Object in tire - to fix or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Psycho2, May 20, 2017.
  1. May 20, 2017 at 9:26 PM
    Psycho2
    Psycho2 [OP] Well-Known Member
    AZ
    '16 DC TRD Sport Barcelona
    Parked at the store today, as I was walking up to the pickup, I noticed something in my tire. Often little rocks will get stuck between treads, so it's nothing to worry about.
    This time I noticed this:
    Looks like a fencing staple that has been worn down.
    I did have the 30K service today, they must not have noticed this when the tires were rotated, or it happened in the ~100 miles between.
    Based on where it is located, I feel so long as it stays put, it won't cause any issues. Should I be worried about it staying in the hole it has created, and get this fixed?
  2. May 20, 2017 at 9:30 PM
    jgw
    jgw Yapping for over six decades
    Joe
    Western Montana
    2017 Tacoma Double Cab 4X4 TRD Off Road Quicksand
    Ultra flex tonneau, bed mat, Ionic nerf bars, weathertech mud flaps and floor mats
    I'd remove it. Chances are you're right and it would do no harm, but it would bother me.
    wilcam47 likes this.
  3. May 20, 2017 at 9:31 PM
    InfernoTonka
    InfernoTonka Infernal Order of Knights Templar of Inferno-ness
    TOD aka Toyota Onroad Development
    2016 Inferno SAF base model SR5 4x4
    That would drive me nuts knowing it's there. Just keep monitoring your tire pressure sensor display. If it goes down then definately get it fixed.
    9TRDTCO and shakerhood like this.
  4. May 20, 2017 at 9:32 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I would get it fixed. If and/or when it decides to go, it will be at the most inopportune time. Its away from the sidewall so should be fixable???
    HutchJ, InfernoTonka and shakerhood like this.
  5. May 20, 2017 at 9:39 PM
    03 NIGHT TACO
    03 NIGHT TACO Well-Known Member
    Jack
    Eastern Washington
    3.4 5 speed TRD
    Kings/Dakars/ARB
    I'd drive to your dealer, or to a trusted tire repair shop, and pull it there. That way, if it starts leaking, you can get it taken care of on the spot. If not, then you can monitor it for a few days, or maybe it won't leak at all.
    20tacoma17 likes this.
  6. May 20, 2017 at 9:57 PM
    tcjacado
    tcjacado Well-Known Member
    Would drive me crazy. Get if fixed for the 15 or 20 bucks for the patch.
  7. May 20, 2017 at 11:33 PM
    AWDDude
    AWDDude Well-Known Member
    2017 Tacoma TRD Off Road DCSB, QuickSand
    Tacowin1013, chucklefunkk and TomTwo like this.
  8. May 20, 2017 at 11:45 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    The longer it stays lodged into the tread there's a good chance if it has penetrated the cord that it is causing more damage
  9. May 20, 2017 at 11:49 PM
    Mike_Lowrey562
    Mike_Lowrey562 Well-Known Member
    Long Beach, CA
    2016 TRD OR MGM
    I would get it taken car of right away..
  10. May 21, 2017 at 3:05 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Yea just take it to a shop and have them patch it for a few bucks.........
    Also have them give you an alignemnt, your tire is wearing terribly!
  11. May 21, 2017 at 3:16 AM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    If you drive over 15 to 20 mph then you need to fix it. Kaufman Tire will fix it for free.
  12. May 21, 2017 at 4:27 AM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    Spray it with some soapy water an see if it bubbles. If it is not leaking just pull it out. If you leave it. I will slowly cause more damage. Get it fixed.
    rolled93slc likes this.
  13. May 21, 2017 at 4:47 AM
    redbird48oo
    redbird48oo Well-Known Member
    Greenville, SC
    2017 Tacoma SR Access Cab, 2.7 with auto GREAT TRUCK
    heck thats nothing, 3 weeks ago had to replace a tire......ever run over a pair of plyers? Was no fixin that puppy, took off spare and put on rim put new tire on spare wheel. 4500 miles was all that was on that tire. funny at first i thought the rearend was gong bad, before the light on dash cam on lol.
  14. May 21, 2017 at 4:52 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I'd 2nd this. If you are going to pull it, do it in a tire shop parking lot.
    03 NIGHT TACO[QUOTED] likes this.
  15. May 21, 2017 at 5:05 AM
    Ledfoot 26
    Ledfoot 26 Well-Known Member
    16 TRD OR 4x4 Barcelona Red
    No big deal, I have a plug kit I keep in my truck it takes 5 Minutes....
    rolled93slc and 4x4Runner like this.
  16. May 21, 2017 at 5:35 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    spray some soapy water on it and see if it leaks, if it doesnt then first get a patch kit, we had one of these at a motorcycle shop I worked at for a bit and it worked great, dont see why it wouldnt work on cars but you should check first, after getting a patch kit, use some wire cutters to remove the staple(not cutting it but using them to grip and leverage it out), listen and spray more soapy water where the staple was, if no soap bubbles build up there you should be fine, if they do then insert a patch, reinflate the tire and check for leaks again.
  17. May 21, 2017 at 5:38 AM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    Wise.
    I always carry a plug kit and a small compressor. If not you, there is always someone else that will need it.:thumbsup:
    Ledfoot 26[QUOTED] likes this.
  18. May 21, 2017 at 5:39 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Pull it and patch it.
  19. May 21, 2017 at 6:23 AM
    SWB Tacoma
    Arkansas
    Take some pliers an move it around while spraying it. If it is bubbling leave it an go get it fixed. If not pull it out if you don't have any doubts. Best thing to do is take it to a tire shop. Go from there.
  20. May 21, 2017 at 8:02 AM
    habanero_taco
    habanero_taco Well-Known Member
    Randy
    2016 Tacoma TRD Sport
    OVTuned
    I'd fix it, or have it looked at, maybe it would never cause an issue, maybe when your out in the boonies on a cold rainy night your tire goes flat, better safe than sorry!
