OBD2 protocol 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MSCOFF, Feb 6, 2012.
  1. Feb 6, 2012 at 9:54 AM
    MSCOFF
    MSCOFF [OP] Well-Known Member
    Mark
    CT
    2017 SR5 AC 4WD
    Does anyone know the protocol used for the OBD2 data link/transfer on an 05-11 Tacoma. I want to hook up another OBD2 device along with my scanguage. Here's a reply from the Linear Logic people.
    Hello Mark,
    Thank you for your inquiry. If the vehicle uses the CAN protocol, you can chain many ScanGauges or OBD2 devices together. If the vehicle uses VPW or PWM, you can hook at least 2 up, and possibly more. If the vehicle uses ISO – then unfortunately the vehicle can only handle one ScanGauge or OBD2 device. Please let us know if you have any further questions.
    Regards,
    Technical Support
    Linear Logic"
    thanks, Mark S.
  2. Feb 6, 2012 at 10:06 AM
    anethema
    anethema Well-Known Member
    J
    Dawson Creek,BC
    08 TRD OR Access cab 4x4
    ARB Bumper,OEM Roof rack modded for access cab, Allpro Rock Sliders,Icon Adjustable coilovers,More Tie Downs in bed, Firestone Airbags in rear,Block heater
    pretty sure it is Can bus.
  3. Feb 6, 2012 at 2:55 PM
    MSCOFF
    Mark
    CT
    2017 SR5 AC 4WD
    Thanks Anethema; I spent a while googling and you're right. It seems to be CAN compliant. A cable splitter costs around $15 and I'm good to go.
