OBD2 problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1943MB, Jun 27, 2021.
  1. Jun 27, 2021 at 11:04 AM
    1943MB
    1943MB [OP] Well-Known Member
    Louis
    1999 Tacoma Regular Cab 2.4 litre
    none
    Hi,
    I had my engine light come on and it was suggested I use an OBD2 scanner to see what the fault number was.
    So I've got this little KonnWei KW902 that I've had and tried plugging that into the adapter and it has power when I turn on the switch. I follow the instructions to use it through my WIFI connection and it will not connect to the ECU.
    I have no idea if this is supposed to connect to the internet. It does not. It says it is connected but there's no internet connection. It even has the message conneted, but no internet connection. Torque app does not recognize it. Nothing is getting through.
    There is no connection to the ECU. I'm getting no response from my Torque program in my phone. I don't know if it's phone, or the car or the adapter or the WIFI.
    Now I'm thinking one of those cheap Bluetooth models might work.
    Can you recommend one that works through the Blue Tooth system that is cheap and I can use through the Torque app.
    Thanks
    Lou
  2. Jun 27, 2021 at 11:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  3. Jun 27, 2021 at 11:15 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
  4. Jun 27, 2021 at 11:16 AM
    kevinRR
    kevinRR Well-Known Member
    Milwaukee, WI
    2022 Toyota 4Runner
    That model is supposed to be use with an Andriod phone and bluetooth for connection. From your post your using WIFI so just switch it to bluetooth.
  5. Jun 27, 2021 at 11:24 AM
    1943MB
    Louis
    none
    Hi,
    Okay, I just bought one of the Android Blue tooth models by ELM. The one recommended by Speedytech. The mini bluetooth.
    Thanks for the advice.
    Lou
  6. Jun 27, 2021 at 11:29 AM
    Nessal
    Texas/Bay Area
    If you're local to the bay area and still struggling with it, let me know.
  7. Jun 27, 2021 at 11:37 AM
    kevinRR
    Milwaukee, WI
    2022 Toyota 4Runner
    Did you try switch your connection to bluetooth on the KW902? I think you just had the connection setting wrong. Iphone uses WIFI and Andriod phone uses bluetooth.
  8. Jun 28, 2021 at 6:40 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
  9. Jun 28, 2021 at 6:44 AM
    Speedytech7
    I only plug em in when I need em or I'm on a long road trip, not something I really leave plugged in
  10. Jun 28, 2021 at 6:57 AM
    MooseDawg
    MooseDawg Active Member
    2002 Prerunner SR5 TRD 3.4lv6 Auto
    Chassis unlimited front & rear bumpers
    Is it normal for the airbag light to stay on when the ELM327 is connected?
  11. Jun 28, 2021 at 7:01 AM
    Speedytech7
    No, something is odd if it is putting the SRS system into diag mode
  12. Jun 29, 2021 at 6:23 AM
    old grouch
    Stan
    95 4x4 V6 Extra Cab
    Thanks
  13. Jun 29, 2021 at 10:09 AM
    Nessal
    Texas/Bay Area
    I had mine for over 11 years and use it half a dozen times a year for various vehicles. Mine looks more like the one that I linked though. I never tries it with the clear case ones that are smaller.
  14. Jun 29, 2021 at 10:10 AM
    Nessal
    Texas/Bay Area
    Mine does it sometimes. Not sure what it's all about but goes out once it's unplugged.
  15. Jun 29, 2021 at 10:12 AM
    eon_blue
    Azusa, CA
    I have a bluetooth OBDII dongle and it triggers my ABS light to stay on if I have it plugged in when I start the truck. I have to plug it in after the truck is running to avoid that.
    But I have a Scanguage now so I never use the dongle anymore.
  16. Jun 29, 2021 at 9:30 PM
    MooseDawg
    Thanks, I will try that.
  17. Jul 1, 2021 at 12:35 PM
    1943MB
    Louis
    none
    Hi,
    Okay, I got the Elm unit plugged in and set my system on the phone to look for Bluethooth devices and it came together very quick. You need to set your torque program to work with Blue tooth. I gave up trying to figure out the problem with the WIFi.
    Sooooo, here's the fault. PO505 Ide control system. It said 2 faults but each line item was the same P0505. That still leaves me in the dark as to which gizmo is causing that fault. Can anyone narrow down what needs fixing ?
    Torque works great with that little scanner. I'll remove it since it fired up as soon as I plugged it in with the engine off. The files on the disk that go into the computer had no auto loasd feature so that was confusing as to which files I needed. I'm not sure I needed any of them when using the torque program.
    Lou
  18. Jul 1, 2021 at 12:41 PM
    Nessal
    Texas/Bay Area
    I would not use that disc. If my memory serves me right, it was full of viruses and trojan horses. You got the small disc right? The one that is 1/4 size of a full CD?
