OBD II Error message
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kris77, May 7, 2010.
  1. May 7, 2010 at 5:04 AM
    kris77
    kris77 [OP] Born in the Backwoods
    West Virginia
    08 DC TRD Sport Speedway Blue
    In channel Vent Visors, AVS Bug Shield, Hankook Dynapro RF10 265/70/17
    I bought an Actron OBD II scanner a few years ago for my old 2000 tacoma. I just tried it out on my 08 tacoma and it keeps getting link errors.
    I found this on the Actron web site...
    ""Note: Many 1996 and newer vehicles (notably heavy-duty trucks) are equipped with the 16-pin OBD II connector, but they do not link with OBD II scanners. Plugging one of our scanners into a non-compliant vehicle will not damage the vehicle or the tool. A Link Error message will be displayed on the scanner.""
    Has anybody tried reading the codes on our trucks?
  2. May 7, 2010 at 5:06 AM
    98tacoma27
    Ben
    Not Beech Creek
    Lots of TW'ers do and have.
  3. May 7, 2010 at 5:07 AM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    i work at a shop and have to all the time. its probobly not getting power. check your fuses. its usually the fuse that goes to your cigarette lighter. its probobly blown. replace that fuse and then try again.
  4. May 7, 2010 at 5:07 AM
    98tacoma27
    Ben
    Not Beech Creek
    Which model did you get?
  5. May 7, 2010 at 5:09 AM
    kris77
    West Virginia
    9135...It was like 80 bucks at advance back in 2003.
    Now they are less than 40 with the sale they have going on...
  6. May 7, 2010 at 5:10 AM
    kris77
    West Virginia
    I have a GPS plugged into one outlet and a cell phone charger in the other...and they both are working...So im guessing the fuse is good.
    I found this out too on another site...
    It says all 2008...and my scanner is not CAN capable i dont think.
    CAN or Controller Area Network is a new serial communication language especially suited for networking "intelligent" devices as well as sensors and actuators within a system. As vehicles transition to more sophisticated electronic systems- to reduce vehicle weight and increase fuel efficiency, on-board computers will be required to handle significantly more data. (Electronic throttle control, steering and braking systems are three common examples.) CAN provides a much faster data link between the computer and each vehicle system, much as a DSL connection provides today's consumers faster data transfer than do dial-up Internet services. The EPA has mandated that all vehicles sold domestically be CAN-equipped beginning with the 2008 model year. It is projected that about 14% of all vehicles on the road will be CAN-equipped in 2008.
  7. May 7, 2010 at 5:11 AM
    justin14200
    justin
    baton rouge
    stock
    dtrl fuse?
    thats almost always the problem we have at work. if not check to make sure the plug on the vehicle side has all the wires plugged in in the back
  8. May 7, 2010 at 5:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Ity's pretty much a paperweight as far as using it for your truck goes.
  9. May 7, 2010 at 5:56 AM
    kris77
    West Virginia
    You know this for a fact?
    I havent found a confirmation yet..
  10. May 7, 2010 at 6:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    http://www.amazon.com/review/RVN0QQ5MZD8ER
    http://www.dieselplace.com/forum/archive/index.php/t-13366.html
    Actron didn't seem to be open with the CAN abilities of this scanner. I would suggest calling them an seeing if they could maybe update the firmware.
    Just to make sure all the bases are covered, you do have the IGN to the on postion right?
  11. May 7, 2010 at 6:34 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    Some CAN, your unit CAN........not
  12. May 7, 2010 at 7:05 AM
    kris77
    West Virginia
    Yeah I just called them and they told me to upgrade to the CP9180.
    It is compliant with 2008 and higher and includes a USB cable for future upgrades.
    Advance still has the 50% off sale on code readers, i might pick one up just to have it.
  13. Dec 19, 2018 at 10:03 AM
    littleschipper
    littleschipper Active Member
    Mechanicsburg, PA
    '07 Tacoma Dbl Cab 4X4 TRD (Stealth mode - No Stinkin' Body Badges here!)
    TRD Cat Back Exhaust, Leer 100XQ Bed Cap, 3M Paint Protector Film, Cool SMT LED Bulbs for Brake Lights, WeatherTech Floor Liners, Pop-N-Lock Tailgate Lock, Toyota Bed Divider, 2002 Yamaha V-Max Hot Rod Motorcycle for More Fun!
    I have the CP9135 model and have used it several times on my 2007 and my father’s 2009 successfully. However, my wife’s 2012 Sienna AWD had idiot lights come on and when I tried to use the scanner I kept getting the link failures. Checked fuses, none blown. Tried it on my Tacoma and had link failures there too! Worked before, so I called the toll free number in the manual and it was Bosch repair. They told me it would be replaced under warranty but mine is more than a year old. They said I would have to buy another one, they will not repair them. Did some research and I’m going to get a BlueDriver tool. Works on my daughter’s Subaru too.
