OBDII Code 302 HELP
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlanToyota, Sep 11, 2010.
  1. Sep 11, 2010 at 2:17 PM
    AlanToyota
    AlanToyota [OP] New Member
    Alan
    So Cal
    2000 prerunner 2.7L
    Hi all,
    sorry for the long post, just want to give all info.
    2000 tacoma 2.7L 115K miles
    Engine started running rough. idle very jerky. smell of unburnt fuel in exhaust. multiple codes with 302 as one of them.
    1. compression check, # 2 - 25psi, all others 150psi, took head off, burnt valve, replaced. now all 150psi.
    STILL rough idle with code 302 only,
    2. Pulled spark plugs, # 2 dirty with unburned fuel, switched with # 1 plug, reset code, No change # 2 still no fire,
    3. Ignition coil pack, switched # 2 with # 1, NO change
    4. Checked all wiring harnesses by turning over motor with no plugs in, all four harnesses produced spark. All four ignition coils produced spark, all four spark plugs produced spark.
    5. Pulled crankshaft pulley, It is in excellent shape, key square, no slop
    6 Pulled all injectors, cleaned, put back in, No Change
    7. Switched # 2 injector with # 1, No Change
    8. Pulled ECM out, cleaned connections, No change
    9. Replaced vacuum lines, No Change
    10. Followed wiring harness back about 1', no obvious broken wires
    11. Light a match collect insurance... just kidding, but jeez this thing is killing me.
    Now truck will idle with no codes, when run up to 2000rpm sounds good, but after 15 secs, check engine light flashes, code 302
    Anyone with any ideas, I am getting desperate here
    thanks Alan
  2. Sep 11, 2010 at 3:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    I think you covered about everything. Hows the O2 sensors? When was the last time they were replaced? Only other things would be the Cats, and ECU....
  3. Sep 11, 2010 at 8:35 PM
    AlanToyota
    Alan
    So Cal
    2000 prerunner 2.7L
    brought 02 sensor about 3 years ago the one before the cat. This would give a misfire code? Don't understand the logic in that one. thanks for the help
  4. Sep 11, 2010 at 8:59 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    After market cats have been known to last only a year or two.
  5. Sep 11, 2010 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont quite understand the logic either, but its listed as a possible cause in the OBDII diagbosis chart I have.
  6. Sep 12, 2010 at 12:44 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
  7. Sep 12, 2010 at 9:57 AM
    fletch aka
    Gary
    Left Coast
    Sent you a PM
  8. Sep 12, 2010 at 4:39 PM
    AlanToyota
    Alan
    So Cal
    2000 prerunner 2.7L
    Ok stuck at work for two days, will check compression and do leak down test when I get home on tuesday.
    thank you for all the suggestions and links
    alan
  9. Sep 19, 2010 at 1:54 PM
    AlanToyota
    Alan
    So Cal
    2000 prerunner 2.7L
    Hi all, just wanted to thank everyone for their input and suggestions. Doc Brown nailed it with the valve clearance tip. When cold, compression was great. but after warming up the valve length expanded causing it not to seal. This explains why there was no code at an idle, but when reved up for 15 -20 seconds the engine became warm, valve stayed open and check engine light flashed. Also why truck would seem to run good right after I started it, but then progressively became rougher and not idle well.
    To all members, this is the best site I have found and thank you to all again. Hope this helps someone else with any problems they have.
    Alan
  10. Sep 19, 2010 at 11:05 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Glad I could help. :D
    -Brian
