obd2 code p0303
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brucewol, Jun 25, 2022.
  1. Jun 25, 2022 at 8:08 PM
    brucewol
    brucewol [OP] Member
    08 tacoma
    My 2008 just started throwing a p0303 code and has lost a lot of power. it is still drivable although i can barely accelerate. the code indicates cylinder 3 is misfiring. before the code, i would sometimes have a rough idle before the car warmed up. at stop lights, the idle would be rough unless i put the car in neutral.
    i'm 175 miles from home in a remote location with little service possibilities. i was able to pull the spark plug and it looks good. i can use an obd2 reader to reset the code but it comes back fairly quickly if i let the car idle. not sure it would be that quick if i was on the road.
    from what i've read, when i get the p0303 code, it goes into safe mode and should be drivable, even for a slower 175 mile ride home. would it be better to just drive home in safe mode or use the obd2 reader to reset the code and hopefully i can get some miles in before i would need to reset it again. thanks for any help.
  2. Jun 25, 2022 at 8:16 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If your check engine light starts flashing, do NOT keep driving.
    I’d swap the #3 coil to a different cylinder. See if it follows to that cylinder.
    Wattapunk and Geeves77 like this.
  3. Jun 26, 2022 at 8:17 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Where is your location? If you are stranded in the remote location, don't hesitate to start a " Help " thread. More likely local TW members will gladly assist.
    Spacecoast likes this.
  4. Jun 26, 2022 at 10:24 AM
    brucewol
    08 tacoma
    thanks all for the comments. i'm currently up in the hills over a hours drive from sonora, californai. no local service and probably would require a tow to sonora. tnshooter's comment was very helpful. i was able to move the coil from cyl 3 to cyl 1. then reran the obd2 reader, and the error code moved to cyl 1. i located a napa echlin coil in sonora and will pick it up on monday.
    Jimmyh and TnShooter like this.
