Obvious knocking during low throttle acceleration between 1000 - 2000 rpm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BONTONWHO, Sep 28, 2008.
  1. Sep 28, 2008 at 10:55 AM
    BONTONWHO
    BONTONWHO [OP] Active Member
    Caliwaii
    05 PreRunner 4.0
    I have an 05 PR 4.0 Automatic with 84000 miles. At about 45000 i noticed a knocking between 1000 - 2000 rpm. Usually coming out of high throttle slowing for a hill or coming out of a stop. Im not a mechanic and my terminology could be incorrect. I took it to my dealer a few times and they finally adjusted my intake hose. I knew about this TSB and its more of a knocking noise from the engine not a clicking noise. It hasn't gotten worse but I'm beginning to loose acceleration power and Im about to do my 90000 service. Any idea or suggestions to better explain to my master mechanic what it is thats going on with out sounding like a pain in the a$$ customer? Your input is appreciated for sure!! Shoots
  2. Sep 28, 2008 at 12:23 PM
    red06toy
    red06toy Well-Known Member
    Worcester MA
    Impulse red OR, 2.5 lift
    2.5 toytec, bilstein 5100 black grille, black lights, partially shaved decals remaning ones black, , trd fj wheels, sirius, Ipod interface, pre-filter delete
    my first question is have you changed your plugs yet? These plugs need to be replaced at 30k. If you started hearing knocking at 45k that makes sense. My truck started at 35k. If you have changed them try running plus or premiun gas. If that doesnt work bring it to the shop. i have a feeling your plugs are toast tho. And FYI toyota used 3 denso and 3 ngk plugs on our trucks. no one seems to know why
  3. Sep 28, 2008 at 1:29 PM
    BONTONWHO
    Caliwaii
    05 PreRunner 4.0
    thanks for the reply.. SPs were changed at my 60000 service. Damn- I wonder what it could be? Just drove to score some grub for the Padre/Charger game and heard it again!! BUMMER
  4. Sep 28, 2008 at 1:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    maybe ask the mechanic when you go in for the 90k service if the valves need to be adjusted. is it more of a knock instead of a ping. you could have spark knock, which it sounds like that may be the case. you can try a higher grade of gas and run some techron thru the tank to see if that takes care of it, and also, time to change the plugs again. if it happens to be spark knock, the higher octane gas should fix that. hope this helps you out man, and you get it squared away quickly!!:)
  5. Sep 28, 2008 at 2:01 PM
    BONTONWHO
    Caliwaii
    05 PreRunner 4.0
    i'll try higher octane and be sure to mention "spark knock" to my master tech. Thanks for the help!
  6. Sep 28, 2008 at 2:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man. let us know what you find out!!
  7. Sep 28, 2008 at 2:08 PM
    BONTONWHO
    Caliwaii
    05 PreRunner 4.0
    I will for sure. Im sure others have this issue too. I'll be taking my truck in this week. Im trying to get it all dialed before shipping it off to the islands. I'll keep up dated. thanks again
  8. Sep 29, 2008 at 9:20 AM
    red06toy
    Worcester MA
    Hopefully its an easy fix, its prob one of the things mentioned good luck
  9. Sep 9, 2013 at 3:22 PM
    benq
    benq Active Member
    Surprise, AZ
    2010 Doublecab, Shortbed, TRD Offroad
    Borla Turbo XL muffler TRD air filter
    Try reading up on this thread, might give you some options. My "fix" is to use 91 octane gas.
    2012 v6 at DCSB engine knocking @ 1500 rpm
