OBD Dongle Suggestion for Techstream
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BLtheP, Nov 6, 2023.
  1. Nov 6, 2023 at 1:40 PM
    BLtheP
    BLtheP [OP] Constantly Tinkering Member
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    What OBD connector are folks using for Techstream on 3rd gens? I have found that my orange one from vFTuner doesn't work (unless I'm doing something wrong).
    Tried searching but didn't find much. Seems like the one from vF used to work but doeesn't anymore.
  2. Nov 6, 2023 at 1:45 PM
    Bishop84
    Bishop84 Well-Known Member
    Did you try changing the vim selection inside techstream setting?
    I use a mongoose but they are pricey.
    I had an Amazon special before but it didn’t work.
    ShimStack likes this.
  3. Nov 6, 2023 at 1:46 PM
    BLtheP
    Plano, TX
    Complete TS noob so probably not. I'll try that today when I get home and see how it works. Thanks.
  4. Nov 6, 2023 at 1:49 PM
    BLtheP
    Plano, TX
    I think I actually did mess around with that last time I tried to connect. What should I be changing?
    I see:
    TIS Techstream VIM
    OpenPort 2.0
    Edit: I did not ever mess with this setting. I see Tactrix under OpenPort 2.0. I bet that fixes it.
  5. Nov 6, 2023 at 3:16 PM
    BLtheP
    Plano, TX
    Worked perfectly after changing the VIM. Wish I had know. That a while ago. Thanks @Bishop84!
    ShimStack and Bishop84 like this.
  6. Nov 6, 2023 at 5:25 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    Just to reiterate, the vFTuner one should work, and in my opinion the best value if you don't have that is the Tactrix.
    SR-71A and BLtheP[OP] like this.
