Oahu Members Thread
Discussion in 'Hawaii' started by Junyaboi808, Jul 2, 2012.
  1. Aug 14, 2015 at 5:26 PM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    She's a keeper!
    k3v11n[QUOTED] likes this.
  2. Aug 14, 2015 at 5:52 PM
    cubiclesurfer
    cubiclesurfer Well-Known Member
    Kailua-Kona, HI
    make sure you remind her that bigger tires don't fit on your rims, so you need new rims too. hahaha
  3. Aug 14, 2015 at 7:51 PM
    cubiclesurfer
    Kailua-Kona, HI
    serious question: is it possible buy just the u-bolts in the all-pro flip kit? just in case my super bumps don't make it by the pelfreybilt camp trip, I wanna cut the excess on my bolts so I don't bottom out on the bolts before the little "stock" bump. what do i need to cut the excess?
  4. Aug 14, 2015 at 7:52 PM
    BotoSlap808
    BotoSlap808 JAHblessed
    Kaneohe,HI
    2015 sport DCSB
    Nah no need patch just throw some gorilla glue over the top lol. I did that to a tire that stealership said they couldn't patch and buggah when last months hahaha #brokemokeproblems
  5. Aug 14, 2015 at 10:58 PM
    xurusaibobx
    xurusaibobx Well-Known Member
    just pull the nail out and double check its not leaking. when i used to work on tires i would see thorns actually puncture threw tires more then actual nails ...
  6. Aug 15, 2015 at 1:13 AM
    Vigo
    Vigo WFO
    On a rock in the pacific
    '12 4 door
    stuff...
    I'm not sure about the replacement bolts.
    I'd use a grinder with a cutoff wheel, since you'll have to cut 8 bolts. It would be a total PITA, but it can be done with a hacksaw but positioning the saw is hard under there.
  7. Aug 15, 2015 at 7:48 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Was driving next to the orange TRD Pro yeaterday (not aido's).. paper plates, but looked like someone keyed the tailgate.. SAD...
  8. Aug 15, 2015 at 9:05 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    That's kinda effed up, some people just has no respect for other people's personal belongings. Either that or he/she pissed off someone. That's what I'm paranoid about haha(knock on wood). That's why avoid going out in crowded public places. Always take the gf's Tc haha.
  9. Aug 15, 2015 at 9:44 AM
    raycie
    Oahu, HI
    In need of $$$
    2 options... either put your old UCAs on, or I think I have some spacers that sarah sent me that I was going to use prior to me figuring out my timbrens
  10. Aug 15, 2015 at 10:08 AM
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
    http://toyteclifts.3dcartstores.com/U-Bolts-with-hardware_p_9.html
    Look at these, also just use a grinder and cutting wheel to take off the excess
  11. Aug 15, 2015 at 10:18 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I used my sawzall to cut mine. If you turn the blade so it's doing a flush cut then it's pretty easy to get the cut nice. You can use anything to cut it, just cut them with the nut threaded on so you can remove the nut after cutting to re-thread the cut portion.
  12. Aug 16, 2015 at 12:12 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    I'm sure Rick @squint0241 and I are in the minority but I thought I'd share my experience with the CravenSpeed antenna. I usually can't catch sheeznit on FM until I hit Kalani High headed west (I had to say west so Rick can follow along). And I usually can catch AM no problem from the house till I cross over. But with this new "Stubby" antenna I could only catch 104.3 and I'm talking about driving through town on the H1! WTFranks? I knew there would be a trade off but I didn't think I'd be stuck with one FM station and no AM signals sitting in the middle of Honolulu. Anyway this one is headed back if nothing changes. Heysus Christ!!!
  13. Aug 16, 2015 at 12:17 AM
    BotoSlap808
    Kaneohe,HI
    2015 sport DCSB
    I have yet to find a good stubby it pisses me off
  14. Aug 16, 2015 at 12:20 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Well some guys have had some fair to midland experiences and I though I'd try my luck. Living out here in HK I can't catch diddly anyway so I thought what the heck might as well try. But c'mon from Waikiki to Honolulu and I can't even catch AM?!?
  15. Aug 16, 2015 at 12:23 AM
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    What did you expect from a stubby antenna.:anonymous: The smaller you go on antenna you loose DB signal strength. There is a reason why the antenna is a certain length. Just my 0.02 cents
  16. Aug 16, 2015 at 12:24 AM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    if you want a good stubby, try one from a Honda Element. I did that for my Celica and I think the threads and everything fits.
  17. Aug 16, 2015 at 12:25 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Well like I said in HK a full mast antenna or nothing and it's still the same reception. I just didn't think sitting in the middle of town I would have the same result as NO antenna. I did have "lowered expectations". Figured AM would still catch at the very least.
  18. Aug 16, 2015 at 12:26 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Thanks. Or I may so the "cut down" like everyone is suggesting. I just like a clean factory look if at all possible.
  19. Aug 16, 2015 at 12:28 AM
    luka
    Kailua, HI
    I keep the stock one on my truck, helps me remember of where I can park :D
    raycie likes this.
  20. Aug 16, 2015 at 12:29 AM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    I usually take my other car to work but my office building is 6'2"....
