OBDII error - No communication
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fishcraft, Apr 15, 2011.
  1. Apr 15, 2011 at 11:00 AM
    Fishcraft
    Fishcraft [OP] Member
    Lakewood, CA
    05 TRD PreRunner SR5
    I took my tacoma to 3 different smog test shops and couldn't pass the test because of an error with the OBDII connection - no communication. The truck passed the actual smog test with flying color. There are no blown fused in the engine compartment or under the dash. The smog tech checked myOBD II post and it has power. I found a thread posted here from 2007, but no one replied to it. Please help if you can. Thanks.
  2. Apr 15, 2011 at 11:07 AM
    TiMe
    TiMe Well-Known Member
    CA
    05 Dbl Cab 4x4
    6" Fabtech with coilovers 33" nitto mud grapplers
    Had the same thing happen just the other day. CEL was on and had my buddy check it with his scanner and it came up error. Had another buddy with a snap on modis scanner check it and it read the codes. Try a different scanner.
  3. Apr 15, 2011 at 2:44 PM
    Fishcraft
    Lakewood, CA
    The first smog station tried twice and could not communicate with the vehicle. He wanted $95 to diagnose the problem on top of the $53 for the smog test.
    The second smog station (a test only station) ran the test 3 times and he told me, he has the lastest software update for this system. He said my truck is a CAN vehicle and his computer should bypass the OBD interface, but it didn't and failed. Test and service were free!
    The third smog station also ran the test 3 times he also used a snap-on scanner which did not established a communicate line, double check the fuses and wires, all checked out ok. Test and service were free!
    I just spend 2 hours examining all of the wires and connectors under the dash and found a loose single female pin connector near the gas paddle. It looks used, but I couldn't the corresponding male pin.
  4. Apr 15, 2011 at 2:47 PM
    98tacoma27
    Ben
    Not Beech Creek
    It's common to find "spare" plugs in the dash. They are for options that your tacoma may not have come with.
  5. Apr 15, 2011 at 3:51 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Have you disconnected your battery recently? Sometimes that communication error may occur if the ECU haven't totally reset. (may take 50+ miles) I would drive it around and then hook a scan tool up to make sure there are no codes before taking it for re-inspection. If not, then recommend another scanner.
  6. Apr 16, 2011 at 12:17 PM
    Fishcraft
    Lakewood, CA
    I took my truck to the dealer and it passed the smog test. The tech said there is nothing wrong with my port. My truck is a CAN vehicle, not an OBDII. Next time I'll just go to the dealer for the test and save me some trouble. Thanks to all who helped me!
  7. Apr 11, 2014 at 2:18 PM
    Asphaltjunkie
    Asphaltjunkie New Member
    North Carolina
    06 PreRunner
    Don't mean to hijack the thread but I'm having a similar problem, so better to kickstart this one.
    06 Tacoma PreRunner, V6 Auto. Never had any problems other than gas cap lost it's seal last year. Tried to get it inspected today (96 and up require emissions testing in NC) and she failed. Reason stated was "could not establish communication." I checked every fuse in both blocks, under the hood and under the dash. Any suggestions before I by a new ECM? Thanks
  8. Apr 11, 2014 at 2:58 PM
    smd3
    smd3 Well-Known Member
    Seems like OP was able to get smog at the toyota dealership, can you do that?
  9. Apr 14, 2014 at 5:28 PM
    Asphaltjunkie
    North Carolina
    06 PreRunner
    I've got another mechanic/inspection station who's willing to test the connection and see what happens. If it fails again I guess the dealership will be next stop
  10. Apr 14, 2014 at 8:29 PM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    CAN is a protocol that is OBDII compliant along with several others. It is like a subcategory.
  11. Oct 23, 2014 at 2:34 AM
    IceMan50
    IceMan50 Well-Known Member
    Western MA
    08 Tacoma DBL Cab Long Bed TRD
    TRD Intake
    Im having the same issue with my 08' No connection when brought to the inspection station. Next step is taking it to the dealer. Any updates on this? Thanks.
