OBDII codes P0133 and P0130
Discussion in '1st Gen. Tacomas (1995-2004)' started by goomba, Jul 8, 2011.
  1. Jul 14, 2011 at 11:11 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    play around with ignition coils and see if it changes cylinders. cannot watch videos now thoguh so hopefully im giving you decent advice :D
  2. Jun 5, 2012 at 7:03 AM
    goomba
    goomba [OP] It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Found out it was a lazy cat(clogged cat). Thanks guys
  3. Jul 16, 2020 at 7:47 PM
    97tacoma01
    97tacoma01 Member
    972rzE85
    E85 convertion stage 2 mods
    Replace your knock sensor, it wont throw a code but it will go into safe mode and the ecu wont fault it and the o2 sensors will read wrong
  4. Jul 16, 2020 at 9:00 PM
    Glamisman
    Glamisman Well-Known Member
    i didnt see what motor you had so I uploaded both.
    • 5VZ.pdf
      File size:
      466.5 KB
      14
    • 4cyl.pdf
      File size:
      464 KB
      10
