Obnoxious Squeaky noise thoughts?...
Discussion in 'Suspension' started by Superhulk LB, Dec 22, 2020.
  1. Apr 13, 2021 at 3:08 PM
    #41
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    That would be pretty annoying... hope they get you a fix soon.
  2. Apr 17, 2021 at 4:26 PM
    #42
    Superhulk LB
    Superhulk LB [OP] Well-Known Member
    Josh
    Oregon
    2019 superwhite DCLB off road
    Tonneau cover, Black exhaust tip, blacked out badges and tailgate lettering. Black rhino(glamis)18x9 wheels with +12 offset. LT265/70/18 Toyo Opencountry ATIII. Metaltech 4x4 rock sliders Cali Raised lower grill light bar/mounts TRD Pro Skid, DD Fogs(pro), Ironman 4x4 FC pro lift.
    So I’ve been spending more time trying to figure the squeak out. I loosened my top strut bolt. The one in the middle of the strut. With it loose and the pressure of the bushing, the noise was gone. mill have to get a new bushing to confirm. But this is the first time I’ve got the noise to go away.
    hyrule_trd likes this.
  3. Apr 17, 2021 at 5:41 PM
    #43
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Thats pretty interesting. Could the order be wrong for the bushings and washers?
  4. Apr 17, 2021 at 5:52 PM
    #44
    Superhulk LB
    Josh
    Oregon
    Guess that’s possible. A shop did the install. Now that I found the noise, I am a little more optimistic of getting it resolved.
    hyrule_trd[QUOTED] likes this.
  5. Apr 17, 2021 at 8:39 PM
    #45
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    We’re yours prebuilt from IM? I’m not sure you’d be able to see if the bushing is good under the top hat.
    Maybe a bad bushing, maybe something it’s rubbing on in there. Could try a little rubber safe spray and see if that helps. Try and spray under as well.
  6. Apr 27, 2021 at 2:13 PM
    #46
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    UPDATE SOLVED: Ended up being the spherical bearing for my King's (fronts) where they bolt to the lower control arm (part number B1058 for those looking). Squeak / creak is now 100% gone. Jimahajer Garage in La Habra diagnosed it and I just had them do the bearing swap since they were very familiar with doing it and I just wanted the squeak gone ASAP. Definitely would recommend them, they had some sweet rigs at the shop (fyi, they said they're moving locations to a bigger shop this week and will be opened back up soon).
    https://www.yelp.com/biz/jimahajer-garage-la-habra
    tcjacado and hyrule_trd like this.
  7. May 24, 2021 at 8:49 PM
    #47
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    @Superhulk LB .... I think we have the same horrendous squeak. I installed the parts myself so I'm pretty sure I have the bushings on the top mount correctly installed. I suspect it's the UCA bushings.
    You had the IM's UCA's ball joints replaced to no effect?
  8. May 24, 2021 at 9:01 PM
    #48
    Superhulk LB
    Josh
    Oregon
    Correct. After they were changed the noise was exactly the same. After that I played with the top hat.
    Fletcher37[QUOTED] likes this.
  9. May 24, 2021 at 9:19 PM
    #49
    Fletcher37
    PNW
    I think I'll try to pull out the UCAs tomorrow. Relube it all and shove it all back in. The UCAs were the crappiest part of the install given the bolts are long and hard to remove w/o bending metal body parts.
    If that fails, I'll disconnect the sway bar and see if the squeak goes away.
    If that fails, I'll burn the truck to the ground and see if that helps. :annoyed:
  10. May 24, 2021 at 9:22 PM
    #50
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Y'all are making me want to ditch the UCAs and go with another brand for them. I've got all the other parts sitting while I wait on the back ordered UCAs, but I'm starting to think I should go JBA and sell the ironman ones whenever they show up.
  11. May 24, 2021 at 9:43 PM
    #51
    Superhulk LB
    Josh
    Oregon
    The UCAs have not been an issue on mine, for what it’s worth.
  12. May 25, 2021 at 4:10 AM
    #52
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Good luck figuring it out. Maybe it’ll end up being something easy. Have you retorqued everything?
    I went with SPC and have been happy. I got my kit back in July/Aug and only got the stage 1 for a few reasons. I had always planned on getting the SPCs after reading about them (and didn’t have the extra cash when I bought the kit for the stage 2). Has worked out well for me so far. I had looked at JBA but some tire wheel combinations don’t work.
    Jojee117[QUOTED] likes this.
  13. May 25, 2021 at 4:35 AM
    #53
    Dmeezy333
    Dmeezy333 Well-Known Member
    2015 White Tacoma TRD Sport
    I had the same issue after I levelled up my truck. The shock was rubbing up against the sway bar.
  14. May 25, 2021 at 9:24 PM
    #54
    Fletcher37
    PNW
    Okay. I think I've found my squeak... Driver side UCA ball joint rubber boot has a small tear. Was almost dry inside and super loose-goosey. I put in 10ml red grease and drove a bit. No squeak! Now I either warranty them if I can or buy different UCAs or just replace the ball joints.
    https://youtu.be/zlVd01r7AOc
    ohcaltexscar and hyrule_trd like this.
  15. May 25, 2021 at 10:35 PM
    #55
    Superhulk LB
    Josh
    Oregon
    Try and warranty them!!! Ironman is good about standing behind there products.
  16. May 26, 2021 at 4:04 AM
    #56
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Good find. Fill ‘er up with grease and plasti weld that shut lol, j/k... Get them to replace it, if they will.
    Superhulk LB[OP] likes this.
  17. May 26, 2021 at 12:57 PM
    #57
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Or just replace the boot?
  18. May 26, 2021 at 2:56 PM
    #58
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Key-Rei and LC7[QUOTED] like this.
  19. Jun 1, 2021 at 7:34 PM
    #59
    mac2165taco
    mac2165taco Member
    Tom
    17 Tacoma TRD Offroad
    Camburg UCA/ King 2.5 coilovers w adjusters
    I can bet you that the creak is from your LCA. I chased this creaking problem for months. It turn out my left lower control arm sleeve is rusted where the cam bolt goes through it. You have to remove the cam bolt to grease the sleeve. I replaced with new LCA thinking it was bad ball joint. You can take it to alignment shop to ask them to remove the bolt to grease it . Creaks no more!
  20. Jul 25, 2022 at 9:59 AM
    #60
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    :rofl:
    I’ve been there my friend
