a couple months, still kind of getting used to everything.
    Castle nut....well I think this truck hates me. Been working on cars for a long time and have had things break but haven't broken anything. Not so with this thing... I've done coil overs on 9 of my past cars without any hiccups. Truck...can't even get a damn castle nut off.
    Pre-soaked it with PB Blaster then started off open end wrench when I realized it was on snug, moved to a box which is when it started to round off. Managed to get a socket on over the rounded corners, but nothing, vice grips, a mallet, nothing, even pulled out the torch but didn't use it. With the way things were going I would have set the truck on fire.
    Maybe there is something about truck suspension geometry that I don't understand yet...but I stick with the original, the truck hates me.
  15. Jul 12, 2015 at 5:47 PM
    hoenah808
    hoenah808 Well-Known Member
    Trent
    Honolulu, HI
    '14 AC sr5 4x4
    get a 6 point socket on it and a breaker bar...if we can setup a time i can drive to you and try get the bolt off..i got quoted $600 to install my stuff, so i but the bullet and installed it myself lol..didnt do my ucas yet tho
  16. Jul 12, 2015 at 6:03 PM
    D.Mathys
    Thanks for the offer.
    I managed to pound a socket on over the rounded nut but I think by then it was too far gone. After that and the vice grips it looks like someone went at it with a hammer and chisel....
    I think cutting it off is the only answer now.
  17. Jul 12, 2015 at 8:39 PM
    luka
    Kailua, HI
    i might have a special socket for stripped bolts/nuts that could fit..need to check
  18. Jul 12, 2015 at 8:51 PM
    D.Mathys
    Thanks. I've seen them but don't own a set.
  19. Jul 13, 2015 at 1:50 AM
    BotoSlap808
    BotoSlap808 JAHblessed
    Kaneohe,HI
    2015 sport DCSB
    Yo guys any1 no the biggest size rim and tires I can go on my stock 2015 DCSB 4cyl taco the stick ones are tiny AF lol
  20. Jul 13, 2015 at 8:58 AM
    k3v11n
    k3v11n Yeah? No!
    Oahu, Hawaii
    2015 SR PreRunner Oahu Edition
    PlastiDip
    265/75/16 or 265/70/17 depending what size wheels you have.
