OBDII port problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by black coffee, Nov 3, 2017.
  1. Nov 3, 2017 at 3:53 PM
    black coffee
    black coffee [OP] A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    The UltraGauge Blue that I ordered came in the mail today but I can't get it to stay connected to the vehicle computer when it is inserted into the OBDII port. It lights up briefly when I hold it in the port but not enough to detect anything or to pair with my iPhone.
    Any fix to get it to connect in the port? It clicks in place when I put it into the port but it won't stay in correctly.
  2. Nov 3, 2017 at 4:00 PM
    eon_blue
    Azusa, CA
    Does it connect via bluetooth or wifi? I remember when I got mine I thought I had ordered a Bluetooth one but it was a wifi device....had to turn on WiFi instead and have my phone connect to the device's signal.
  3. Nov 3, 2017 at 4:09 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    It is the UltraGauge Blue and connects via Bluetooth.
    When I put it into the port, the lights on the UltraGauge light up briefly when holding it firm. But as soon as I let go, it disconnects and I can't make a connection to the computer or pair it with my iPhone.
  4. Nov 3, 2017 at 4:13 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    I did and I have not seen where that is covered.
  5. Nov 3, 2017 at 4:13 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Sounds like one or more pins got pushed further into the module.
  6. Nov 3, 2017 at 4:14 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    What would be the fix if that is true?
  7. Nov 3, 2017 at 4:18 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    Not too sure, but maybe grab needle nose pliers and gently try to pull on the pins a little?
  8. Nov 3, 2017 at 4:38 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    The pins are perfect.
    I can get it to connect very briefly by pressing on one side of the UltraGauge.
  9. Nov 3, 2017 at 5:18 PM
    eon_blue
    Azusa, CA
    Sounds like it's either a problem with the pins on OBDII tool or a problem with the port on your truck....hopefully it's the latter (most likely). See if you can borrow someone else's to confirm? Or try sending it back for a new one.
    JoefromPTC likes this.
