OBDII Scanner Codes P0303, P0300: how f***ed am I?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mavigogun, Jul 6, 2023.
  1. Jul 10, 2023 at 5:08 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Ok, here is another explanation.
    That is oil, and your spark plugs are not sealing properly.
    Remove and replace plugs, boots or wires, and valve cover gaskets.
  2. Jul 10, 2023 at 5:36 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Polish your valve cover as much as you want!!
    I use the crank bolt to move the engine your right there and look easy rather then walk back and forth .
    With a camera you should be able to look at the pistons and valve seats not sure how good you can see depends on the camera set up.
    Why did you replace the radiator?
    good luck!
  3. Jul 10, 2023 at 5:46 PM
    wrightme43
    Seriously I think some people come on here and get joy out of freaking people out about some terrible scenario.
    If you need to identify the substance, mix it with water, if it floats it is oil/petrochemical based.
    If it dissolves in water it is alcohol/water/glycol based.
    Just swap the gaskets, plugs, and boots or wires.
    Use Denso or NGK plugs and QUALITY gaskets and boots or wires.
    Mavigogun[OP] and wayupnort like this.
  4. Jul 10, 2023 at 6:31 PM
    wrightme43
    Now after you get done with that, and if it still misses, we will help you come up with a plan. Do the simple stuff first.
    Mavigogun[OP] likes this.
