OBDII causing warning lights?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HawkNRoll55, May 1, 2018.
  1. May 1, 2018 at 7:50 AM
    HawkNRoll55
    HawkNRoll55 [OP] Well-Known Member
    PNW
    16 Inferno 4x4 OR DCSB AT
    So I just picked up an OBDII module so that I could monitor trans temp, etc. while towing this summer with my Torque app. Had one in my Camaro for 3 years and had no issues. Plugged this one in this weekend and after a couple minutes got the ABS and traction control warnings light up on my dash. Stopped, restarted and had the same. Removed the OBDII and the lights went away.
    Is this a common thing having something plugged in there causing codes? maybe its just this new module is junk, had good reviews though. Didn't wanna use my old one cuz its bigger and would stick out to far.
    Kind of a bummer...
  2. May 1, 2018 at 8:03 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    I have a scan gauge plugged into my Truck with no issues.
  3. May 1, 2018 at 8:05 AM
    1000101 Well-Known Member
    Jon
    Reno, NV
    2022 TRD OR DCSB
    I have a scan gauge II as well. Connected all the time and no issues here.
  4. May 1, 2018 at 9:40 AM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    Herniator likes this.
  5. May 1, 2018 at 9:45 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Carista BT dongle on the connector all the time, and I use OBD fusion. Never had an issue..
  6. May 1, 2018 at 9:50 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    Some of them act strangely with the obd2 and can mix up module communication thus causing lights, ive removed 2 no name brands from customers vehicles causing warning lights to be on, i have yet to hear of a scan guage creating problems.
  7. May 1, 2018 at 9:53 AM
    sxe4533
    sxe4533 Well-Known Member
    Edmond, OK
    2016 TRDORDCSBAT
    2015 TRD PRO suspension
    i have the BAFX OBD2 and have had ABS come on once when in use!
  8. May 1, 2018 at 10:46 AM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I use a Scanguage II for daily monitoring but really bought it for towing and trans temps. I have a Bluedriver bluetooth reader for more in depth monitoring and resetting. Never had an issue leaving them in while running.
  9. May 1, 2018 at 10:49 AM
    awdvkd115
    Bud
    2017 Tacoma TRD OR
    With scan gauge you can also use it to show an accurate speed! I use mine to show the correct speed, both transmission temps and engine temp constantly and you can stroll through the other manually.
  10. May 1, 2018 at 10:50 AM
    smith.p.sean
    smith.p.sean Well-Known Member
    Right on the home page of carista as your connecting it mentions that warnings on the dash are normal. That said I have a $12 one that doesnt have any issues staying in all the time and have never had any dash warnings.
    SPS
  11. May 1, 2018 at 10:52 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    That's normal, my OBDII plug in will trip my ABS warning light if I leave it plugged in after restarting the truck. Have to start the truck and then plug in the OBDII adapter, if you leave it plugged in it will trip the light.
  12. May 1, 2018 at 11:14 AM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    If it sends out bs pid requests well then yes it's junk.
  13. May 1, 2018 at 11:40 AM
    MrMccrackin
    MrMccrackin Well-Known Member
    Gilbert, AZ
    2004 TRDOR PreRunner, 2017 MGM TRDOR 4x4
    This - i had the same happen when using the Torque app
    eon_blue[QUOTED] likes this.
  14. May 1, 2018 at 12:48 PM
    HawkNRoll55
    PNW
    yea, I was gonna go the route of plugging it in after starting the truck. still a pain in the ass to have to take it out each time. oh well. I thought about the scanguage but wasn't sure if that was gonna throw errors by leaving it in also
  15. May 1, 2018 at 12:51 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I get them when using Carista. It says it's normal.
  16. May 1, 2018 at 1:09 PM
    FrayAdjacent
    FrayAdjacent Well-Known Member
    Matthew
    Austin, TX
    2017 Tacoma SR5 4x4
    I just fired up Torque Pro a couple weeks ago, using the OBDII plug-in thing I bought years ago. I can't even remember when I got it... maybe 2009? I left it plugged in over night, then drove the next day after setting up the trans temp PIDs. It worked fine. No warning lights.
    I do not leave it plugged in all the time, though. I intend to use it when I'm towing the trailer to monitor trans temps. Otherwise, the little doohickey sticks out a bit and can be a bit annoying.
  17. May 1, 2018 at 1:14 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    only thing bad about the one I have is when you clear codes it clears everything on the daughters car...so the first 3 or 4 starts are rough, then the ecu re learns the idle settings. Its the only vehicle it does it on. no other codes pop on but Ive never left it connected very long.
  18. May 2, 2018 at 4:47 AM
    2016Tacoman
    J
  19. May 2, 2018 at 5:04 AM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    I have an '18 and running a cheap OBD2 adaptor with the torque app and have never had any issues. I leave it plug in all the time.
  20. Jun 22, 2018 at 7:55 AM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    Bringing this back up.....
    I’m using the BAFX and Torque Pro. I get the ABS and Anti Skid lights while towing my camper. Funny thing is the lights wont pop on at first. Its when I turn the truck off then start up I get the lights. Turning the truck on and off wont make the lights go away. Second funny thing, it only happens when I have the camper hooked up. All functions of the camper work perfectly. Lights, trailer brakes everything work. Ive never gotten these lights keeping the BAFX plugged in full time while the trailer is not connected.
    So, when these lights are on, are the ABS and Anti-Skid functions working or not? Next time I tow I plan to connect the BAFX after I start the truck. If that fixes the issue I’m not sure how long I will be running Torque Pro before caving for the Scan Guage.