  12. Oct 23, 2014 at 4:41 AM
    offgrid taco
    offgrid taco Well-Known Member
    ned
    mass
    24 trd off road bronze oxide
    Just had the same problem with mine. Three tries with their computer and could not connect. My scan gauge connects right away. Took it to a friend at a shop and could not get their new snap on diagnostic computer to connect. Messed with the connection for twenty min and finally connected. Took the entire obd wire harness and jammed it forward into the connector. This seemed to solve the problem at least for now.
  13. Oct 23, 2014 at 4:53 AM
    kg5ie
    kg5ie Well-Known Member
    Bill
    Tx
    '14 PreRunner
    UltraGauge
    Often the "no communication" error has nothing to do with the connector. It is a product of the machine finding the correct protocol and communication parameters in order to communicate with the computer. Not unlike the old baud rate issues some of us old folks fought with computer telephone modems. ;)
  14. Oct 23, 2014 at 5:09 AM
    gearcruncher
    Canadain bumper technician
  15. Oct 23, 2014 at 9:28 PM
    IceMan50
    Western MA
    TRD Intake
    Brought mine to the dealer today for a second attempt at inspection; same issue (could not communicate). The tech checked all the fuses under the hood with a test light (I watched him) with no luck. He also, tried pushing all the pins into the connector to make sure everything was properly seated, this didn't help. So this makes two different shops that are unable to link up with the OBDII. At this point I have scheduled an appointment in a week to have them diagnose the problem, but at $95/hr to start, I was really hoping for some additional advise. I've read all the threads on TacomaWorld pertaining to this issue and no one seems to have a definitive solution besides the fuse (which is functional in my case). Any help would be appreciated. Thanks in advance.
  16. Jun 6, 2016 at 12:55 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    what was the outcome?
  17. Jun 6, 2016 at 4:20 PM
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Snap on and every other decent newer obd 2 scanner will work with your truck. You have a problem with your port most likely.
  18. Apr 8, 2021 at 5:57 PM
    alexander4x4
    alexander4x4 Active Member
    Having the same issue at the dealer
    2018 tacoma
    No communication
    connector is getting power
    They tried replacing the connecting pins
    No luck so far
  19. Dec 27, 2021 at 8:10 PM
    BilboT34Baggins
    BilboT34Baggins Member
    2013 Tacoma TDR Offroad Automatic. 2.5" lift in the front, 3" lift I the rear, 285/75r16 BFGs
    Bought it with drop bracket lift and BFGs (good find). Took it to a shop to weld on a stock frame bracket to undo the drop bracket lift and install a proper spring lift. Hoping to regear to 4.56 and put on front and rear bumpers in the future. Also, of course hoping for a supercharger someday.
    Any luck?
    I'm having this exact same issue, and I found some resources that can help. If you measure the resistance between the can pins (6 and 14) you should get just over 60 ohms. If one of the two 120 ohm terminating resistors is disconnected it will read 120 ohms. If both are it'll read in much higher.
    If you want to diagnose with an oscope you can, connecting to both the 6 and 14 pins. Here's a site that goes into a bit of detail: https://pmmonline.co.uk/technical/can-bus-fault-finding-tips-and-hints-part-1/
    Also, another forum post on here about a mechanic solving a series can communication issue. https://www.tacomaworld.com/threads/can-communication-issue.571362/.
    I've tried both of the above with no luck. Am going to reset the ecu tomorrow by disconnecting the battery and then driving around for a bit to see if it solves it.
    Wondering if the dealership/shop ever figured yours out??
  20. Dec 27, 2021 at 9:22 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Can you talk to any module on the network?
    CAN systems usually aren't terribly hard to troubleshoot if you have a scope, a DVOM, a capable scan tool, and a wiring diagram.
    First step typically is to see which modules (if any) will communicate, if you can talk to some but not all you need to diagnose the part of the network that won't talk, if you can't talk to anything then you need to check network resistance and if that's good put a scope on it and look at the signals (should be 2.5v to 3.5v square waves on one line and 2.5v to 1.5v square waves on the other line) and go from there.
    b_r_o likes this.
