OBD Fusion PIDs for 2023
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bgavin, Jul 11, 2024.
  1. Jul 11, 2024 at 8:30 PM
    bgavin
    bgavin [OP] Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    Question: does the older PID package work correctly for the 2023 Tacoma?
    I saw something about configuring the app as an older model year.
    Has anybody done this successfully with a 2023 Tacoma?
  2. Jul 12, 2024 at 6:20 AM
    AlBrewer
    AlBrewer Well-Known Member
    2023 TRD OR
    Yep...I'm using the 2021 package on my 23 offroad with no problems
  3. Jul 12, 2024 at 10:21 PM
    JohnDeere630
    JohnDeere630 Well-Known Member
    Gary
    Gray 2023 Tacoma SR5
    Yes, the 2021 package works fine.
  4. Aug 2, 2024 at 2:10 PM
    bgavin
    Orangevale, CA
    I originally set Fusion to my 2023 Tacoma including the VIN number.
    Later, I bought the 2021 Enhanced Diagnostics for 2021.
    This downloaded and installed correctly.
    However, I cannot see any of the enhanced PIDS.
    Would somebody please take a moment to detail the steps to get this working?
    I am thinking I might have to discard this vehicle then recreate it as a 2021, without installing the VIN.
  5. Aug 2, 2024 at 2:24 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yes, set as 2021 in Vehicle Editor
  6. Aug 2, 2024 at 2:36 PM
    bgavin
    Orangevale, CA
    I did this, and still do not have access to the enhanced PIDS.
    Is the VIN for my 2023 getting in the way?
    If so, can I delete this vehicle from the App, then recreate as a 2021 without VIN?
  7. Aug 2, 2024 at 2:46 PM
    Vlady
    Issy, WA
    Uninstall the app, reinstall and repeat the process
  8. Aug 2, 2024 at 2:49 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    I hadnt used OBD fusion in a year and then when i needed it (to check tranny temp) i couldnt find it. After depring around for a while i tried updating the app and that worked.
    Remember to check network A after after you hit Connect
    bgavin[OP] likes this.
  9. Aug 3, 2024 at 2:36 PM
    AlBrewer
    2023 TRD OR
    My VIN did not prevent me from downloading the enhanced add-ons for my 2023. The adapter will pull the VIN as soon as it's paired to the truck anyway. I just set the year as 2021 after it was paired. I just did a factory reset on my phone for other reasons, and had to re-do this process last week. Make sure you select the correct engine.
  10. Aug 3, 2024 at 3:40 PM
    bgavin
    Orangevale, CA
    If you have to reset your phone what happens to the purchased OBD Fusion and the Enhanced package? How do you reinstall without buying again?
    I bought the enhanced add-on AFTER setting the vehicle as a 2023. I should probably delete and recreate the vehicle as a 2021
  11. Aug 3, 2024 at 7:53 PM
    LFOD
    LFOD Well-Known Member
    2021 SR5 DCSB
    I had an issuer where my phone (apple) lost the PDIS. Thought it was bad luck and went to repurchase through OBD fusion. I got a pop up that said it looks like you already purchased this, would you like to download again? Downloaded no issues, No charge.
    bgavin[QUOTED][OP] likes this.
  12. Aug 4, 2024 at 7:34 AM
    AlBrewer
    2023 TRD OR
    I have the ODB Link MX+ reader, so enhanced add ons are free. Maybe this is the difference? What OBD reader are you using?
  13. Aug 4, 2024 at 7:42 AM
    bgavin
    Orangevale, CA
    This thread is specific to the OBD Fusion app running on an iPhone.
