OBA (On Board Air) brand switch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 3Leaf, Jan 23, 2014.
  1. Jul 13, 2014 at 12:14 AM
    gunhound
    gunhound Gunhound
    CO
    2013 DCLB Sport
    5/15 tint, NFab step bars, Viper SST, Weathertech floor liners, Toyo A/T IIs on 17x9 XD Menace wheels. Lift - SPC LR UCAs, Wheelers 3 pc AAL, OME N140s, N182 and 885 w/ TP spacers.
    Installed one of these switches as well, but like others mentioned the backlighting is opposite -
    Using a meter, found out the dimming circuit is reversed.
    When dash lights are turned down, voltage increases.
    Anyone know a way to fix this so the switch dims with the dash lights?
  2. Jul 13, 2014 at 12:21 AM
    7shotguns
    7shotguns the captain
    Utah
    14 SR5 DCSB Black
    not much yet, I did tint the tail lights though.
  3. Sep 8, 2015 at 5:00 PM
    Kemosabe
    Kemosabe Little bitty life
    Louis
    Western Quebec, Canada
    2010, 2.7l, 4x4, M/T
    URD STS, Spidertrax spacers, AFE Pro dry
    What kind of connection is behind those switch? Does it need an harness or it can receive a kinda universal male / female connector?
  4. Sep 8, 2015 at 5:04 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Mine is a 2013 and it fit perfectly.
  5. Sep 8, 2015 at 5:06 PM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    It came with the harness. The Harness has 4 wires. Power, relay, dead and a connection to plug into the running lights if desired in that order.
    Kemosabe[QUOTED] likes this.
  6. Sep 8, 2015 at 5:53 PM
    916carl
    916carl Well-Known Member
    Carl
    2008 DCSB TRD Sport SR5
    It is hard to find the wiring diagram on line. The vendor doesn't list it on their website and you only get one after you buy the switch. This is what you get with each switch:
  7. Feb 20, 2016 at 3:45 PM
    summit907
    summit907 Active Member
    2017 Tundra CM
    How would I wire this if I'm just adding an on/off switch to wires that already exists? I'm adding an on off switch in my DTRL wire.
  8. Feb 20, 2016 at 4:16 PM
    vtecb20da
    vtecb20da Member
    seth
    I have three of them in my truck. I wired them to the factory ground that dims with the rest of the dash lights and they dim with the factory lights just fine. I love them.
  9. Feb 20, 2016 at 5:35 PM
    summit907
    2017 Tundra CM
    I'm not going to illuminate just need it as a basic on/off switch so how would I wire it I just cut my dtrl wire and connect it to this, but how
  10. Feb 20, 2016 at 9:25 PM
    vtecb20da
    vtecb20da Member
    seth
    Wire it in line if you cut drl wire green and yellow and red and yellow.
  11. Feb 20, 2016 at 9:30 PM
    summit907
    2017 Tundra CM
    sweet thanks
  12. Aug 3, 2016 at 8:13 PM
    Toynado
    Toynado Well-Known Member
    SF Bay Area
    2016 TRD OR DCSB Quicksand
    EXTERIOR: Toytec Boss 2.0 Dakar CS047R Leaf Springs Tailpipe chopped Pelfreybilt Front full hoop front bumper w/ Pelfrey fairlead Pelfreybilt Rear standard bumper Pelfreybilt Aluminum IFS, Mid, Rear (exhaust reroute) & Gas tank skids Pelfreybilt Fuseplate w/ 12 circuit fuse block All-Pro Apex Sliders ProComp 7036 17"x9" -6 offset BFG 275/70R/17 KO2's Warn VR10000-S winch Baja Designs S8 light bar & Squadron sports amber pods in front bumper Baja Designs S2 flush pods in rear bumper Baja Designs Squadron Pro amber pods on Caliraised ditch light brackets @rrentrop reflective black tailgate inserts RSI LED's for regular & high beams Prinsu Cabrac Custom Tradesman Truck Top by Access Manufacturing w/ Powertank 8"propane tank mount & Yakima tracks on the roof INTERIOR: Warrior Products door sill protectors Husky Weather Beater floor mats front & rear Coverking arid multicam seat covers in the front Midland 75-822 CB w/ 4' Firestick antenna on C4 Fabrication tailgate mount Consolevault Hondo Garage iPhone mount
    Any chance you could take a pic of the two wires you taped into and corresponding AOB wires? I'm going to be wiring up three of these switches in the next couple weeks and a total novice.
    What type of connector did you use to connect the AOB wires to the wire coming off the tap?
