Obnoxious Front End Chirp/Squeak. Please help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poolstick, Apr 4, 2015.
  1. Apr 4, 2015 at 1:17 PM
    Poolstick
    Poolstick [OP] Well-Known Member
    When driving over about 10MPH, every bump I hit with my front end makes a terrible chirping noise. I can't seem to recreate it by bouncing it, kicking it, or shaking it.. I've never made my truck move so much while in park. Running 5100's set at 1.5 and a Relentless skid up front - everything else is stock.
    I've tried dry-lube on the suspension components and that might've made it worse. Also tried on some of the metal-metal connections where the frame meets the body, where the skid plate meets the frame, etc. Nothing changes! I can only hear it when the windows are down.
    What can I do to eliminate this chirp? I know it's not the back end, as I've already had and dealt with that problem. I definitely only hear it when the front end hits, and usually when it's moving upwards, not down. I've also had the wheel bearings replaced in the last few months, so I really don't think it's that. Shaking/moving the wheel pretty hard recreates no sound, so that makes me feel a little better.
    These trucks and their squeaks - for a 2010, I think this is a little ridiculous!
    Edit: Ignore my picture - got the stock bumper back on now.
  2. Apr 4, 2015 at 1:25 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    mine squeaks like crazy after snow wheeling. :confused:
    I think its my dust boots. I usually just spray a shit load of lubricant and that takes the squeaking away for awhile
    Good luck man
  3. Apr 4, 2015 at 2:09 PM
    stractman
    stractman Well-Known Member
    Colorado
    07 DCSB TRD sport, 4x4
    mine does this exact thing. i discovered that my uca "ball-joints" (icons) are the culprit. you have stock ucas, most likely the same.
    several threads on tw discuss this, we just have to deal with the squeaks after rains/washing/water and dry-lube the components. it lasts for a while until it gets soaked again.
    i've learned to deal with standard taco creaks and groans but the uca joint squeak is the most annoying sound in the world.
    good luck isolating and solving the noise.
  4. Apr 4, 2015 at 4:58 PM
    Poolstick
    Yeah - do you just blast dry lube into your ball joints? The dust jackets on both of mine seem to be torn (no idea how, been that way for a pretty long time). Is it detrimental in any way do do that? Can I accidentally push out necessary stock grease?
  5. Apr 4, 2015 at 5:59 PM
    stractman
    Colorado
    yes.
    no.
    you shouldn't grease it, it attracts everything. grease bad.
    you should do what these threads suggest, dry film lube good. tri-flow.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/309217-creaking-noise-up-front.html
    http://www.tacomaworld.com/forum/suspension/367158-uniball-vs-balljoint.html
    we live in colorado, which means constant moisture from rain, snow, and the crap they fling on roads. ours will squeak way more than others who live in temperate areas.
  6. Apr 4, 2015 at 7:08 PM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    Try adjusting your hood bumpers and give them and the contact points of the good a light film of grease. I had a squeak for months I couldn't track down and swore it was the suspension, ended up being the hood.
    njcoma likes this.
  7. Jun 3, 2016 at 1:35 PM
    mmarrrnold
    mmarrrnold Well-Known Member
    Vista, CA
    2015 TRD Offroad DCSB
    SCS Ray 10s - Brushed Copper 285/70/17 Nitto Ridge Grapplers Icon 2.5 Coilovers + JBA UCAs Dakar Leafs + OME Nitros Relentless Fab Rear Bumper Some lights
    I've had the same problem for months. Been adding dry lube daily and can occasionally get it to quiet down a bit, but that only lasts a day or so. I've also lubed the UCA at all points, LCA, shock mounts, and greased the tie rod end. Out of ideas at this point so it looks like the lube will just be daily maintenance...
  8. Jun 3, 2016 at 5:44 PM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Try pb white lithium in the spray can on the lower shock bolt. That's where my noise was coming from and I'm running 5100 set at stock height. I could reproduce my noise by rocking the truck back and forth though so who knows.
  9. Oct 13, 2016 at 12:40 AM
    300AACTaco
    300AACTaco Well-Known Member
    Alaska
    Black '15 DCSB TRD Off Road 4x4
    ARB Old Man Emu 90000s and 60091s OME 886s, Trim Packer, Icon Tubular Uniball UCAs, CMC, Invisible Sway Bar, Dakar Rear Leaf Packs, Timbren Rear Bumpstops, All Pro U-bolt flip up kit, Method Race Wheels NV 16X8 4.5BS, Cooper ST Maxx LT285/75/16, DEPO Black Tail Lights, Weathertech Floormats, Cascadia Vehicle Tents Mt. Shasta in Earth Tone Green, Custom Green Tree Fabrication Bed Rack, N-Fab Spare Tire Bed Mount
    My front end squeaks CONSTANTLY while driving, just started a few days ago, doesn't matter if I'm going over a bump or driving on flat road, it's a constant squeak. From 1mph to 70mph I can hear it. Super annoying.
  10. Oct 13, 2016 at 12:43 AM
    njcoma
    njcoma Well-Known Member
    California
    2017 Accord Sport Special Edition
    Previous: 2006 Tacoma SR5 Prerunner: 2010 4Runner sr5 Rims, TSB rear leafs, Wetokole neoprene seat covers, JVC LED color matched head unit, scanguage II, Flowmaster 40 cat back exhaust, hankook dynapro atm tires, Class 4 Uhaul Hitch. Kicker 12 inch sub and amp. Focal speakers. jba offroad UCAs.. Detroit truetrac rear end... bilstein 5100 rear and 6125 front coilovers. Nfab front bumper with KC apollo lights, bed lights, bluesea systems fuse box....lots of painted stuff.
    Yep.. one of my hood bumpers fell off during an pil change and I didnt notice.. made the hood slightly crooked and squeeked....
    I found that if you buy one of those rubber weights from a sporting goods store..and Dremel out a square.. it works perfectly.. did the same to my tailgate when it squeeked too.
  11. Sep 16, 2024 at 10:57 AM
    deangrande45
    deangrande45 Well-Known Member
    Dean
    2021 SR 2WD Black
    Hey man not sure if you are still active on here but could you elaborate on this? I figured out the squeak is my hood but I don't know what part. I don't know if it's the latch or other parts. I checked everything and nothing is missing.
