OBDII Port Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Maticuno, Jan 25, 2014.
  1. Jan 25, 2014 at 5:37 PM
    Maticuno
    Maticuno [OP] Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Due to a recent decrease in fuel economy, I connected my scan tool to look for any pending codes, possibly for the O2 sensors. Instead of any information, my scan tool gives me a "Link Error". I tried disconnecting and reconnecting multiple times with no luck. Thinking it was my scan tool (which works on other vehicles I tested), I borrowed a friend's scan tool...which is giving me the same communication error issue. Now I suspect a problem with the port itself (or, hopefully not, the ECU itself). I searched the forum and came up with this thread:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/240244-obdii-not-communicating-scan-tool.html
    No positive diagnosis was ever found in that thread, which is why I'm making a new one. Does anyone have any ideas? I quick visual inspection of the port shows that all pins are present and don't appear to be deformed.
  2. Jan 26, 2014 at 5:32 PM
    Maticuno
    2011 Suburban 2500
    Anyone?
  3. Jan 26, 2014 at 5:48 PM
    gearcruncher
    Canadain bumper technician
  4. Jan 26, 2014 at 6:05 PM
    gearcruncher
  5. Jan 26, 2014 at 6:06 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Have you ever used that scan tool on your truck before? If so and it did work you might try disconnecting the battery for 10 mins or so and see if that helps? Just a thought. I'm sure someone on here will know much more about it.
  6. Jan 27, 2014 at 12:28 PM
    Maticuno
    2011 Suburban 2500
    I know the power pin is getting power because the scanner turns on when connected and it loads its software. The problem comes when I tell the scanner to check for codes. At that point it tries to link, then says there is a communication failure/error.
    Also, I know it's not the scanner because both scanners (mine and the borrowed) work on every other vehicle I've tried it on.
  7. Jan 27, 2014 at 1:16 PM
    RearViewMirror
    Craig Christ
    Sounds like you narrowed the problem down then.
  8. Jan 27, 2014 at 1:42 PM
    Maticuno
    2011 Suburban 2500
    Only a little. It could be a pin socket slightly bent and not making contact with the scanner plug, it could be a wiring issue not getting the proper signal voltage to one of the many communication pins, and it could be a failing ECU.
  9. Jan 27, 2014 at 1:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Pins 4 (CGND, Chassis Ground ) and 5 ( SGND, Signal Ground ) are grounds.
    Pins 6 high and 14 low are the Can Bus signal wires.
    Pin 16 is the power 12 volts.
    That is all that is needed for OBD II Can Bus.
    Looks like you have an issue with wires ( pins ) # 6 and 14 or the ECU.
    scocar likes this.
  10. Jan 27, 2014 at 2:33 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    are both scanners canbus capable?
  11. Jan 27, 2014 at 2:42 PM
    gearcruncher
    You have 12 volts to power the scanner through pin 16
    Now you have to check for 5 volt signal reference from the ecm ?
    Do you have a digital volt ohm meter ?
  12. Mar 6, 2014 at 6:03 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    In a Gen 2 Taco ther eis an ODB fuse under the hood and they pop all the time for some reason, replace the fuse = fixed.
