Observations on the Entune system with a flash drive
Discussion in '3rd Gen. Tacomas (2016-2023)' started by old-timer, Mar 26, 2016.
  1. Jan 31, 2018 at 12:55 PM
    #61
    BBPSR54X4
    BBPSR54X4 Well-Known Member
    2017 SR5 DCSB 4x4
    Thanks OP. Got my Music Library loaded and working. Great Info.
  2. Feb 21, 2018 at 4:11 PM
    #62
    cmillls45
    cmillls45 Well-Known Member
    Minneapolis, MN
    Sorry if these are dumb questions.
    1. Can I just rip cds right to iTunes and it will be in the correct format?
    2. Will I be able to rip successfully even if I didn’t purchase the music from iTunes?
    3. Lastly, do you guys do the folder structure right in iTunes (artist, album, song title) and then copy all the folders onto the USB drive?
  3. Feb 22, 2018 at 10:42 AM
    #63
    axepilot
    axepilot Active Member
    Dan
    '16 SR5 DCSB Quickie
    You dont "need" iTunes but it is helpful for tagging song files.
    Ripping from CDs using iTunes will convert to mp3 if you set it up thst way in the iTunes settings. Mp3 will definitely work but other formats may work as well.
    "Ripping" by definition is pulling the song from a disc which implies you have the disc so, yes, the songs will play. Any mp3 (and possibly other formats) regardless the source will play. As I said, iTunes is not required.
    Folder hierarchy isnt required either. You could put all your songs on the drive with no folders at all but I would be pulling my hair out trying to sort or manage the files that way. The system will still read the song files and categorize them based on the data in the ID3 tags. But, since you asked, yes I like Artist, Album, Songs... seems the most sensible approach.
  4. Feb 22, 2018 at 10:43 AM
    #64
    axepilot
    Dan
    Oh... ITunes won't manage or create your folders, you have to do that yourself.
  5. Feb 22, 2018 at 1:18 PM
    #65
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    You do know you can just say "play artist z z top", right? (I know sometimes it doesn't work... and I don't think Cajun is a language option.)
    ...or press browse, quickly press the WXYZ button 4x to get to Z, then select ZZ. I know that is 6 taps; but, I view it as a quick three step process.
    I guess they intend for you to use the voice control; but, like you I would like the option to browse from the wheel. I rented a lower trim Camry and put my USB drive in it. It did not have voice control; instead, it had a control pad (up, down, L, R, select, back like the one on the other side of our wheels). You could browse and select like you and I want. I have a grand vision of one day converting my wheel to work like the Camry poverty trim. I suspect the head unit has the functionality built in and it is just a matter of finding the right pins to swap.
  6. Feb 22, 2018 at 2:26 PM
    #66
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    No!!!! I absolutely did NOT know that I could just say "play artist ZZ Top", in Cajun (or Yat for that matter). How does this work with AC/DC or Queen or such, when there are about a dozen albums under each artist? I guess it would be way to easy to just say "next folder"?
    Just this morning I was trying once again to find a button or knob to increment or decrement through folders without having to resort to stepping through the menus WHILE DRIVING. If it's unsafe to view a text on-screen while driving it certainly has to be unsafe to step through menus too, right TOYOTA?
    My other vehicles have a knob that scrolls through folders, and using the up/down select button on the steering wheel advances to the first song in folder "B" if you advance past the last song in folder "A". I still think this truck did that 6 or 8 months ago prior to one of the updates. I know it used to allow viewing a text message on-screen while moving until fairly recently.
    Anyways, thanks for the tip about voice control... I'm going out to try that now . . .
  7. Feb 22, 2018 at 2:30 PM
    #67
    Tharris242
    Houston, TX
    I think it will just play all songs by that artist.
    or you can say...
    "play album back in black"
    "play song back in black"
  8. Feb 22, 2018 at 2:47 PM
    #68
    BBPSR54X4
    2017 SR5 DCSB 4x4
    I have my hierarchy as follows ...
    Artist - Album - Songs
    So -
    The Beatles in the root of USB drive, in The Beatles folder Abby Road, Magical Mystery Tour, etc. Then the songs in each album folder.
    ZZ Top in the root of USB drive, in ZZ Top folder Tejas, etc. Then the songs in each album folder.
    etc, etc.
    I can lookup and play by artist or album.
    I used Windows Media Player (Windows 10) to copy the songs from CDs to MP3s on my hard drive and get the ID3 tags.
    Suggestion: place a couple of artists/albums on a USB using your PC. Plug the USB drive into the dash and see if everything displays and plays as expected. Then copy the rest.
