OBD || will not connect
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Larrydsmithh, Jul 2, 2016.
  1. Jul 2, 2016 at 4:16 PM
    Larrydsmithh
    Larrydsmithh [OP] Member
    Larry
    2014 Magenta Grey
    265 wrangler duratrac tires Window visors Chrome nerf bars Bull bumper Tonneau cover 2 1/2" Leveling kit
    Truck won't start . I tried to read codes with a new OBD reader and keep getting a link error . Checked all fuses inside and out . Would appreciate if anyone can help .
  2. Jul 2, 2016 at 4:26 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Does it try to turn over? Does the starter tick? What noise does it make?
    What kind of OBDII reader are you using? It is not uncommon for cheap ones to not support all vehicles. Go to an autoparts store like Orileys and borrow their nice one for free if you need to.
  3. Jul 2, 2016 at 5:05 PM
    Larrydsmithh
    Larry
    2014 Magenta Grey
    I tried a friends OBD || before and received codes because I changed fuel caps . I just got s Leveling kit in on Friday and drove home . The next morning it wouldn't start . So I borrowed his OBD || again and it won't get a reading just says ( link error) . I go and buy a new OBD and I'm getting the same ( link error) . It turns over no problem , just won't start . I even disconnected the battery hoping it might reset itself . No F---ing way nothing .
  4. Jul 2, 2016 at 5:08 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Does it try to start at all? It is either Air/Fuel/Spark. You should still be under factory Toyota warranty.
  5. Jul 2, 2016 at 5:15 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Is the ECU on a fuse?
    TacomaZL likes this.
  6. Jul 2, 2016 at 5:17 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    It's shot in the dark but could it be a fault in the main computer of the truck? If you're using the same scan tool as before I am not sure what would cause it. Take it to a parts store that reads codes and see if they have the same issue. Link errors are usually an issue with the scan tool and not the vehicle.
  7. Jul 2, 2016 at 5:18 PM
    TacomaZL
    Illinois
    You might be on to something....
    Ringing @Jimmyh
  8. Jul 2, 2016 at 5:46 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    There apparently is a OBDII fuse:
    Also, there are 2 fuses that are used to clear DTC codes from the ECU on page 10 of this document:
    http://www.customtacos.com/tech.old.../06toyrm/06toypdf/06rmsrc/rm2006ta/005007.pdf
  9. Jul 3, 2016 at 1:53 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    your reader has to be canbus capable
  10. Jul 3, 2016 at 7:09 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check these three fuses IGN, IG1 and IG1 NO2 in the inside fuse panel.
    Check these four Fuses OBD, OBD-B, EFI, and EFI NO2 under the hood fuse panel.
    And as stated above the OBD2 Tool must be Can Bus capable.
  11. Jul 3, 2016 at 10:27 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Easier said than done, but you're going to have to attempt to backtrack their work. Connections, fuses, etc. Today is Sunday; my guess is they are closed and maybe tomorrow as well.
    Seems we've got 2 or 3 threads going similar to yours. Someone had work done and now their truck won't start. In all of these cases you have to ask yourself how did the owner get home with the truck in the first place? It must have started. The following day it doesn't.
    My guess is a loose connection has since come apart.
  12. Jul 4, 2016 at 1:21 AM
    Larrydsmithh
    Larry
    2014 Magenta Grey
    Yes Lester true , I went under the front end this time and pushed on connections that I could see basically the ABS electrical connections behind the breaks . I think that's the ABS and pushed in on them to make sure there connected . There wasn't much else there that I seen . It's been working since then . I've gone out for a 55km drive and then a couple other times . I didn't shut it off until I got home . It's 5 am now and I'm on my way to the gym and she started today . I'm brining it in for a history check maybe it will show up . It won't show up on a OBD reading . Fingers crossed :)
  13. Jul 4, 2016 at 4:16 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    If they find nothing and if it happens again check to see if the "check engine light" comes on when you first turn the key to the run position. If the light does come on the engine ECM isn't "coming on" so to speak.
  14. Jul 4, 2016 at 4:23 AM
    Larrydsmithh
    Larry
    2014 Magenta Grey
    Lol I brought it into the shop where I had the Leveling kit put in and they couldn't find s thing wrong even with a history check . So I bring it to Toyota and they think the security key lost connection something that happens . So I go to leave and it won't start . They are getting there aster Teck on it in a few minutes .
    I'll send a update after we find out what's going on .
    Ruggybuggy likes this.
  15. Jul 4, 2016 at 6:17 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    This is what I hate about a chipped key immobilizer systems.
    They Suck. I am so happy I do not have this in mine.
    tomwil likes this.
  16. Jul 4, 2016 at 6:25 AM
    Larrydsmithh
    Larry
    2014 Magenta Grey
    Go figure it didn't start after I got to Toyota . Then it did a few tries later now they are checking ECU and a couple other things after that if that's not the problem . Nothing worse than not trusting the truck every time you get in it .
