OBD2 port - no comms
Discussion in '3rd Gen. Tacomas (2016-2023)' started by venkman781, Feb 13, 2022.
  1. Feb 20, 2022 at 5:55 AM
    venkman781
    venkman781 [OP] Member
    2019 Black Double Cab Off Road LB
    I honestly have no idea. If I’d had the truck serviced for years off and on, I could understand a bit of wear. The truck is practically brand new and has only been serviced at the dealer once. I hadn’t once put a scan tool on it (didn’t even own one) until the situation that prompted the OP.
    I'm pretty proficient working with wiring and I saw a similar thread to mine here at TW and @ktbell444 showed a few photos of the connector pulled apart. Doesn’t even look to require a depinning tool, but that could help keep things orderly while I’m splicing new wire in. I suppose I could also label each wire with its PIN number.
  2. Feb 20, 2022 at 8:40 AM
    venkman781
  3. Feb 20, 2022 at 9:07 AM
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Karl @ktbell444 is the expert! He made my bench flash harness. He does professional work. He is the man for advice on this.
    I would PM him, he may be able to repair it with pics to show where it is "messed up". It may just be one or two pins that need to be fixed.
    ktbell444 likes this.
  4. Feb 20, 2022 at 9:55 AM
    caribe makaira
    Caribbean, Puerto Rico
    :hattip:
    These is the info that you seek:
    ktbell444 and PapaRee like this.
  5. Feb 20, 2022 at 11:14 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The only reason I'd be hesitant with the connector that's already pinned up is I've received a few messages from people using aftermarket pins and they seem to loosen over time the more the connector is used. I use OEM pins each time I have built a connector because of that. The price will be a bit higher, but worth the added insurance. OEM pins come in 200mm lengths I believe.
    Plus, you won't have to lie on your back on the floorboard of the truck and solder more pins than necessary.
  6. Feb 20, 2022 at 7:34 PM
    venkman781
    I’m willing to wire it up using the OEM connectors. Not totally sure how I’ll diagnose which are damaged but if it’s not obvious by looking at it, I could always test the pins individually on my scan tool to see if they are loose. Any tips on sourcing the OEM parts?
  7. Feb 20, 2022 at 8:03 PM
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Here's what I've used in the past:
    82998-05010
    Regarding which may be damaged and assuming a visual inspection doesn't show anything obvious, the female OBD pins should be a tight fit when inserting the male pin into it.
    For a flash through VF, you should only need the following pins:
    • 4 - Chassis ground
    • 5 - Signal ground
    • 6 - CAN High
    • 14 - CAN Low
    • 16 - Battery
    But I'd go ahead and check all while you're at it.