  9. Apr 9, 2018 at 8:55 PM
    #69
    BlackSabbathTacoma
    BlackSabbathTacoma Well-Known Member
    2016 TRD OFF ROAD - BLACK
    sorry for the old dig.
    two questions:
    When you do this still limited by the file types?
    Does this recognize artist and the album down to songs?
  10. Jul 4, 2018 at 7:36 PM
    #70
    crash13
    crash13 Member
    Arizona
    ok guys, so either I'm Feeling like i'm the least tech savvy person alive. I've already tried THREE different thumb drives, and every time i plug it into my 2018 Taco it only reads some of the songs. I barely have 1000 songs on the drive. One drive i plugged in it only read ABC and TUV songs. WTF. the other two i tried did sorta teh same thing. I'm have a MAC computer and using iTunes on it. The songs i have are a mix of CD's i've uploaded, and songs i've down loaded or purchased off of iTunes. I believe all are MP3 or AAC "format". HELP a lady out please.
  11. Jul 27, 2018 at 12:57 PM
    #71
    Loaded NightraiN
    Loaded NightraiN Well-Known Member
    17 TRD Off Road
    So has anyone found a good way to randomize songs, without repeating?
    I like to keep a few hundred songs on a drive, and hear each song once before repeating any
    In my old aftermarket unit, I would randomize the filenames with padded numbers. This does not matter with Entune, as it seems default playback is alphabetical title, not filename. The random feature is only good until you turn the vehicle off.
    Any ideas?
  12. Aug 3, 2018 at 2:50 PM
    #72
    lruss
    lruss New Member
    #72
  13. Aug 3, 2018 at 5:04 PM
    #73
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Maybe there is an app for your phone that is better suited for audiobooks, and you could listen via bluetooth?
    #73
  14. Aug 3, 2018 at 5:33 PM
    #74
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    I just play by song title, that's pretty damn random.
  15. Aug 3, 2018 at 5:37 PM
    #75
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    This^
    I just go to Audio>Bluetooth/USB>Songs>choose Any random song>play>hit RAND in the screen to shuffle to a RANDom song..
  16. Aug 10, 2018 at 9:41 AM
    #76
    Loaded NightraiN
    17 TRD Off Road
    Problem with that is next time you start the truck, it doesn't remember what was played before. After a few days, you get a lot of repeats. After a few weeks, there are songs you never hear. This is a common problem with all MP3 players really. But most of those play by filename, and those were easy enough to randomize.
    I just found "Mp3tag" that works perfectly! Add your directory, and you can randomize your tracks, with one click. Then you can add sequential numbers in front of the title. From there your truck will play them in that order. Right where you left off each time!
  17. Sep 3, 2018 at 12:37 PM
    #77
    Mt452
    Mt452 New Member
    If you use a program to manage your music like Mp3Tag you can edit the tags on each song in order to create a "playlist" that entune will recognize. For example inside Mp3Tag (this is the program I use) select a song you want to add to a playlist. Then under the 'Genre' tag I simply alter that tag from 'Rock' or 'Alternative' to the playlist name (80's Rock) I want. Then once the USB is loaded in your truck, select Genre and then the playlist you have named (80's Rock). Bam... playlist cranking...
  18. Dec 25, 2018 at 4:30 PM
    #78
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I have 13,000+ on my 128GB UltraFit drive. I have the Entune w/nav in my T4R. Probably one of the first stock head units I've liked. I didn't realize there was a 9999 file limit though. I though maybe not all of my music had copied over to my drive, so my music collection basically stops after the letter S.
    My folders are arranged in "Artist" > "year - album" > "track# - song title"
    Other than the file limit, I wish it would put the albums in chronological order. Would also be nice if it would move onto the next album instead of repeating the current album.
    I have the album artwork embedded in the files at 500 x 500px and they display fine. I also wish my unit had the time on it, instead of a separate clock above it.
  19. Dec 26, 2018 at 5:50 AM
    #79
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    It does, if you choose to play "by artist". It will advance to the next album by the same artist. But then it would be nice if you could quickly scroll up or down through folders using the tuning knob instead of having to resort to menus on the touchscreen or using voice commands. Often, I don't KNOW what I want to hear next... I just want to scroll though until I decide to stop on something.
  20. Dec 26, 2018 at 9:33 AM
    #80
    replica9000
    2019 T4R ORP
    Yeah I didn't try that. Artist > All Songs does load all of the albums. The tuning knob lets me scroll through the list, or skip through the songs quickly. Between the tuning knob and the steering wheel controls, I barely need to use the touchscreen.
