OBD2 PO301 Code
Discussion in 'Technical Chat' started by NLamb1978, Apr 3, 2010.
  1. Apr 3, 2010 at 12:30 PM
    NLamb1978 [OP] Member
    Apr 3, 2010
    96 4x4 2.7L Ext Cab
    On my way to work this morning my truck developed a problem. I felt a small hiccup and knew something was amiss. I stepped on the gas and the check enging light came on. It was running real rough and had no power. I limped to a nearby parking lot and hooked up my scanner. I got a PO301 code. Misfire detected cylinder 1. Made it back home. Changed out the plugs, distributor cap and rotor button. Made it a little better. Seems to run fine then starts missing.
    Should I try to replace the wires or just take it to the mechanic?
    96 Tacoma 4x4 2.7L
    138k miles
