OBX Sand?
Discussion in 'South East' started by dpak, Apr 27, 2011.
  1. Apr 27, 2011 at 8:34 PM
    dpak
    dpak [OP] Well-Known Member
    Richmond, VA
    09 4x4 TRD Offroad DCSB
    Eibachs w/ 5100's set at 0, Rear TSB, TRD Catback Exhaust, SCS F-5 Matte Gray Wheels, 265/75/16 Hankook Dynapro ATM Tires, Elusive Elements Mesh Grill
    Hey - just curious what type of sand is on the beaches of OBX? Is it the sugary sand type? Just checking to see if my Prerunner stands a chance in OBX.
  2. Apr 27, 2011 at 8:42 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    there is a link here about going down to 15psi and having good luck.
    i have taken my 4x4 taco to OBX twice. i aired down to under 20psi and had no issues. my buddy refused to air down his 4x4 tundra and he did ok but not nearly as good. i would be nervous with 2wd but if you go with someone with 4x4 you should be ok, the tow guys out there charge an arm and a leg to get you unstuck
  3. Apr 27, 2011 at 8:44 PM
    Caduceus
    Caduceus Well-Known Member
    the Lowcountry
    09 DCSB TRD 4x4
    For the most part it's "regular" beach sand. Nothing too spectacular. You'll be better if you drop your PSI, but you're probably OK running 30PSI... Just avoid the reddish-color, that stuff is big, fluffy, and can suck you down. Depending where you get on, there might be a small dune on the entrance path.
    Stay on the more packed stuff and you won't need 4wd.
  4. Apr 27, 2011 at 9:00 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Lives: Pyeongtaek, South Korea/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
  5. Apr 27, 2011 at 9:10 PM
    pudge151
    Sean
    Connecticut
  6. Apr 28, 2011 at 6:39 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    It's pretty loose sand. Not very packed. Just air down to 15-20ish psi and use 4hi and you will be fine. Also go easy on the skinny pedal. Wheel spin in sand is just going to dig you deeper. Unlike mud, there's nothing solid underneath, just more sand, and eventually water.
  7. Apr 28, 2011 at 6:49 AM
    macgyver
    Brad
    Canton, GA
    Lol yeah they do...
  8. Apr 28, 2011 at 6:54 AM
    dpak
    Richmond, VA
    Guess the smart thing to do is stay away from the beach. So is there nearby parking to the beach if I wanted to go surf fishing?
  9. Apr 28, 2011 at 6:58 AM
    macgyver
    Brad
    Canton, GA
    Yeah, but I'm sure other people will have the same idea and wanna fish right by the access ramp too.
  10. Apr 28, 2011 at 11:50 AM
    Namyo
    Namyo -
    get chu onea these
