OBA System Multi Use Help Needed
Discussion in 'Technical Chat' started by I Liquid I, Oct 2, 2011.
  1. Oct 2, 2011 at 2:36 PM
    I Liquid I
    I Liquid I [OP] Well-Known Member
    Puerto Rico
    06 BSP Double Cab Long Bed
    Too many mods to list
    Hello,
    After I finish my current project im planning on adding/modifying an OBA system for my Tacoma.
    I've searched all over but I do not find anyone with a system that airs all the things needed with the same system. Perhaps it is not possible?
    Basically I need an air system that I can use to ait the following:
    - ARB Rear Locker
    - Rear Firestone Ride Rites (with in cab controller, for switched raise/decrease of pressure)
    - Spare for airing tires and perhaps using an air tool (though the air tool wont be common and at most it would be for like taking the tires nuts off and such)
    Is there a way for me to wire the 3 lines into 1 OBA system? I know that the ARB uses an actuator/solenoid. The Ride Rites use a pressure controller and for the spare hose it's pretty much just having it there after the tank.
    So how would I go about connecting the Airbag and air locker specific systems to the same OBA system? Or I'm I going to have to run dual OBA systems?
    If I'm explaining myself in a weird way, please tell me so and Ill try to come up with a sketch or something.
    Thanks!
  2. Oct 3, 2011 at 11:48 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Everything there is possible, but you will need a lot of volume.
    You will need a large tank and a Large compressor.
    If it were me I would get a 20lb. CO2 tank, mount it upright so you can use it all the time. Run a line to the locker, another line to the airbags and a connector for a air hose.
    Keep the regular at 90 psi and everything will work fine. Depending on how much you will use a 20lb. tank should last for months. It's about $30 to refill.
  3. Oct 3, 2011 at 7:49 PM
    I Liquid I
    Puerto Rico
    Thanks for the information.
    Question however,...
    I know I can split the line coming from the compressor or the tank. But would I be able to install the hardware that supplies the air to the airbags or the locker on the line itself?
    That's my doubt, since I though i'd have to mount it near/on the compressor.
  4. Oct 4, 2011 at 7:20 AM
    DDD
    Derek
    Santa Clarita, CA
    Not sure what hardware is required for the air bags, but the ARB locker just uses an electronic solenoid. So yes you can install the solenoid anywhere along the line that connects to the locker.
    I am sure the air bags are similar.
  5. Oct 4, 2011 at 10:12 PM
    I Liquid I
    Puerto Rico
    Sweet.
    Thank you very much for the info man. :D
