OBX Racing Headers
Discussion in 'Performance and Tuning' started by 05PreRunner, Mar 25, 2008.
  1. Mar 25, 2008 at 9:39 AM
    05PreRunner
    05PreRunner [OP] "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
  2. Mar 25, 2008 at 9:42 AM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    there are better options for short tube headers in the price range, JBA or Doug Thorley
  3. Mar 25, 2008 at 9:44 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    It says no weld installation, but I don't see bolt holes where the cat goes. If I were going for headers, I'd be getting the doug thorley long tube headers that remove the front set of cats. They are a true bolt on connection. You might have problems with emissions testing though since you are in in Cali
  4. Mar 25, 2008 at 9:53 AM
    05PreRunner
    <-(714)-> SO-CAL
    yup, that's what i was thinking.......i hate california's emission rules.
  5. Mar 25, 2008 at 4:45 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Anyone know the emissions laws in North Carolina. What does an inspection station check for in this state. I dont want to eliminate cats and then be rejected for saftey inspection sticker...
  6. Mar 25, 2008 at 5:04 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    check this site, its for north carolina. http://www.dmv.org/nc-north-carolina/smog-check.php by the way, you coming to our tacoma meet at uwharrie at the end of april??
  7. Mar 25, 2008 at 5:21 PM
    roxspin72
    NC
    Oh Yeah!!!
    by the way, you coming to our tacoma meet at uwharrie at the end of april??[/quote]
    Yup, but will have to wait til I get back to work on monday, to give my final confirmation...
  8. Mar 25, 2008 at 5:27 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  9. Mar 25, 2008 at 5:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Yup, but will have to wait til I get back to work on monday, to give my final confirmation...[/QUOTE]
    alright,cool!!! gonna be a good time!!
  10. Mar 25, 2008 at 6:06 PM
    roxspin72
    NC
    Oh Yeah!!!
    WOW!!! Looking at that it seems like I will not be getting Doug Thorley long tubes.
    I want the sound and improved performance of Headers but not the penalty of failed emissions.
  11. Mar 25, 2008 at 6:10 PM
    The_Hodge
    SC
    the shorty jba's or obx's will keep the front ones and u can either have someone cut out the rear cats and piece some in piping....or get the urd y-pipe and it takes out the reat cats and has a place for the back o2 sensor to screw in. neither way of taking out the back ones will throw codes during testing.
  12. Mar 25, 2008 at 6:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, you just need probably a y pipe from urd, like jhodge said, that wont throw a cel code. shorty headers with o2 simulators may be the way to go.......you'll pass emissions, and you will have extra sound/power.
    eidt:.....actually, forget paying that much for the y pipe.....just get someone to cut out the rear cats and install straight piping there, it wont throw a cel either because the o2 sensors are behind the last 2 cats. then do the headers with the o2 simulators......pass emissions without any problems i'd think.
  13. Mar 25, 2008 at 6:26 PM
    The_Hodge
    SC
    w/ the shorty headers, u dont have to get o2 sensors. i'm pretty sure that they weld in before any of that mess. tacorock didnt say anything about o2 sensors w/ his.
  14. Mar 25, 2008 at 6:31 PM
    roxspin72
    NC
    Oh Yeah!!!
    Ok here we go, hope no one gets mad, but I need questions answered and could not find much in forum.
    Shorty headers JBA: emissions legal/but need welding of stock cats? So, why not replace front cats w/high flow cats to weld to headers/purchase Y pipe, cant use straight pipe cause of my Borla cat back. Instead, remove stock rear cats. Question, this set up W/O2 simulator, will I pass emissions?
    Also, if this is true are the JBA Headers of any quality? I heard lots of mixed opinions.
  15. Mar 25, 2008 at 6:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, i think you are correct!!
  16. Mar 25, 2008 at 6:41 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you say you cant use straight pipe for the 2 rear cats because of your borla catback. the catback should be basically on after the rear cats, then a little more piping right?? so you could use straight pipe there. all the y pipe does is eliminates the rear cats, basically from right where the rears bolt up, to where your borla is bolted on, so you should be fine with two pieces of straight pipe in place of the cats.........its essentially the same thing. and as far as the jba's.....i have heard mixed results also. i still think thorleys are the way to go.......even if you had to have o2 sensor simulators, and you should be able to pass emissions.
  17. Mar 25, 2008 at 6:49 PM
    roxspin72
    NC
    Oh Yeah!!!
    Ok, so now Im catching on. If I want the Doug Thorleys, all I have to do is install the O2 simulators and the inspection station should pass me for emissions test?
    How does this work, and or, has it worked for anyone???
  18. Mar 25, 2008 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    basically, all they are doing is checking for emissions. o2 simulators will make their diagnostic tool read what "should be", while its actually "not", therefore passing emissions. at least thats the way im pretty sure it works.
    and yes.......you are catching on indeed:D!!
    here, check this out.,.........this is basically what a o2 simulator does!!
    http://supersoda.com/detail.php?id=00000000079
  19. Mar 25, 2008 at 6:55 PM
    The_Hodge
    SC
    u should be ok if u get the long tubes, as long as u do the o2 simulators. urd sells those as well i believe. for emissions here, they pop in a scanner and make sure ur throwing no codes. if u really want a down and dirty on what u can get by w/, go by ken's muffler shop here in fayetteville by the sams slub enterance and talk to the 40ish y/o looking guy w/ brown hair/mustache and he'll give u the down and dirty of what u can get by w/...especially if u want them to do any work. i asked them about getting them to cut out the rear cats and pipe it in and they said that by law they couldnt touch anything already there from the factory. but i mentioned to him about the y pipe and he said that'd be the best way to go. they welded on my sliders and welded my piping on my magnaflow exhaust b/c the catback came w/ the glorified hose clamps and they were leaking at the muffler on both sides.
  20. Mar 25, 2008 at 7:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    man......what the hell happened to our quotes??? all these are kinda messed up!!! wtf??
